流程图如下:
8 c$ J! h4 w) i; v. `$ C4 s
| ) Y- i2 S% X2 C9 I
| RE:STM32 I2C 硬件中断方式实现方法,带流程图
+ F" q1 T4 l2 J2 ?
6 s9 I! X( Z9 W* eI2C 中断处理函数如下:2 R7 U5 t, z% y4 G
- <table class="t_table"><tbody><tr><td><div align="center"><table class="t_table"><tbody><tr><td>/**3 v4 t+ S* F' O! m
- * @brief This function handles I2C1 Event interrupt request, tx, rx, d' r. z- A& n5 w0 t% G
- * buffer and number of bytes will be changed.
0 J! z7 E4 j, S$ X6 ~. X2 M& ?) \ - * @param None
9 x) H) e5 k6 d* g7 {# ] - * @retval None" d- b) d4 o7 ?, L# T/ s: W
, i8 J9 ~. Y' j d. M - void I2C1_EV_IRQHandler(void)
4 ?; M" P: q' S - {
, ~1 |7 y4 f: u+ q N9 r4 D/ n - #ifdef ARC_I2C_IRQ
3 \7 m% ^+ c) ~3 u5 R; ~ - uint32_t i2cEvent;
2 X1 g3 E/ Y& ?1 ~' }6 v - I2C_param_struct __IO *pI2C_param;
4 l3 K7 y7 J7 ~ V+ | - . d) a) a5 _6 Z) {* T- [$ o
- pI2C_param = ARC_get_I2C_param();
* s5 r r5 G# @, \7 P, U - i2cEvent = I2C_GetLastEvent(I2C1);) w* E" T! U! S9 E
0 R7 |/ k( q Y# v - switch (i2cEvent)
4 ?! }' \# p( y5 h - {, h8 k7 { u& R; u* z. {
- case I2C_EVENT_MASTER_MODE_SELECT:/* EV5 */
- q' m$ ^, m" x - if(pI2C_param->I2C_DIRECTION == ARC_I2C_DIRECTION_TX); j4 {0 v) f2 }
- {" h9 N7 N9 U" A2 x8 H
- I2C_Send7bitAddress(I2C1, pI2C_param->DeviceAddr, I2C_Direction_Transmitter);* K! j( B% V" ]5 f9 k+ M/ X. W/ f
1 @6 Z6 c R9 Z5 x q% D: U2 K6 Q - else |, h0 o4 y9 h3 L" \8 A# S; G" c
- {4 l+ Y2 k3 R* @- @
- I2C_Send7bitAddress(I2C1, pI2C_param->DeviceAddr, I2C_Direction_Receiver);1 y5 N) S! }- M( Y5 l
" c9 J! u/ _! t - break;# N# j6 F k) J9 x5 r% h
7 N- u# D3 `* D9 T* M" \" F- /* Master Transmitter -------------------------------------------------------*// Z) N1 f# q9 ]9 I# ]$ k. W# U
- case I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED:
! [: W0 l2 h$ S9 F - I2C_SendData(I2C1, pI2C_param->SubAddr);
7 F8 n* H1 ?% W; v - if(pI2C_param->TxNumOfBytes == 0)
3 \ s# i" W) \3 ^% p3 `, m - I2C_ITConfig(I2C1, I2C_IT_BUF, DISABLE);
0 p& u1 p2 y/ w9 `. N) V - break;9 M9 H+ v) w( c. A/ I6 e7 \
0 ]) \+ ^$ ^& x& m C! U - case I2C_EVENT_MASTER_BYTE_TRANSMITTING: /* Without BTF, EV8 */
/ ~$ P6 M( k9 i4 z* ? - if(pI2C_param->TX_I2C_Index < pI2C_param->TxNumOfBytes)
7 L! w+ y; a+ g: H# e - {
- z' ?, u/ E1 |" M V - I2C_SendData(I2C1, pI2C_param->TxData[pI2C_param->TX_I2C_Index++]);- Y7 b0 i' W/ W
8 N! F% p2 [7 `! k. Y9 \% q8 I - else
! |1 e8 U5 g7 ~# ~& S( b: R - { " L1 K5 U3 s. ?2 l2 ], ?
