' ^/ M# A% R) N+ k3 Q5 M. h" M/ l
2 ?" [6 h" A, Y# M1 ]
1. Linux运维基础采集项做运维,不怕出问题,怕的是出了问题,抓不到现场,两眼摸黑。所以,依靠强大的监控系统,收集尽可能多的指标,意义重大。但哪些指标才是有意义的呢,本着从实践中来的思想,各位工程师在长期摸爬滚打中总结出来的经验最有价值。 在各位运维工程师长期的工作实践中,我们总结了在系统运维过程中,经常会参考的一些指标,主要包括以下几个类别: CPU Load 内存 磁盘 IO 网络相关 内核参数 ss 统计输出 端口采集 核心服务的进程存活信息采集 关键业务进程资源消耗 NTP offset采集 DNS解析采集
7 z% r! w! g" _) ~
每个类别,具体的详细指标如下,这些指标,都是open-falcon的agent组件直接支持的。falcon-agent每隔一定时间间隔(目前是60秒)会采集一次相关的指标,并汇报给server端。 2. CPU相关采集项计算方法:通过采集/proc/stat来得到,大家可以参考sar命令的统计输出来理解。 cpu.idle:Percentage of time that the CPU or CPUs were idle and the system did not have an outstanding disk I/O request. cpu.busy:与cpu.idle相对,他的值等于100减去cpu.idle。 cpu.guest:Percentage of time spent by the CPU or CPUs to run a virtual processor. cpu.iowait:Percentage of time that the CPU or CPUs were idle during which the system had an outstanding disk I/O request. cpu.irq:Percentage of time spent by the CPU or CPUs to service hardware interrupts. cpu.softirq:Percentage of time spent by the CPU or CPUs to service software interrupts. cpu.nice:Percentage of CPU utilization that occurred while executing at the user level with nice priority. cpu.steal:Percentage of time spent in involuntary wait by the virtual CPU or CPUs while the hypervisor was servicing another virtual processor. cpu.system:Percentage of CPU utilization that occurred while executing at the system level (kernel). cpu.user:Percentage of CPU utilization that occurred while executing at the user level (application). cpu.cnt:cpu核数。 cpu.switches:cpu上下文切换次数,计数器类型。 5 F [8 A" O# W o) v0 ]$ f5 ~
3. 磁盘相关采集项计算方法:先读取/proc/mounts拿到所有挂载点,然后通过syscall.Statfs_t拿到blocks和inode的使用情况。每个metric都会附加一组tag描述,类似mount=$mount,fstype=$fstype,其中$mount是挂载点,比如/home,$fstype是文件系统,比如ext4。 df.bytes.free:磁盘可用量,int64 df.bytes.free.percent:磁盘可用量占总量的百分比,float64,比如32.1 df.bytes.total:磁盘总大小,int64 df.bytes.used:磁盘已用大小,int64 df.bytes.used.percent:磁盘已用大小占总量的百分比,float64 df.inodes.total:inode总数,int64 df.inodes.free:可用inode数目,int64 df.inodes.free.percent:可用inode占比,float64 df.inodes.used:已用的inode数据,int64 df.inodes.used.percent:已用inode占比,float64 ' ]0 O- L( k! Y$ z$ E- [* ~) Q6 E/ R2 l
4. megacli工具输出使用 megacli 工具读取 RAID 相关信息,每个metric都会附件一组tag描述,用来标明所属PD或者 VD,PD格式为PD=Enclosure_ID:SLOT_ID,比如PD=32:0表明第一块磁盘 ,VD=0 表明第一个逻辑磁盘。 sys.disk.lsiraid.pd.Media_Error_Count:这个及以下三个指标目前仅作为数据收集,不一定意味磁盘损坏(只是表示损坏概率变大) sys.disk.lsiraid.pd.Other_Error_Count sys.disk.lsiraid.pd.Predictive_Failure_Count sys.disk.lsiraid.pd.Drive_Temperature sys.disk.lsiraid.pd.Firmware_state:如果值不为0,则此物理磁盘出现问题 sys.disk.lsiraid.vd.cache_policy:如果值不为0,表示此逻辑磁盘缓存策略和设置不符 sys.disk.lsiraid.vd.state:如果值不为0,表示此逻辑磁盘出现问题
. \: i, J# L# Y" w3 y 5. SMART工具输出使用 smartctl 工具读取磁盘 SMART 信息,目前所有指标仅作为数据收集,不一定意味磁盘损坏(只是表示概率变大),每个metric都会有一组tag描述,表明盘符,例如device=/dev/sda。 sys.disk.smart.Reallocated_Sector_Ct sys.disk.smart.Spin_Retry_Count sys.disk.smart.Reallocated_Event_Count sys.disk.smart.Current_Pending_Sector sys.disk.smart.Offline_Uncorrectable sys.disk.smart.Temperature_Celsius
