【年度庆典二】STM32G431RBT6携三色墨水屏送祝福
Squall 发布时间:2021-1-4 12:15
大家好,我又又来啦~!先祝愿ST社区论坛越来越好~!  c5 A3 {; F/ K1 c% L. }( D" K
7 ~8 U, {( P: H- P0 {7 X
传统节目:桂花~上酸菜~!* n: ^5 x* E" y8 Q
0 O: k' K1 Z5 x( r0 Y小伙伴们说我只有旧板子,来,给你们看看新的。# e/ |. w% U$ b& e5 _, R9 @
# l" i5 s% \. s7 |- @废话不多说,桂花~上酸菜~!, R3 A4 h  f) z" {5 r6 s! V; B
; X+ {0 N; l$ q6 }+ V
6 r$ Z, i& E# s" u- u
! ~% A2 B( C- a8 o! @  Q2 |部分Main函数代码:. x# T; W  [4 @2 K
  1. /* Private user code ---------------------------------------------------------*/6 H$ J9 t5 [. G' U/ k- n
  2. /* USER CODE BEGIN 0 */% n/ h- {' l+ `$ A& I
  3. static int steps=0;//状态3 B7 [5 @* Z: j/ G
  4. static int Status=0;//步骤1 n: e. f( C, H% P+ ?
  5. /* USER CODE END 0 */( z% {( l! b% t) R7 O+ A
  6.   a2 {2 P* l7 p1 u( d8 s# @
  7. /**: U1 e, s! ?/ P! d% C
  8.   * @brief  The application entry point.
    ( ?5 H8 `: k2 i5 _$ n' i/ s
  9.   * @retval int
    4 w& l. m% H5 D6 a
  10.   */  U7 S& m6 y1 Z9 [# n9 O. ]
  11. int main(void)
    , H) Z% u* T7 @; m+ Z' P) W  m
  12. {
    5 n( f5 p) f4 }; n$ `" C7 w
  13.   /* USER CODE BEGIN 1 */- L! H# ~- V$ @, `( F3 R  b5 ~2 r
  14. $ p1 t3 U6 Y' J6 x! G
  15.   /* USER CODE END 1 */
    . P% e  O$ i1 o
  16. , D- O1 p. q# v/ Z( Z9 v+ U5 p
  17.   /* MCU Configuration--------------------------------------------------------*/! S" B: [- b( e
  18. / }/ i5 [9 |+ x% q! D+ a5 U
  19.   /* Reset of all peripherals, Initializes the Flash interface and the Systick. */& J9 ^) \3 f3 r) ]; C2 i) m1 {+ y
  20.   HAL_Init();2 L- q2 K/ G5 S' H: Y6 K" m
  21. / P0 u$ t2 i& i! b3 s
  22.   /* USER CODE BEGIN Init */6 T  }5 h' k. B9 H
  23. . A: r) l* `' G( Y: T6 S" E2 |
  24.   /* USER CODE END Init */
      Y' @) v+ ?( P4 R/ _+ T
  25. ' I+ K2 ]+ @4 `" w
  26.   /* Configure the system clock */' N* [1 _- E9 V& `- k6 p
  27.   SystemClock_Config();
    ! |9 S5 J/ A4 m7 @3 B! V
  28. 1 Q' r" S6 y; D
  29.   /* USER CODE BEGIN SysInit */
    " q& y  v# K7 Y+ S: _
  30. 8 ^9 p4 e" O7 K6 v; p4 l- ?
  31.   /* USER CODE END SysInit */! h" Y- H' u5 q- t
  32. 7 u1 ]0 ]1 L7 N. \
  33.   /* Initialize all configured peripherals */- i% ]8 r! X+ B% o, w4 m0 u
  34.   MX_GPIO_Init();
    ( t, P2 L. n8 m
  35.   MX_LPUART1_UART_Init();4 s3 N! g: G% B; V/ _
  36.   MX_SPI2_Init();: }$ r6 f, u! z1 U
  37.   /* USER CODE BEGIN 2 */
    ) ]" S& ^- P5 F
  38.         Status=1;
    2 e* A/ D- ~, I7 N- `- S# Z2 c: E/ c
  39.         HAL_GPIO_WritePin(LD2_GPIO_Port, LD2_Pin, GPIO_PIN_SET);
    . l4 X. J3 y0 p; _+ O  w
  40.         steps = HT_1in54b_V2_init();
    4 c1 R% V  R* u6 L
  41.   /* USER CODE END 2 */
    4 a1 t0 L' O' P7 C0 h
  42. 5 ~+ w9 k1 J: X, L8 Z$ x
  43.   /* Infinite loop */
    7 Q9 r* o. o! B# M2 m% Q
  44.   /* USER CODE BEGIN WHILE */0 S- b4 H  Y% `) R1 i1 K9 O# ^4 V
  45.   while (1)
    6 H; Z1 z) ?: _6 E
  46.   {
    ! a2 K, y5 J- }2 M+ ]
  47.     /* USER CODE END WHILE */
    9 [. l% Y, ~/ H0 L0 Y4 p1 @
  48. $ ~( T; \( w+ E! ^  f
  49.     /* USER CODE BEGIN 3 */
    , @# {* B6 K. Y9 ]9 R0 r* O
  50.   }
    / v- n- {9 r: L! j8 F& e( d* R
  51.   /* USER CODE END 3 */% k1 j% y( k" j6 V- _
  52. }
  1. /* USER CODE BEGIN 4 */4 ~3 f6 t5 ^" l! _
  2. void HAL_GPIO_EXTI_Callback(uint16_t GPIO_Pin)  . M. ~$ o3 o5 [" D
  3. {  # O7 W% t" n' L/ y
  4.   /* NOTE: This function Should not be modified, when the callback is needed, ( t/ t# ?" h+ s# a
  5.            the HAL_GPIO_EXTI_Callback could be implemented in the user file
    , U- h: K! Q( I* s1 d  v
  6.    */
    6 E! z7 v% h9 o
  7.     switch(GPIO_Pin)
    6 e. q( K' z% C4 v
  8.     {  //LD3_Pin|LD2_Pin
    ( {: [. _  u: a1 J2 _8 C
  9.         case B1_Pin:( j1 }5 z% r: h* _
  10.                                         if(Status==1)7 |" k  h7 P# o3 ~3 |
