STM32F103RCT6如何让按键按下后处于"失效"状态
踮起脚摘苹果 提问时间:2019-9-10 17:38 /
这段代码是按键部分的处理,其中有3个按键,童锁键,出热水键和出冷水键。出冷水需要短按冷水键,对应的冷水阀和冰胆进水阀打开;出热水需要先短按童锁键解锁,然后短按热水键热水键才被打开
/*按键工作*/
unsigned char statu = 0;
static char shot=0;// status hot
static char scold= 0;//status cold
static char child = 0;//童锁
static unsigned long cold_key_press_tick=0;
static unsigned long hot_key_press_tick=0;
static unsigned long child_key_press_tick=0;
static unsigned long cold_key_delay_tick=0;
static unsigned long hot_key_delay_tick=0;
static unsigned long child_key_delay_tick=0;
static int dchild = 0;//顾名思义,dchild => delay child
static int dhot = 0;
static int dcold = 0;//delay cold
char delay_hot=0;
char delay_cold= 0;
char delay_child = 0;
unsigned long G_Tick = 0;//冷水阀G计时时间
static unsigned long H_Off_Tick = 0;//H阀关闭计时时间
static unsigned long H_On_Tick = 0;//H阀打开计时时间
void Key_Work(void)
//        static KEY_TYPE key_type_temp = OFF_KEY;
        static char hchange = 0,cchange = 0,child_change = 0;//hot change ,cold change 设置翻转
#if 1
    if (READ_CHILD_KEY_VALUE)//读取童锁键值,但是有问题的是,if里面应该是一个表达式,表达式为真时,才会执行if里面的内容,so,READ_CHILD_KEY_VALUE == 1
        if (gTick - child_key_press_tick >= 3*1000)//按键按下时间超过9*1000ms
            child = 1;
    else
        child = 0;
        child_key_press_tick = gTick;
        if(child == 1)//长按童锁键
                child = 0;//按下后清空原状态
                if(key_type == CHILD_KEY)
                        child_change = !child_change;
                        key_type = OFF_KEY;
                       Trans_dat_append(STATE_23);//整机自清洗指令
                        if(child_change)//排水状态
                                System_Sta.s.clean_self_cmd = FLAG_ON;//自排水命令标志关闭
                                System_Sta.s.drain_close_flag = 1;//清除标志位
                                /*加蜂鸣器时间判断是否进入此循环,进入排水状态,蜂鸣器响2声*/
                                System_Sta.s.beep_timer_flag = TIMER_RUN;
                                Block_Timer(50);//阻塞时间50ms
                                System_Sta.s.beep_timer_flag = TIMER_RESET;
                                Block_Timer(200);//阻塞时间200ms
                                 System_Data.flash_water_flag[0]='0';
                                 System_Data.flash_water_flag[1]='1';//开始排水
                                /*在排水状态让按键短按"失效",一直没成功???,放在这里,似乎成功了*/
                                if((dchild == 1) || (dhot == 1) || (dcold == 1))//短按
                                        dchild = dhot = dcold = 0;
                                        delay_cold = delay_child = delay_hot = 1;
                                        hot_key_delay_tick = cold_key_delay_tick = child_key_delay_tick = 0;//短按
                                        hot_key_press_tick = cold_key_press_tick = child_key_press_tick = 0;//长按
                                        Set_HotWaterValve_F(Bit_RESET);
                                        Set_ColdWaterValve_G(Bit_RESET);
                                        Set_NormalWaterValve_H(Bit_RESET);
#if 0
                        else//不进入自排水状态,蜂鸣器响3声
                                System_Sta.s.clean_self_cmd = FLAG_OFF;//未收到自排水命令
                                System_Data.flash_water_flag[0]='2';//停止排水
                                child_change = 0;
#endif
#endif
    #if 1
        if(READ_HOT_KEY_VALUE)
            if(gTick-hot_key_press_tick>=3*1000)//“热键”按下时间超过9*1000ms
                        shot = 1;
        else
                shot = 0;
