STM32F1短路断路针脚实现外部中断,触发不稳定
landoli 提问时间:2020-3-16 10:36 /
因为产品需要,要短路2个针脚,一个针脚设置为推挽输出,50MZ。一个针脚设置为浮空输入,并设置为捕捉上升沿和下降沿的外部中断位。然后用杜邦线将两个针脚插一起。这个时候应该是触发上升沿,然后拔掉一个针脚,应该是触发下降沿的。结果非常不好用。有时拔掉以后,也不触发下降沿。有时插上不触发上升沿,有时杜邦线活动一下,就不断的进中断。已经加了软件消抖。
想问一下,我的代码有问题吗?如果没问题,那我是不是要加电容解决?加多少,怎么加合适?如果不建议这种方式,那怎么做能判断一个线路是通路还是短路呢?
请大神帮忙!!!
  1. #define LOCK_EXIT_GPIO_CLK                                         RCC_APB2Periph_GPIOA
  2. #define LOCK_EXIT_GPIO_PORT                                         GPIOA
  3. #define LOCK_EXIT_GPIO_PIN                                         GPIO_Pin_4
  4. #define LOCK_EXIT_GPIO_PORTSOURCE          GPIO_PortSourceGPIOA
  5. #define LOCK_EXIT_GPIO_PINSOURCE          GPIO_PinSource4
  6. #define LOCK_EXIT_LINE                                                  EXTI_Line4
  7. #define LOCK_EXIT_IRQN                                                        EXTI4_IRQn
  8. #define LOCK_EXIT_IRQHANDLER                                EXTI4_IRQHandler
  9. #define LOCK_STA GPIO_ReadInputDataBit(LOCK_EXIT_GPIO_PORT, LOCK_EXIT_GPIO_PIN)
  10. #define LOCK_OUT_GPIO_CLK                                         RCC_APB2Periph_GPIOA
  11. #define LOCK_OUT_GPIO_PORT                                 GPIOA
  12. #define LOCK_OUT_GPIO_PIN                                         GPIO_Pin_5
  1. lock_gpio.GPIO_Pin = LOCK_EXIT_GPIO_PIN;
  2.         lock_gpio.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  3.         GPIO_Init(LOCK_EXIT_GPIO_PORT, &lock_gpio);
  4.
  5.         lock_gpio.GPIO_Pin = LOCK_OUT_GPIO_PIN;
  6.         lock_gpio.GPIO_Mode = GPIO_Mode_Out_PP;
  7.         lock_gpio.GPIO_Speed = GPIO_Speed_50MHz;
  8.         GPIO_Init(LOCK_OUT_GPIO_PORT, &lock_gpio);
  9.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO , ENABLE);
  10.
  11.         GPIO_EXTILineConfig(LOCK_EXIT_GPIO_PORTSOURCE, LOCK_EXIT_GPIO_PINSOURCE);
  12.         lock_exti.EXTI_Line = LOCK_EXIT_LINE;
  13.         lock_exti.EXTI_Mode = EXTI_Mode_Interrupt;
  14.         lock_exti.EXTI_Trigger = EXTI_Trigger_Rising_Falling;
  15.         lock_exti.EXTI_LineCmd = ENABLE;
  16.
  17.         EXTI_Init(&lock_exti);
  18.
  19.         GPIO_SetBits(LOCK_OUT_GPIO_PORT, LOCK_OUT_GPIO_PIN);
  1. char lockStatus;
  2. char isUnLock;
  3. void LOCK_EXIT_IRQHANDLER(void)
  4. {
  5.          if(EXTI_GetITStatus(LOCK_EXIT_LINE) != RESET){
  6.
  7.                  if(LOCK_STA != lockStatus){
  8.                                 delay_ms(10);
  9.                          if(LOCK_STA != lockStatus){
  10.                                 if(!isUnLock){
  11.                                         lockStatus = LOCK_STA;
  12.                                         isUnLock = 1;
  13.                                  }
  14.                          }
  15.                  }
  16.          }
  17.          delay_ms(100);
  18.          EXTI_ClearITPendingBit(LOCK_EXIT_LINE);
  19. }
赞 收藏 评论2 发布时间:2020-3-16 10:36
mylovemcu 回答时间:2020-3-16 11:20:23
输入针脚不用配置成浮空输入的  上拉或者下拉都可以  上拉常态就是高电平  下拉常态就是低电平  这样确定进中断的方式
如果软件采用中断输入  不建议采用软件消抖  采用1K电阻和0.1uf电容进行硬件消抖
参与人数 1蝴蝶豆 +3 收起 理由
STMCU + 3
landoli 回答时间:2020-3-16 14:23:55
mylovemcu 发表于 2020-3-16 11:20
输入针脚不用配置成浮空输入的  上拉或者下拉都可以  上拉常态就是高电平  下拉常态就是低电平  这样确定进 ...
谢谢大神!我准备加个电阻