2 C4 B- t5 o: Y r$ e' K - }: \$ S( `, T1 M/ v% E% s% K
- break;
+ S2 ^. \) r2 D; Y9 m3 O3 l% Y4 \ - , V# a4 l% t4 x
- case I2C_EVENT_MASTER_BYTE_TRANSMITTED: /* With BTF EV8-2 */
3 r2 ^! T1 a# e - if(pI2C_param->TX_Generate_stop == 1); j5 G( }1 Z, @/ |8 G
- {: C ~4 e5 I: T2 }2 O
- I2C_GenerateSTOP(I2C1, ENABLE); ^% b+ E6 C2 y' G
- I2C_ITConfig(I2C1, I2C_IT_EVT, DISABLE);3 ?# _/ B2 a! L. a. o% n
/ J3 o/ G$ {) A4 G9 s# u& ` - else
+ v8 u8 r0 }* y* [9 M S - {
9 A9 H& u7 n1 V) B7 M* O2 S- k4 _, F- A - pI2C_param->I2C_DIRECTION = ARC_I2C_DIRECTION_RX;; w! v% A8 k. }! A
- I2C_ITConfig(I2C1, I2C_IT_BUF, ENABLE);0 `1 g5 {9 E3 `7 T8 A
- I2C_GenerateSTART(I2C1, ENABLE);
* J# a2 ~* C8 M4 J! L" I4 Q - }; j9 E2 |9 H- O, f4 d( d6 o: q
- break;4 X& i. q1 _" R& j* h+ y8 X
' E$ `% b% w# Q5 v+ _- /* Master Receiver -------------------------------------------------------*/
: c, H" ~7 s3 ]0 I' Q, W" s1 \ - case I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED:
& b2 r& G; K, g& B1 T - if(pI2C_param->RX_I2C_Index == (pI2C_param->RxNumOfBytes - 1))- @) A1 e7 _7 }9 m! v+ q
- {2 f0 g4 r: [2 O
- I2C_AcknowledgeConfig(I2C1, DISABLE);
8 ?5 y6 O! X5 _7 g7 r4 A' E+ ? - I2C_GenerateSTOP(I2C1, ENABLE);) X# C0 ~6 W9 {/ a3 h3 C7 r
- }# B# |; |# _* ~) K' ^ M
- break;: {9 {6 f& p# g3 q2 M
- 8 c9 M8 L( N+ y( {) {3 y
- case I2C_EVENT_MASTER_BYTE_RECEIVED:
; T, y% _3 c2 V) K8 |" z - pI2C_param->RxData[pI2C_param->RX_I2C_Index++] = I2C_ReceiveData (I2C1);# c8 p4 X9 w/ ?7 ^
+ T' N; K! m. r' A0 J: r, W( ? - {
m6 M( n0 x- B7 M; |- \ - I2C_AcknowledgeConfig(I2C1, DISABLE);) ]( ~0 b3 f( z' q5 m0 t
- I2C_GenerateSTOP(I2C1, ENABLE);2 s: d, c4 L2 ]& a$ n( {! s
- }2 `0 ]1 i, t- J% F& L
- break;* F3 `. u* D! I6 S
: F* }* `% V! u& m4 {+ y* [- default:( V! \4 ?9 j" ?: T( N, ~
- break;/ t. d- N8 L0 _- I& |2 C# k) r
; f+ Z& D- M( r( l6 w
4 J( w7 m/ W% f- #endif
2 J$ c9 R1 _/ j, m6 N2 i. V& o - }</td></tr></tbody></table></div></td></tr></tbody></table>
1 z8 T5 Z. O/ i* R, o) d' @" p1 P |