                hot_key_press_tick = gTick;
        if(READ_COLD_KEY_VALUE)
        if(gTick - cold_key_press_tick >= 3*1000)//“冷键”按下时间超过9*1000ms
                        scold = 1;
        else
                scold = 0;
                cold_key_press_tick = gTick;
        if(scold==1 && shot==1)//同时按下冷水键和热水键,长按
                Save_Data.s.self_clean_flag = 0;//保存掉电前自排水完成状态,自排水是"童锁"+"冷水"
                i2cWriteBuffer1(AT24C02_ADDR,AT24C02_REG,sizeof(SAVE_DATA_UNION),(u8*)&Save_Data);/*写入数据*/
                /*初始化整个联合体数组*/
                for (int i = 0; i < sizeof(STA_UNION); i++)
                        System_Sta.sta = 0;
                memset((void *)(&System_Data),0,sizeof(DATA_STRUCT));
        //开启蜂鸣器
        if(TIMER_RESET==System_Sta.s.beep_timer_flag)
        System_Data.flash_water_flag[1]='2';/*停止清洗*/
        while(1);
        if(scold==1 && child==1)   //按下冷水键和童锁键10s处于排气过程      (问题点???)
                System_Sta.s.clean_self_cmd = FLAG_OFF;//自排水标志位turn off
                System_Sta.s.Vent_Flag = FLAG_ON;//自排气标志位打开
                //System_Sta.s.Vent_Flag = FLAG_ON;
                //System_Data.Cold_Water_G_Tick = 0;//
                //System_Sta.s.Cold_Water_G_Flag = FLAG_OFF;
                //System_Data.Normal_Water_H_Tick = 0;
                //System_Sta.s.Normal_Water_H_Flag = FLAG_OFF;
//                for (int i = 0; i < sizeof(STA_UNION); i++)
//                        System_Sta.sta = 0;
//                memset((void *)(&System_Data),0,sizeof(DATA_STRUCT));
                while(1);//如果次处加上while(1)则无法打开冷水和热水阀
        if(shot == 1 && READ_COLD_KEY_VALUE == 0)//只按下热水键长按
                if(key_type == HOT_KEY)
                    hchange = !hchange;//hot change
                    key_type = OFF_KEY;
                        if(System_Sta.s.hot_close_flag == 1)
                                if(Bit_RESET==Read_WaterShortagDetection())
                                        System_Data.fixed_state[1] = '1';
                    System_Sta.s.hot_close_flag = 0;
                                        if (Save_Data.s.machine_type != DY_100B)
                        System_Data.ntc2_setting_temperature = 0;
                                        // u8 tem[2] = {0};
                                        // tem[0] = System_Data.ntc1_setting_temperature;
                                        // tem[1] = System_Data.ntc2_setting_temperature;
                                        // i2cWriteBuffer1(AT24C02_ADDR, AT24C02_REG_TEM, sizeof(tem), (u8*)&tem);/*写入数据*/
                                        Trans_dat_append(STATE_12);
                                        // GPIO_WriteBit(GPIOC, GPIO_Pin_12, 1);
                                        // GPIO_WriteBit(GPIOA, GPIO_Pin_13, 1);
                                        System_Sta.s.to_heat1_cmd_flag = FLAG_ON;
                                        System_Sta.s.to_heat2_cmd_flag = FLAG_ON;
                                        Trans_dat_append(STATE_03);
                                else
                                        Block_Timer(50);
                                        Block_Timer(200);
                                        Block_Timer(50);
                                        Block_Timer(200);
                                        Block_Timer(50);
                                        hchange = 0;//hot_key change
                        else
