求购基于STM32F4X的例程(付费)
sagane 发布时间:2020-7-14 14:45
4 D7 l, m* ^+ E' {Hi,
4 r. c# I& A7 q: t1 P6 s两个问题:
) R/ j* E: w& {+ n3 t& f% K* K1.求购1套基于STM32F4X的code,已经经过验证的,可以付费,我的微信:85929109,可以私信我。* K) s4 v" }' H; j
2.本人用CubeMx Version 5.6.1生成的Custom Hid设备可以枚举成功,但是不能收发数据,通过Bus hound获取描述符述提示invalid command ,在Capture窗口返回Cancel,还请牛人指点。7 h% U8 z; E% o5 U9 s
( |& N8 J- g+ d, P$ |4 c/ F
报告描述符如下:* M: H4 \. }4 ]3 t
/** Usb HID report descriptor. */
" }8 r  M1 T$ G% [* K__ALIGN_BEGIN static uint8_t CUSTOM_HID_ReportDesc_FS[USBD_CUSTOM_HID_REPORT_DESC_SIZE] __ALIGN_END =. J" {7 V0 i8 ^5 j/ ]
% G6 P' R2 R# H4 ?3 |                0x05, 0x8C,            /* USAGE_PAGE (User Define)           */
6 a+ u6 q4 t- E( \                0x09, 0x01,
/ o+ }. U+ ]2 Y( Q$ B7 C( O                0xa1, 0x01,5 z' E) B, e5 G
    /* 6 */+ U9 i- [% }8 r. ^: b6 z* H1 o2 \+ f
    /*in*/    : |9 j. s7 S, m2 I. `5 C. a5 J, l( [
    0x09, 0x03,                    // USAGE_PAGE(1)
0 h. M! I) O7 r    0x19, 0x00,                    //   USAGE_MINIMUM(0)
1 o6 B3 [% c/ ~  w' X1 K+ p    0x29, 0xFF,                    //   USAGE_MAXIMUM(255)
6 ^: F7 ~; \/ O5 H0 o  Z    0x15, 0x00,                    //   LOGICAL_MINIMUM (0): u9 }1 V% X* Y$ }' |! K
    0x25, 0xFF,                    //   LOGICAL_MAXIMUM (255)- L: ?6 G8 `  X  Y
    0x75, 0x08,                    //   REPORT_SIZE (8). f# [* n# F6 {
    0x95, 0x40,                    //   REPORT_COUNT (64)
: h+ w1 a# r( {, ^$ F$ ^) `+ ~+ ]    0x81, 0x02,                    //   INPUT (Data,Var,Abs)" N% U$ I1 b0 e: h; [7 t3 ?
    /*22*/
' e5 M" k+ i) r9 F5 T- \
: @& \7 G7 p3 @6 X+ V    /*out*/
, D$ N$ ]8 U' o: a, A    0x09, 0x04,                    // USAGE_PAGE(2)
3 g) `- b9 x( G: a# r6 V8 L    0x19, 0x00,                    //   USAGE_MINIMUM (0)( Y6 u/ ^, A' h; v3 c
    0x29, 0xFF,                    //   USAGE_MAXIMUM (255); C4 L# |2 ^# }4 @
    0x15, 0x00,                    //   LOGICAL_MINIMUM (0)9 o% l/ w: k1 M4 x' Q# P' z7 b
. h1 E- Q  S2 s4 g& g    0x75, 0x08,                    //   REPORT_SIZE (8)
& E- c% C+ Z9 q' n    0x95, 0x40,                    //   REPORT_COUNT (64)
3 {$ N, F- r9 M  E0 [) {) E/ r    0x91, 0x02,                    //   OUTPUT (Data,Var,Abs)
9 j7 V. S/ a, h# l    /* 38 */
5 ]/ c* o, L/ F$ F- m) ~4 y    0xc0               /*     END_COLLECTION                 */
. D% V: ]. C. I. b' {};
+ V* C& ]5 I3 q" ~; J5 o5 f. F" t) @0 `5 ?9 k* P( `  _
4 @  I8 [8 u8 P. S; Q
# s) k5 n) a' @' b+ A
赞 收藏 评论1 发布时间:2020-7-14 14:45
李康1202 回答时间:2020-7-15 08:58:47
顶一下
1 d9 y! O* a0 q  i, F
