一些成熟软件中常用的宏定义
gaosmile 发布时间:2021-1-12 13:49
写好C语言,漂亮的宏定义很重要,使用宏定义可以防止出错,提高可移植性,可读性,方便性等等。下面列举一些成熟软件中常用的宏定义。
1. 防止一个头文件被重复包含1#ifndef COMDEF_H
5 D2 T3 M* u; C2#define COMDEF_H- n6 N. t6 s8 V$ Q0 Z" V
3//头文件内容
$ ~- {1 x: D4 j& ~4#endif
% i6 v8 `/ F0 \6 t1 F( O$ U% i
2. 重新定义一些类型,防止由于各种平台和编译器的不同,而产生的类型字节数差异,方便移植。1typedef unsigned char boolean; /* Boolean value type. */
2 P2 e, C" h0 ^4 P/ l0 E2typedef unsigned long int uint32; /* Unsigned 32 bit value */" t7 r  {- y$ Z* c3 x3 y, i" q
3typedef unsigned short uint16; /* Unsigned 16 bit value */
. \' p' z9 a) w9 d. U4typedef unsigned char uint8; /* Unsigned 8 bit value */' Y7 t" X& N, y( f# t
5typedef signed long int int32; /* Signed 32 bit value */1 d0 X& W: C4 B, J" A
6typedef signed short int16; /* Signed 16 bit value */! B' w' k9 w- y1 f( I9 _% q
7typedef signed char int8; /* Signed 8 bit value */
% \8 R% y- b) }4 F( ~
下面的不建议使用
1typedef unsigned char byte; /* Unsigned 8 bit value type. */6 ~2 ^& `  n4 l! x/ r
2typedef unsigned short word; /* Unsinged 16 bit value type. */
( Z" s8 f/ l& G 3typedef unsigned long dword; /* Unsigned 32 bit value type. *// w# C# H: e: Z* k4 X
4typedef unsigned char uint1; /* Unsigned 8 bit value type. */
# H5 R+ R6 W' q# _. h 5typedef unsigned short uint2; /* Unsigned 16 bit value type. */
/ Z) ]/ \1 h' C( J& q& P 6typedef unsigned long uint4; /* Unsigned 32 bit value type. */% p+ Z/ t3 k& G# f. c$ n3 a
7typedef signed char int1; /* Signed 8 bit value type. */  q# x$ ]  M$ l: u
8typedef signed short int2; /* Signed 16 bit value type. */
; S$ i7 |3 O6 b& d# Z* o- y" a 9typedef long int int4; /* Signed 32 bit value type. */2 x. Y! g- K7 U+ J4 N
10typedef signed long sint31; /* Signed 32 bit value */
" @# b, f# L  K11typedef signed short sint15; /* Signed 16 bit value */& n! c' Z+ U6 c
12typedef signed char sint7; /* Signed 8 bit value *// c, I2 [" m* w5 A
3. 得到指定地址上的一个字节或字1#define MEM_B( x ) ( *( (byte *) (x) ) )
6 r$ j& x4 {( {/ @2#define MEM_W( x ) ( *( (word *) (x) ) )9 ^1 I( L# m% T9 L
4. 求最大值和最小值1#define MAX( x, y ) ( ((x) > (y)) ? (x) : (y) )
1 u1 a, l! s; _! W. V6 }2 H- L2#define MIN( x, y ) ( ((x) < (y)) ? (x) : (y) )+ m( X$ s/ g2 j3 d' W
5. 得到一个field在结构体(struct)中的偏移量1#define FPOS( type, field ) \+ L: I/ r  S! ^
2/*lint -e545 */ ( (dword) &(( type *) 0)-> field ) /*lint +e545 */
  M1 T+ f/ X9 }! y! S( [& Y) ?" a. f
6. 得到一个结构体中field所占用的字节数1#define FSIZ( type, field ) sizeof( ((type *) 0)->field )+ T5 R# |  V# i1 w) r7 Z
7. 按照LSB格式把两个字节转化为一个Word1#define FLIPW( ray ) ( (((word) (ray)[0]) * 256) + (ray)[1] )
. n0 X% D, G1 P/ W: Q
8. 按照LSB格式把一个Word转化为两个字节1#define FLOPW( ray, val ) \
- }+ h$ H" b* j8 [4 w4 K2(ray)[0] = ((val) / 256); \9 C9 l1 V0 i- @, C- `! t
3(ray)[1] = ((val) & 0xFF)
2 G+ g" M5 G0 k. H0 m. F
9. 得到一个变量的地址(word宽度)1#define B_PTR( var ) ( (byte *) (void *) &(var) )
$ r! ?; @, T. o3 U) c3 U' x2#define W_PTR( var ) ( (word *) (void *) &(var) )