                                // GPIO_WriteBit(GPIOC, GPIO_Pin_12, 0);
                                // GPIO_WriteBit(GPIOA, GPIO_Pin_13, 0);
                                // System_Data.ntc1_setting_temperature = 0;
                                // if (Save_Data.s.machine_type == DY_100B)
                                //         System_Data.ntc2_setting_temperature = 0;
                                // else
                                // u8 tem[2] = {0};
                                System_Data.fixed_state[1] = '0';
                                Block_Timer(50);
                                Set_HotTube_1(Bit_RESET);
                                Set_HotTube_2(Bit_RESET);
                System_Sta.s.hot_close_flag = 1;
        if(scold == 1 && READ_HOT_KEY_VALUE == 0)//只按下冷水键
                if(key_type == COLD_KEY)
            cchange = !cchange;//冷键翻转
            //GPIO_WriteBit(GPIOA, GPIO_Pin_14, cchange);
            key_type = OFF_KEY;
            Trans_dat_append(STATE_02);
            if(cchange)
                System_Data.fixed_state[2] = '1';
                Set_IceTube(Bit_SET);
                Block_Timer(50);
                Block_Timer(200);
                Block_Timer(50);
            else
                System_Data.fixed_state[2] = '0';
                Set_IceTube(Bit_RESET);
                Block_Timer(50);
        if(Bit_SET==Read_WaterShortagDetection()||System_Data.ntc1_temperature>=95||System_Data.ntc2_temperature>=95)
                GPIO_WriteBit(GPIOC, GPIO_Pin_12, 0);//hot tube 1
                GPIO_WriteBit(GPIOA, GPIO_Pin_13, 0);//hot tube 2
                hchange = 0;
#endif
#ifdef KEY_DELAY_S
    // 加入按键持续时间判断
//    static unsigned long cold_key_delay_tick=0;
//    static unsigned long hot_key_delay_tick=0;
//    static unsigned long child_key_delay_tick=0;
#if 0
    char delay_hot=0;
    char delay_cold= 0;
#endif
    // child
                if (gTick - child_key_delay_tick >= KEY_DELAY_S_LOW * 1000 //KEY_DELAY_S_LOW单位为second,*1000为ms
            && gTick - child_key_delay_tick <= KEY_DELAY_S_HIGH * 1000)
            dchild = 1;
        else if (gTick - child_key_delay_tick > KEY_DELAY_S_HIGH * 1000)
            dchild = 0;
    else
        // 捕捉到 KEY_DELAY_S_LOW 到 KEY_DELAY_S_HIGH 区间内的有效按键
        if (dchild == 1)
            dchild = 0;
            delay_child = 1;
        child_key_delay_tick = gTick;
    // hot
    if (READ_HOT_KEY_VALUE)
        if (gTick - hot_key_delay_tick >= KEY_DELAY_S_LOW * 1000
                && gTick - hot_key_delay_tick <= KEY_DELAY_S_HIGH * 1000)
            dhot = 1;//
        else if (gTick - hot_key_delay_tick > KEY_DELAY_S_HIGH * 1000)
            dhot = 0;
    else
        if (dhot == 1)
            dhot = 0;
            delay_hot = 1;
        hot_key_delay_tick = gTick;
    // cold
    if (READ_COLD_KEY_VALUE)
        if (gTick - cold_key_delay_tick >= KEY_DELAY_S_LOW * 1000
                && gTick - cold_key_delay_tick <= KEY_DELAY_S_HIGH * 1000)
            dcold = 1;
        else if (gTick - cold_key_delay_tick > KEY_DELAY_S_HIGH * 1000)
            dcold = 0;
    else
        if (dcold == 1)
            dcold = 0;
            delay_cold = 1;
        cold_key_delay_tick = gTick;
    // 如果有超过1个按键在动作,则复位全部按键标志位
    int delay_key = delay_cold + delay_hot + delay_child;
    if (delay_key > 1)
        delay_cold = delay_hot = delay_child = 0;
        delay_key = 0;
#if 0
        //如果冷水键和热水键同时按下,则复位全部
