写好C语言,漂亮的宏定义很重要,使用宏定义可以防止出错,提高可移植性,可读性,方便性等等。下面列举一些成熟软件中常用的宏定义。1. 防止一个头文件被重复包含1#ifndef COMDEF_H 2#define COMDEF_H 3//头文件内容 4#endif 2. 重新定义一些类型,防止由于各种平台和编译器的不同,而产生的类型字节数差异,方便移植。1typedef unsigned char boolean; /* Boolean value type. */ 2typedef unsigned long int uint32; /* Unsigned 32 bit value */! S3 T4 j( v: l9 r" L+ n9 _ 3typedef unsigned short uint16; /* Unsigned 16 bit value */ 4typedef unsigned char uint8; /* Unsigned 8 bit value */ 5typedef signed long int int32; /* Signed 32 bit value */' u- b3 W7 E: r) I Y( L% {+ U! l 6typedef signed short int16; /* Signed 16 bit value */: a, p+ [6 C7 r 7typedef signed char int8; /* Signed 8 bit value */0 F. T: {/ Z0 N5 P3 ]6 c4 s 下面的不建议使用 1typedef unsigned char byte; /* Unsigned 8 bit value type. */2typedef unsigned short word; /* Unsinged 16 bit value type. */ 3typedef unsigned long dword; /* Unsigned 32 bit value type. */$ [9 h3 f. w9 d! w$ G 4typedef unsigned char uint1; /* Unsigned 8 bit value type. *// a/ y% b/ V8 J 5typedef unsigned short uint2; /* Unsigned 16 bit value type. */ z5 @9 w5 ?/ t3 P0 `1 W$ j" ^1 w3 x 6typedef unsigned long uint4; /* Unsigned 32 bit value type. */ U' \8 x2 |8 }0 y 7typedef signed char int1; /* Signed 8 bit value type. */ 8typedef signed short int2; /* Signed 16 bit value type. */ 9typedef long int int4; /* Signed 32 bit value type. */ 10typedef signed long sint31; /* Signed 32 bit value */0 C! f7 ^8 C! n7 r+ f" w- n% c 11typedef signed short sint15; /* Signed 16 bit value */6 q; Z1 x2 X! }: Y 12typedef signed char sint7; /* Signed 8 bit value */ 3. 得到指定地址上的一个字节或字1#define MEM_B( x ) ( *( (byte *) (x) ) )* _. R& A. W$ ?8 `" E) c 2#define MEM_W( x ) ( *( (word *) (x) ) ) 4. 求最大值和最小值1#define MAX( x, y ) ( ((x) > (y)) ? (x) : (y) ) 2#define MIN( x, y ) ( ((x) < (y)) ? (x) : (y) ) 5. 得到一个field在结构体(struct)中的偏移量1#define FPOS( type, field ) \ 2/*lint -e545 */ ( (dword) &(( type *) 0)-> field ) /*lint +e545 */ 6. 得到一个结构体中field所占用的字节数1#define FSIZ( type, field ) sizeof( ((type *) 0)->field )9 R) X5 ~% _7 n/ c 7. 按照LSB格式把两个字节转化为一个Word1#define FLIPW( ray ) ( (((word) (ray)[0]) * 256) + (ray)[1] )1 E8 [( z1 }0 ^; h! B! n 8. 按照LSB格式把一个Word转化为两个字节1#define FLOPW( ray, val ) \ 2(ray)[0] = ((val) / 256); \: d* P0 E( |* q 3(ray)[1] = ((val) & 0xFF) 9. 得到一个变量的地址(word宽度)1#define B_PTR( var ) ( (byte *) (void *) &(var) )* g' m0 r7 z* o 2#define W_PTR( var ) ( (word *) (void *) &(var) )* x! [* p+ C2 b4 D3 ?1 Y! m# d 10. 