' z( M8 T4 S4 [' i2 N8 {/ Z
10. 得到一个字的高位和低位字节1#define WORD_LO(xxx) ((byte) ((word)(xxx) & 255)): d# @# r+ Q% w
2#define WORD_HI(xxx) ((byte) ((word)(xxx) >> 8))4 U- g% O4 T$ W, F! O# b# B) M* n
11. 返回一个比X大的最接近的8的倍数1#define RND8( x ) ((((x) + 7) / 8 ) * 8 )
# C* X9 f, n( {: ^. ^: z& Y
12. 将一个字母转换为大写1#define UPCASE( c ) ( ((c) >= 'a' && (c) <= 'z') ? ((c) - 0x20) : (c) )* }) U# [/ H) ~2 G# F' F; V% O
13. 判断字符是不是10进制的数字1#define DECCHK( c ) ((c) >= '0' && (c) <= '9')
, G' q3 _, O/ F6 r- p
14. 判断字符是不是16进制的数字1#define HEXCHK( c ) ( ((c) >= '0' && (c) <= '9') ||\: I, |% N# Y0 Z* Q0 j/ y
2((c) >= 'A' && (c) <= 'F') ||\8 h* c7 W% \0 p
3((c) >= 'a' && (c) <= 'f') )
7 Q* Y( T* R+ U# |5 j9 |
15. 防止溢出的一个方法1#define INC_SAT( val ) (val = ((val)+1 > (val)) ? (val)+1 : (val))
$ w7 s. j6 K/ \  p
16. 返回数组元素的个数1#define ARR_SIZE( a ) ( sizeof( (a) ) / sizeof( (a[0]) ) )
8 S4 a6 D8 ^9 s# n( Q
17. 返回一个无符号数n尾的值MOD_BY_POWER_OF_TWO(X,n)=X%(2^n)1#define MOD_BY_POWER_OF_TWO( val, mod_by ) \" l: z; L0 p+ V& ]- L
2( (dword)(val) & (dword)((mod_by)-1) )! s* ^4 h2 c3 H: c( s
18. 对于IO空间映射在存储空间的结构,输入输出处理1#define inp(port) (*((volatile byte *) (port)))
  y6 p9 Z- p9 F; f. J2#define inpw(port) (*((volatile word *) (port)))+ L/ K1 b+ s& d/ @# |
3#define inpdw(port) (*((volatile dword *)(port)))  K1 I2 p0 v5 {$ U, Y
4#define outp(port, val) (*((volatile byte *) (port)) = ((byte) (val)))1 {/ }- ?0 S& a" ?& U) ]$ W
5#define outpw(port, val) (*((volatile word *) (port)) = ((word) (val)))+ X) P, k6 {! V) {4 \
6#define outpdw(port, val) (*((volatile dword *) (port)) = ((dword) (val)))* d) ^. p, X9 q
19. 使用一些宏跟踪调试
A N S I标准说明了五个预定义的宏名。它们是:
1_ L I N E _
5 \8 M+ e/ p  y1 f& [* ]2_ F I L E _3 ~6 O$ j+ @4 f  E. F( Q$ c2 k! M
3_ D A T E _
7 v  s+ o4 w0 x+ u0 n; @4_ T I M E _3 Q5 p* u! I3 D" R
5_ S T D C _7 f( E* a" g% C
如果编译不是标准的,则可能仅支持以上宏名中的几个,或根本不支持。记住编译程序也许还提供其它预定义的宏名。
_ L I N E _及_ F I L E _宏指令在有关# l i n e的部分中已讨论,这里讨论其余的宏名。
_ D AT E _宏指令含有形式为月/日/年的串,表示源文件被翻译到代码时的日期。
源代码翻译到目标代码的时间作为串包含在_ T I M E _中。串形式为时:分:秒。
如果实现是标准的,则宏_ S T D C _含有十进制常量1。如果它含有任何其它数,则实现是非标准的。
可以定义宏,例如: 当定义了_DEBUG,输出数据信息和所在文件所在行
1#ifdef _DEBUG! C. R) M) f$ R
2#define DEBUGMSG(msg,date) printf(msg);printf(“%d%d%d”,date,_LINE_,_FILE_)
+ W5 B! u( k* J- F2 y5 H3#else
- N4 M' W+ F; b0 N. e4#define DEBUGMSG(msg,date)+ j& g. G& o0 l( b+ n% ?  H$ W
5#endif8 P* U6 d8 F3 y3 `
20. 宏定义防止使用时错误用小括号包含。
例如:
1#define ADD(a,b) (a+b)
  C7 z5 ]7 h% X2 ^
用do{}while(0)语句包含多语句防止错误
例如:
1#difne DO(a,b) a+b;\
; s2 k: P! C" P( a' H) \2a++;; ~' }: v6 E( D9 K7 T
应用时:
1if(….)! w' O- I" t4 i  u7 x( y# |: W2 m
2DO(a,b); //产生错误: E( o" W, [, T0 ]
3else5 ~4 L# v1 V3 h
解决方法:
1#difne DO(a,b) do{a+b;\' W4 S1 I; y  w. R. J1 R& y
2a++;}
while(0)
5 D% V/ f. U( }3 b3 N4 V
赞 收藏 评论3 发布时间:2021-1-12 13:49
3个回答
goyhuan 回答时间:2021-1-12 15:55:37
总结得很到位
sincomaster 回答时间:2021-1-13 00:04:46
谢谢分享
kylixyao 回答时间:2021-1-14 17:51:30
比较实用