        int delay_key1 = delay_cold + delay_hot;//delay_key1 表示同时按下冷水键和热水键的延时
        if(delay_key1 > 1)
                delay_cold = delay_hot = 0;
                delay_key1 = 0;
        //如果冷水键和童锁键同时按下,则进入排气过程
        int delay_key2 = delay_child + delay_cold;//delay_key2表示长按冷水键和童锁键
        if(delay_key2 > 1)
                System_Sta.s.Vent_Cmd = FLAG_ON;
#endif
#endif  // KEY_DELAY_S
        if(Save_Data.s.machine_type==DY_75)/*按键失效*/
                System_Sta.s.key_timer_flag = TIMER_RESET;
        else if(Save_Data.s.machine_type==DY_400)/*童锁键改为温水键*/
                Child_Key_On_Flag = 1;
        //等待捕捉到稳定按键值
    if((TIMER_RUN==System_Sta.s.key_timer_flag)&& (System_Data.key_tick >= KEY_DELAY_MS)
        #ifdef KEY_DELAY_S
            && (delay_key == 1)
                //复位按键去抖定时器
                System_Data.key_tick = 0;
                //更新按键值
        key_type_temp = key_type;
#ifdef KEY_DELAY_S
        if (delay_child == 1)
            key_type_temp = CHILD_KEY;
        else if (delay_cold == 1)
            key_type_temp = COLD_KEY;
        else if (delay_hot == 1)
            key_type_temp = HOT_KEY;
        else
                //开启蜂鸣器
  if (System_Data.fill_water_number[sizeof(System_Data.fill_water_number)-3] == '0' &&\
      System_Data.fill_water_number[sizeof(System_Data.fill_water_number)-2] == '1' &&\
      System_Data.fill_water_number[sizeof(System_Data.fill_water_number)-1] == '2'
//         if (key_type_temp != System_Data.last_key_type)
//             key_type_temp = OFF_KEY;
// //            return;
        //处理按键值
        switch(key_type_temp)
                case CHILD_KEY://此case为选择童锁按键
                        //System_Data.child_flag_tick = 0;
                        if(Save_Data.s.machine_type==DY_400)//DY_400为一个热水泵+一个冷水泵
                                if((CHILD_KEY==System_Data.last_key_type&&FLAG_ON==System_Sta.s.water_on_flag)||\
                                                 (System_Sta.s.Liquid_shortage_flag == FLAG_ON))
                                                Set_NormalWaterValve_H(Bit_RESET);//温水键复位
                                                //System_Data.cold_water_time += System_Data.cold_water_flag_tick/1000;
                                                System_Sta.s.child_timer_flag = TIMER_RESET;
                                                System_Sta.s.normal_water_on_flag = FLAG_OFF;
                                                System_Sta.s.pre_out_normal_water_flag = 0;
                                else /*准备打开温水开关*/
                                        System_Sta.s.pre_out_normal_water_flag = 1;
                                        if(TIMER_RESET!=System_Sta.s.nfc_tick_flag)
                                                Trans_dat_append(REQUEST_RFID_CHANGE_06);/*上报数据*/
                                                System_Data.rfid_number_ascill[24]='0';
                                                System_Data.rfid_number_ascill[25]='0';
                                        Trans_dat_append(STATE_22);/*上报数据 请求出水*/
                        else
                                System_Sta.s.child_timer_flag = TIMER_RUN;
                                Child_Key_On_Flag = 1;/*解锁*/
                        break;
                case HOT_KEY://此case为热键
                        if((FLAG_OFF==Child_Key_On_Flag) || \
                           (HOT_KEY==System_Data.last_key_type&&FLAG_ON==System_Sta.s.water_on_flag)|| \