得到一个字的高位和低位字节1#define WORD_LO(xxx) ((byte) ((word)(xxx) & 255)) 2#define WORD_HI(xxx) ((byte) ((word)(xxx) >> 8)); h6 `; ]5 u9 F9 ?1 X7 E 11. 返回一个比X大的最接近的8的倍数1#define RND8( x ) ((((x) + 7) / 8 ) * 8 )2 Q% i7 k% T" n4 i. T7 D; S' a3 [8 {, g 12. 将一个字母转换为大写1#define UPCASE( c ) ( ((c) >= 'a' && (c) <= 'z') ? ((c) - 0x20) : (c) )% G. W9 X) a9 D# a+ a 13. 判断字符是不是10进制的数字1#define DECCHK( c ) ((c) >= '0' && (c) <= '9') 14. 判断字符是不是16进制的数字1#define HEXCHK( c ) ( ((c) >= '0' && (c) <= '9') ||\6 {/ P4 P# z" Q0 Z C$ t$ y6 I 2((c) >= 'A' && (c) <= 'F') ||\ 3((c) >= 'a' && (c) <= 'f') )( w9 C; W% Z$ z% ^8 s 15. 防止溢出的一个方法1#define INC_SAT( val ) (val = ((val)+1 > (val)) ? (val)+1 : (val))3 x6 h0 \1 {* \# }# z 16. 返回数组元素的个数1#define ARR_SIZE( a ) ( sizeof( (a) ) / sizeof( (a[0]) ) ) 17. 返回一个无符号数n尾的值MOD_BY_POWER_OF_TWO(X,n)=X%(2^n)1#define MOD_BY_POWER_OF_TWO( val, mod_by ) \2 z0 e9 |$ a/ \" M( D( U" r 2( (dword)(val) & (dword)((mod_by)-1) ) 18. 对于IO空间映射在存储空间的结构,输入输出处理1#define inp(port) (*((volatile byte *) (port))) 2#define inpw(port) (*((volatile word *) (port))) 3#define inpdw(port) (*((volatile dword *)(port))) 4#define outp(port, val) (*((volatile byte *) (port)) = ((byte) (val)))9 ^- z# S( y3 | F2 A 5#define outpw(port, val) (*((volatile word *) (port)) = ((word) (val)))' f+ w' X5 K* y& ^ 6#define outpdw(port, val) (*((volatile dword *) (port)) = ((dword) (val)))" F2 j2 |" L5 P9 D8 H. S! g# J 19. 使用一些宏跟踪调试 A N S I标准说明了五个预定义的宏名。它们是: 1_ L I N E _2_ F I L E _# ^+ V* i" q' ^. z2 l9 S8 Z/ W 3_ D A T E _4 ]& c+ h) d% \) z6 N6 h" ] 4_ T I M E _ 5_ S T D C _, Q' b0 h3 s/ C( O1 D9 } 如果编译不是标准的,则可能仅支持以上宏名中的几个,或根本不支持。记住编译程序也许还提供其它预定义的宏名。 _ L I N E _及_ F I L E _宏指令在有关# l i n e的部分中已讨论,这里讨论其余的宏名。 _ D AT E _宏指令含有形式为月/日/年的串,表示源文件被翻译到代码时的日期。 源代码翻译到目标代码的时间作为串包含在_ T I M E _中。串形式为时:分:秒。 如果实现是标准的,则宏_ S T D C _含有十进制常量1。如果它含有任何其它数,则实现是非标准的。 可以定义宏,例如: 当定义了_DEBUG,输出数据信息和所在文件所在行 1#ifdef _DEBUG) J# x% i4 z, t" B2#define DEBUGMSG(msg,date) printf(msg);printf(“%d%d%d”,date,_LINE_,_FILE_) 3#else; R8 E7 W5 a) Q2 R 4#define DEBUGMSG(msg,date)# R; T: G) I7 R) b" F1 g2 P 5#endif: @3 I4 ?6 n- C' ^" o6 T. p9 r 20. 宏定义防止使用时错误用小括号包含。 例如: 1#define ADD(a,b) (a+b)用do{}while(0)语句包含多语句防止错误 例如: 1#difne DO(a,b) a+b;\2a++; 应用时: 1if(….)9 a1 t! o1 x1 M6 t2DO(a,b); //产生错误" ?) A7 L" e8 M) \- l" r 3else }: f$ c- Y' ~- A% c; D5 D9 O 解决方法: 1#difne DO(a,b) do{a+b;\, \- S* q- p( f5 [: `9 p6 i! @2a++;}while(0)6 a: K/ t* M# f! X" m |