$ a8 e) D- q' U! h' V+ m J 6. 分区读写监控测试所有已挂载分区是否可读写,每个metric都会有一组tag描述,表示挂载点,比如mount=/home 7. IO相关采集项计算方法:每秒采集一次/proc/diskstats,计算差值,都是计数器类型的。每个metric都会有一组tag描述,形如device=$device,用来表示具体的设备,比如sda1、sdb。用户可以参考iostat的帮助文档来理解具体的metric含义。 disk.io.ios_in_progress:Number of actual I/O requests currently in flight. disk.io.msec_read:Total number of ms spent by all reads. disk.io.msec_total:Amount of time during which ios_in_progress >= 1. disk.io.msec_weighted_total:Measure of recent I/O completion time and backlog. disk.io.msec_write:Total number of ms spent by all writes. disk.io.read_merged:Adjacent read requests merged in a single req. disk.io.read_requests:Total number of reads completed successfully. disk.io.read_sectors:Total number of sectors read successfully. disk.io.write_merged:Adjacent write requests merged in a single req. disk.io.write_requests:total number of writes completed successfully. disk.io.write_sectors:total number of sectors written successfully. disk.io.read_bytes:单位是byte的数字 disk.io.write_bytes:单位是byte的数字 disk.io.avgrq_sz:下面几个值就是iostat -x 1看到的值 disk.io.avgqu-sz disk.io.await disk.io.svctm disk.io.util:是个百分数,比如56.43,表示56.43%
. m' g9 k; k* s @* J5 n, v 8. 机器负载相关采集项计算方法:读取/proc/loadavg,都是原始值类型的: load.1min load.5min load.15min / U, \+ ?; E) p$ E) _
9. 内存相关采集项计算方法:读取/proc/meminfo 中的内容,其中的mem.memfree是free+buffers+cached,mem.memused=mem.memtotal-mem.memfree。用户具体可以参考free命令的输出和帮助文档来理解每个metric的含义。 10. 网络相关采集项计算方法:读取/proc/net/dev的内容,每个metric都附加有一组tag,形如iface=$iface,标明具体那个interface,比如eth0。metric中带有in的表示流入情况,out表示流出情况,total是总量in+out,支持的metric如下: net.if.in.bytes net.if.in.compressed net.if.in.dropped net.if.in.errors net.if.in.fifo.errs net.if.in.frame.errs net.if.in.multicast net.if.in.packets net.if.out.bytes net.if.out.carrier.errs net.if.out.collisions net.if.out.compressed net.if.out.dropped net.if.out.errors net.if.out.fifo.errs net.if.out.packets net.if.total.bytes net.if.total.dropped net.if.total.errors net.if.total.packets 8 O% a$ ^; Q* {
11. 端口采集项计算方法,通过ss -ln,来判断指定的端口是否处于listen状态。原始值类型,值要么是1:代表在监听,要么是0,代表没有在监听。每个metric都附件一组tag,形如port=$port,$port就是具体的端口。 net.port.listen + _" I2 A8 \8 @- K
12. 机器内核配置kernel.maxfiles:读取的/proc/sys/fs/file-max kernel.files.allocated:读取的/proc/sys/fs/file-nr第一个Field kernel.files.left:值=kernel.maxfiles-kernel.files.allocated kernel.maxproc:读取的/proc/sys/kernel/pid_max & `/ M, S8 E N8 T( N
13. ntp采集项使用 ntpq -pn 获取本机时间相对于 ntp 服务器的 offset。 14. 进程监控15. 进程资源监控process.cpu.all:进程和它的子进程使用的sys+user的cpu,单位是jiffies process.cpu.sys:进程和它的子进程使用的sys cpu,单位是jiffies process.cpu.user:进程和它的子进程使用的user cpu,单位是jiffies process.swap:进程和它的子进程使用的swap,单位是page process.fd:进程使用的文件描述符个数 process.mem:进程占用内存,单位byte
5 Y( U0 u/ ]* |# L5 I$ o" \# N6 ^# R! E# u 16. ss命令输出ss.orphaned ss.closed ss.timewait ss.slabinfo.timewait ss.synrecv ss.estab ! z$ X5 t! u1 k7 \( _- X
6 F0 u" `3 s0 K, k
Z: r4 C' X9 A: y+ C5 `. f |