                                Set_HotWaterValve_F(Bit_RESET);//复位热水键
                                System_Data.hot_water_time += System_Data.hot_water_flag_tick/1000;
                                System_Sta.s.hot_water_timer_flag = TIMER_RESET;//定时器复位
                                System_Data.hot_water_flag_tick = 0;//计时器清0
                                System_Sta.s.hot_water_on_flag = FLAG_OFF;
                                System_Sta.s.pre_out_hot_water_flag = 0;
                                if(FLAG_OFF==Child_Key_On_Flag)
                                        System_Data.water_out_flag[0] = '0';
                                        System_Data.water_out_flag[1] = '4';/*童锁未解锁拒绝出水*/
                                  Trans_dat_append(WATER_OUT_REPORT_21);/*上报数据*/
                                        if(System_Sta.s.nfc_tick_flag == TIMER_RUN)/*nfc出水中*/
                                                        System_Data.rfid_number_ascill[24] = '0';
                                                        System_Data.rfid_number_ascill[25] = '4';
                                        if(FLAG_OFF==System_Sta.s.scaven_end_flag)
                                                        System_Sta.s.scaven_hot_flag =  FLAG_ON;
                                                        Trans_dat_append(ORDER_REPORT_04);/*上报数据*/
                        else /*准备打开热水开关*/
                                System_Sta.s.pre_out_hot_water_flag = 1;
                                if(Save_Data.s.machine_type!=DY_400)
                                        System_Data.child_flag_tick = 0;/*清0童锁计数器*/
                        break;
                case COLD_KEY:
                        if((COLD_KEY==System_Data.last_key_type&&FLAG_ON==System_Sta.s.water_on_flag)|| \
                           (System_Sta.s.Liquid_shortage_flag == FLAG_ON && FLAG_ON == System_Sta.s.Normal_Water_H_Flag ))
                                System_Sta.s.cold_water_timer_flag = TIMER_RESET;
                                System_Data.cold_water_flag_tick = 0;
                                System_Sta.s.cold_water_on_flag = FLAG_OFF;
                                System_Sta.s.pre_out_cold_water_flag = 0;
                                System_Data.Normal_Water_H_Off_Time +=  System_Data.Normal_Water_H_Tick/1000;
                                System_Sta.s.Normal_Water_Timer_Flag = TIMER_RESET;
                                if(System_Sta.s.Normal_Water_H_Flag)
                                        System_Sta.s.Normal_Water_H_Flag = FLAG_ON;
                                if(System_Sta.s.Normal_Water_Timer_Flag == TIMER_RESET)
                                        System_Sta.s.Normal_Water_Timer_Flag = TIMER_RUN;
                                Set_NormalWaterValve_H(Bit_RESET);//此处H阀表示的是冰胆的进水阀,turn off it!!!,增加了H阀控制冰胆
                                if(gTick - H_Off_Tick > 200 && statu == 1)//关闭状态时statu应该从1到0,打开状态为从0到1
                                        H_Off_Tick = gTick;
                                        statu = 0;
                                if(TIMER_RUN == System_Sta.s.Normal_Water_Timer_Flag && System_Data.Normal_Water_H_Tick > 200)
                        else /*准备打开冷水开关*/
                                System_Sta.s.pre_out_cold_water_flag = 1;
                        break;
                case OFF_KEY:
                        break;
                default :
