编译错误 Error: L6218E:
mecca7aa 提问时间:2022-3-1 21:39 / 未解决
照着野火的教学视频编写了一个基本定时器的函数,其中用到的中断服务函数的子程序STM32f10x_it.c
结果编译有错误..\Output\Basic[ti](https://bbs.elecfans.com/zhuti_715_1.html)m.axf: Error: L6218E: Undefined symbol time (referred from stm32f10x_it.o).
意思是STM32f10x_it.c中变量time没有定义,但是我在这段程序的一开头就已经定义了time变量,见下面蓝色字体。
是在不知道怎么办了,请教一下各位大神
中断程序如下
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x_it.h"
#include "bsp_[LED](https://www.hqchip.com/app/957).h"
#include "bsp_exti.h"
#include "stm32f10x.h"
#include "bsp_usart.h"
#include "bsp_adc.h"
#include "stm32f10x_tim.h"
#include "bsp_BasicTim.h"
int8_t ucTemp;
extern uint16_t time;
extern uint16_t ADC_conversionValue;
/** @addtogroup Template_Project
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
/*            Cortex-M3 Processor Exceptions Handlers                         */
* @brief  This function handles NMI exception.
* @param  None
* @retval : None
  void NMI_Handler(void)
* @brief  This function handles Hard Fault exception.
* @param  None
* @retval : None
  void HardFault_Handler(void)
  /* Go to infinite loop when Hard Fault exception occurs */
  while (1)
* @brief  This function handles Memory Manage exception.
* @param  None
* @retval : None
  void MemManage_Handler(void)
  /* Go to infinite loop when Memory Manage exception occurs */
  while (1)
* @brief  This function handles Bus Fault exception.
* @param  None
* @retval : None
  void BusFault_Handler(void)
  /* Go to infinite loop when Bus Fault exception occurs */
  while (1)
* @brief  This function handles Usage Fault exception.
* @param  None
* @retval : None
  void UsageFault_Handler(void)
  /* Go to infinite loop when Usage Fault exception occurs */
  while (1)
* @brief  This function handles SVCall exception.
* @param  None
* @retval : None
  void SVC_Handler(void)
* @brief  This function handles [debug](https://www.elecfans.com/tags/DEBUG/) Monitor exception.
* @param  None
* @retval : None
  void DebugMon_Handler(void)
* @brief  This function handles PendSVC exception.
* @param  None
* @retval : None
  void PendSV_Handler(void)
* @brief  This function handles SysTick Handler.
* @param  None
* @retval : None
  void SysTick_Handler(void)
//串口中断服务函数
void DEBUG_USART_IRQHandler(void)
if(USART_GetITStatus(DEBUG_USARTx, USART_FLAG_RXNE)==RESET)
//也可以换成        if(USART_GetITStatus(DEBUG_USARTx, USART_IT_RXNE)!=RESET)
ucTemp = USART_ReceiveData(DEBUG_USARTx);
USART_SendData(DEBUG_USARTx, ucTemp);
//一.独立模式ADC,中断服务函数读取程序
void ADC_IRQHandler(void)
if(ADC_GetITStatus(ADC_x, ADC_IT_EOC) == SET)
ADC_conversionValue = ADC_GetConversionValue(ADC_x);
ADC_ClearITPendingBit(ADC_x, ADC_IT_EOC);
//基本定时器中断服务函数
void BASIC_TIM_IRQHandler(void)
//判断更新中断是否发生
if(TIM_GetITStatus(BASIC_TIM,TIM_IT_Update) != RESET)
time++;
//清除中断标志位
TIM_ClearITPendingBit(BASIC_TIM,TIM_IT_Update);
/*                 STM32F10x Peripherals Interrupt Handlers                   */
/*  Add here the Interrupt Handler for the used peripheral(s) (PPP), for the  */
/*  available peripheral interrupt handler's name please refer to the startup */
/*  file (startup_stm32f10x_xx.s).                                            */
* @brief  This function handles PPP interrupt request.
* @param  None
* @retval : None
  void EXTI4_IRQHandler(void)
  //判断是否进入中断
  if(EXTI_GetFlagStatus(EXTI_Line4)!=RESET)
  //中断服务程序
  LED_G_TOGGLE;
  //执行中断服务函数完毕后,清除中断标志位
  EXTI_ClearITPendingBit(EXTI_Line4);
/******************* (C) COPYRIGHT 2009 STMicroelectronics *****END OF FILE****/
收藏 评论1 发布时间:2022-3-1 21:39
废鱼 回答时间:2022-3-3 14:41:17
extern uint16_t time和uint16_t time不同的,前者只是全局声明,后者是定义。只需要再main.c中定义一个uint16_t time;即可。
