《STM32F030x4x6x8xC勘误手册》中DMA部分如下描述,最后一句解决方案什么意思呢? Workaround The only way to lock GPIOx_OTYPER with i=15..8 is to lock also GPIOx_OTYPER[i-8]. 勘误手册描述: 2.3 DMA 2.3.1 DMA disable failure and error flag omission upon simultaneous transfer error and global flag clear Description Upon a data transfer error in a DMA channel x, both the specific TEIFx and the global GIFx flags are raised and the channel x is normally automatically disabled. However, if in the same clock cycle the software clears the GIFx flag (by setting the CGIFx bit of the _IFCR register), the automatic channel disable fails and the TEIFx flag is not raised. This issue does not occur with ST's HAL software that does not use and clear the GIFx flag, but uses and clears the HTIFx, TCIFx, and TEIFx specific event flags instead. Workaround The only way to lock GPIOx_OTYPER with i=15..8 is to lock also GPIOx_OTYPER[i-8]. |
勘误手册写错了,将上文对GPIO的内容写到了DMA;猜测DMA解决办法这里,只需要清除相对应的标志就行。 |
DMAMUX 使用内部外设Request Event(不使用TIM12和LPTIM)
DMA传输完成后,串口与DMA一直处于忙状态
STM32F407VET6 能适配哪些FATFS版本文件
STM32H7A3VGTA QSPI读W25Q128J DMA模式不能工作
//STM32H7A3VGT6 QSPI的DMA方式无法正常工作
HAL_TIM_IC_Start_DMA的回调函数是HAL_TIM_IC_CaptureCpltCallback吗?为什么进不去?
STM32G473RC timer8的CCDS bit, Capture/Compare DMA selection.
STM32H7+SAI+DMA双缓冲配置失败.
利用stm32f412 的SPI 的DMA 模式读取外部ADC数据如何提高效率
FW_H7 V1.12.1-HAL库DMA双缓冲配置