                        break;
        //更新上次的有效按键
        if(OFF_KEY!=key_type_temp && CHILD_KEY!=key_type_temp)
                System_Data.last_key_type = key_type_temp;
                if(CHILD_KEY == key_type_temp)
        if(System_Sta.s.pre_out_cold_water_flag==1||\
           System_Sta.s.pre_out_normal_water_flag ==1||\
           System_Sta.s.pre_out_hot_water_flag ==1)
                if(TIMER_RESET==System_Sta.s.wait_water_tick_flag)
                        System_Sta.s.wait_water_tick_flag = TIMER_RUN;
        else
                System_Sta.s.wait_water_tick_flag = TIMER_RESET;
                System_Data.wait_water_tick = 0;
        if(System_Data.wait_water_tick>5000)
                System_Sta.s.pre_out_cold_water_flag=0;
                System_Sta.s.pre_out_normal_water_flag =0;
                System_Sta.s.pre_out_hot_water_flag =0;
        //允许热水出水
        if(System_Sta.s.pre_out_hot_water_flag == 2)
                Set_HotWaterValve_F(Bit_SET);//热水阀置位
                Set_NormalWaterValve_H(Bit_RESET);//温水阀复位
                        H_Off_Tick = gTick;
                        statu = 0;
                        Set_ColdWaterValve_G(Bit_RESET);//在温水阀复位后的200ms冷水阀复位
                //Set_ColdWaterValve_G(Bit_RESET);//在温水阀复位后的200ms冷水阀复位
                if(TIMER_RESET==System_Sta.s.hot_water_timer_flag)
                        System_Sta.s.hot_water_timer_flag = TIMER_RUN;
                System_Sta.s.hot_water_on_flag = FLAG_ON;
                if(System_Sta.s.cold_water_on_flag)/*更新 切换出水相关标志位*/
                        System_Sta.s.Update_Out_Water_Time_flag = FLAG_ON;
                if(Save_Data.s.machine_type==DY_400&&System_Sta.s.child_timer_flag==1)/*更新 切换出水相关标志位*/
                        /*停止温水*/
                /*停止冷水*/
                /*取水容量定时器和标志位*/
                System_Data.Capacity_Control_Time += System_Data.Capacity_Control_Tick/1000;
                System_Sta.s.Capacity_Control_Timer_Flag = FLAG_OFF;
                System_Data.Capacity_Control_Tick = 0;
                System_Sta.s.Capacity_Control_Timer_Flag = TIMER_RESET;
                if(System_Sta.s.Capacity_Control_Flag)
                        System_Sta.s.Capacity_Control_Flag = FLAG_ON;
                if(System_Sta.s.Capacity_Control_Timer_Flag == TIMER_RESET)
                        System_Sta.s.Capacity_Control_Timer_Flag = TIMER_RUN;
                /*在冷水出水过程中增加阀H动作???                                  Add by HeJun */
                if(System_Data.Capacity_Control_Tick  > 45000 && TIMER_RUN == System_Sta.s.Capacity_Control_Timer_Flag)//当阀H的水量时间到了45s,则关闭H阀
                        //H_On_Tick = gTick;
                        //statu = 1;
                if(gTick - H_On_Tick > 45000 && statu == 0)
                        H_On_Tick = gTick;
                        statu = 1;
                                H_Off_Tick = gTick;
                                statu = 0;
        //允许冷水出水
        else if(System_Sta.s.pre_out_cold_water_flag == 2)
                Set_ColdWaterValve_G(Bit_SET);
                Set_InletValve_I(Bit_RESET);//此处阀I为热罐进水阀,turn off it!!!
                if(TIMER_RESET==System_Sta.s.cold_water_timer_flag)
                        System_Sta.s.cold_water_timer_flag = TIMER_RUN;
                        System_Sta.s.cold_water_on_flag = FLAG_ON;
                if(TIMER_RESET == System_Sta.s.Normal_Water_Timer_Flag)
                //System_Data.Capacity_Control_Tick = 0;