  11.                                         {
    & y: Y& u$ i* o2 P7 x. J3 {
  12.                                                 if(steps==1)$ q( N9 A- S. s. N4 T! m
  13.                                                 {
    , Y& G& l- v/ t% u1 h, A
  14.                                                         Status=0;
    ! v9 n% j3 [9 p. ], D5 d& D
  15.                                                         HT_1in54b_V2_clear();
    ; W. |& S/ [" ?$ e5 ~9 y* F. [
  16.                                                         Status=HT_1in54b_V2_showLogo1();
    - B9 r# A, X: d6 N  _, n5 K
  17.                                                 }
    ) p7 q8 U! ^- Z9 O
  18.                                                 else if(steps==2)2 @, O' \$ w) s+ N) ?
  19.                                                 {
    # z3 v5 [* K2 m7 J* {
  20.                                                         Status=0;: c+ n* L- f' j; J/ n: c& V1 i  c
  21.                                                         HT_1in54b_V2_clear();
    3 _! K7 W( O- _' L
  22.                                                         Status=HT_1in54b_V2_showWord1();2 _; o! @; z- u7 T# f7 L  s! g
  23.                                                 }
    2 N' `0 w  p# I! n* E- P
  24.                                                 else if(steps==3)+ p& {7 ]: w9 S3 e. m" ~3 t
  25.                                                 {
    9 r* A5 y' e/ T' z9 P; |2 ]" V
  26.                                                         Status=0;
    3 b# n" K/ i6 s5 c# S9 Y' [  ^
  27.                                                         HT_1in54b_V2_clear();
    / o5 ?( @/ L' E
  28.                                                         Status=HT_1in54b_V2_showLogo2();
    6 n/ W* i- x' p: Y2 O
  29.                                                 }$ ^- I1 T! U8 y, n* o( U
  30.                                                 else if(steps==4)
    & h2 x- U& F" M$ L* {# Q
  31.                                                 {
    0 H  R4 x* E8 N8 C; u/ e* m% Z
  32.                                                         Status=0;' c2 E5 N+ Y3 Q3 @' d: [6 r
  33.                                                         HT_1in54b_V2_clear();3 J9 m2 V8 B# F& o9 r) ]
  34.                                                         Status=HT_1in54b_V2_showWord2();
    7 n; D9 K5 W  f1 J
  35.                                                 }
    ( k0 e$ N1 t1 J2 i6 ?8 c- N- o, m* p
  36.                                                 steps+=1;
    * R# Z. j! M' m7 ?$ f; U
  37.                                                 if(steps>=5)( `: q# m/ T7 m0 _( H
  38.                                                 {2 ^" t; L" l# e
  39.                                                         steps=1;: p3 d2 G8 n# ~! g. O2 h
  40.                                                 }
    . C$ @! y5 T: X, X1 j/ N
  41.                                         }- x" ]- C* i* J' m! V$ l) i
  42.        9 p7 ?, B( f- n$ _1 C# u
  43.                                         break;
    * ~! g3 d6 C/ @1 Z" ^2 |
  44.         default:
    * L, |' ?7 x! _8 b% e, |# z
  45.                                         break;  * g. m; e5 H2 s. o9 z
  46.     }  ) Q7 n9 K+ v8 R/ p# Z0 t
  47.         }+ K% e6 O) v2 G, ~% O. H) _
  48. /* USER CODE END 4 */
, v% |# `$ ~  H' l' n3 s* G& b- j9 _4 N& I! b8 M
双手奉上代码。
' }5 h" U. \2 Y8 P0 r, H+ [全部代码及CubeMX配置:! I- C0 y, B' x% r( u( V
链接:https://pan.baidu.com/s/19vbPL4WoJOzACWszifYSKQ ! m2 M5 T+ i; Q4 Z3 {. f# I
提取码:rtnb
( f2 I/ u* j/ F, z. E. B. S4 ~
/ m; t0 c8 z1 z6 r" q
赞 收藏 评论0 发布时间:2021-1-4 12:15