                if(System_Sta.s.hot_water_on_flag)/*更新 切换出水相关标志位*/
                if(gTick - G_Tick > 200 && statu == 0)//此段代码加载试验仅第一次有效
                        statu = 1;
                        G_Tick = gTick;
                Set_NormalWaterValve_H(Bit_SET);
                if(TIMER_RUN == System_Sta.s.cold_water_timer_flag && System_Data.cold_water_flag_tick > 200)
                /*停止热水*/
                        /*停止温水*/
                //允许温水出水
                if(System_Sta.s.pre_out_normal_water_flag == 2)
                        if(TIMER_RESET==System_Sta.s.child_timer_flag)
                        System_Sta.s.normal_water_on_flag = FLAG_ON;
                        /*停止热水*/
                        /*出水容量未满*/
                        System_Sta.s.Capacity_Control_Flag = FLAG_OFF;
                        /*冰胆进水阀关闭*/
                        /*取水容量标志位*/
                                System_Sta.s.Normal_Water_Timer_Flag = FLAG_ON;
                        /*停止冷水*/
                                //statu = 1;
                                H_On_Tick = gTick;
                                statu = 1;
                                        H_Off_Tick = gTick;
                                        statu = 0;
                /*温水键工作*/
                if((TIMER_RUN==System_Sta.s.child_timer_flag) && (System_Data.child_flag_tick>HOT_DELAY_MS))
        else
                /*童锁键工作*/
                if((FLAG_ON==Child_Key_On_Flag) && \
                   (CHILD_DELAY_MS>System_Data.child_flag_tick) && \
                   (FLAG_ON==System_Sta.s.hot_water_on_flag))
                else if(CHILD_DELAY_MS<=System_Data.child_flag_tick)
                        Child_Key_On_Flag = 0;
        /*热水键工作*/
        if((TIMER_RUN==System_Sta.s.hot_water_timer_flag) && (System_Data.hot_water_flag_tick>HOT_DELAY_MS))
//  if( (TIMER_RUN==System_Sta.s.hot_water_timer_flag) &&\
//                  (0<System_Data.hot_water_flag_tick) &&\
//                  (HOT_DELAY_MS>System_Data.hot_water_flag_tick) &&\
//            (TIMER_RUN==System_Sta.s.hot_water_timer_flag) )
        /*冷水键工作*/
        if((TIMER_RUN==System_Sta.s.cold_water_timer_flag) && (System_Data.cold_water_flag_tick > COLD_DELAY_MS) \
                 && (TIMER_RUN == System_Sta.s.Normal_Water_Timer_Flag))
                /*在冷水出水过程中增加阀H动作,直接关闭H阀                                        Add by  */
                        H_Off_Tick = gTick;
                        statu = 0;
此段代码中dchild,dhot和dcold都是短按的延时变量,那么当我短按按下任何一个按键,该按键本该有的状态不被触发该用什么方法做?比方说短按冷水键冷水阀和冰胆进水阀不打开,短按童锁键再按热水键,热水阀不打开。 if((dchild == 1) || (dhot == 1) || (dcold == 1))//短按
       Set_HotWaterValve_F(Bit_RESET);//热水出水阀复位
       Set_ColdWaterValve_G(Bit_RESET);//冷水出水阀复位
       Set_NormalWaterValve_H(Bit_RESET);//冰胆进水阀复位
这段代码是我尝试的做法,也就是把短按的按键延时变量清0,但是各按键按下后依然有效,现在卡在这里了???
赞 收藏 评论6 发布时间:2019-9-10 17:38
6个回答
wenyangzeng 回答时间:2019-9-10 19:09:12
设置1个标志位,按动了童锁键就置位,热水键根据标志位出水或不出水即可。
踮起脚摘苹果 回答时间:2019-9-10 19:37:53
wenyangzeng 发表于 2019-9-10 19:09
设置1个标志位,按动了童锁键就置位,热水键根据标志位出水或不出水即可。 ...
如果童锁键被置位了,那么热水键就算是按下也不会触发热水阀打开了
wenyangzeng 回答时间:2019-9-10 20:42:11
假设标志位为1时允许出热水,执行出热水后清除标志位。本次出热水有效。出完热水后禁止,本次操作结束。
七哥 回答时间:2019-9-11 09:37:32
功能不复杂,代码看不懂。
建议写成状态机的方式,把事件分成几个状态,各状态间跳转清晰明了。
tanic 回答时间:2019-9-11 16:46:14
代码架构很乱,懒得看,
业务逻辑很简单,
建议重构状态机或者使用RTOS。
代码架构乱,是导致程序猿写&改BUG的主要原因之一
tanic 回答时间:2019-9-11 16:55:25
//键值获取
key=Key_scan();
//状态位更改
/*根据最新键值,结合之前的状态,更新状态标志*/
//动作执行
/*根据标志控制输出*/
