【经验分享】利用STM32F103的高级定时器产生三路互补PWM波形,占空比可调,带死区
STMCU小助手 发布时间:2022-4-21 21:00
, V: l) |3 q2 k- W% R: g7 J
  1. void timer_init(void)4 I& ^7 q; Y" ?) F9 `3 i
  2. {8 D# Z+ C- @* I) `
  3.         GPIO_InitTypeDef  GPIO_InitStructure;
    ) Y; L+ ]. O; {% B- K5 ~
  4.         TIM_TimeBaseInitTypeDef TIM_BaseInitStructure;
    5 B" ~. H5 n8 Z
  5.         TIM_OCInitTypeDef TIM_OCInitStructure;
    , N" M% v$ T9 D- ]$ _. W" N$ Z
  6.         TIM_BDTRInitTypeDef TIM_BDTRInitStructure;
    . W( i0 f5 p8 Z+ N
  7.
    5 Z4 [- D3 g3 m: p6 [2 l% k0 L
  8.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOD,ENABLE);- H" A$ S# t( W7 @# `
  9.         * J( D$ q6 M- j+ c1 a/ x
  10.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);
    6 ~4 I9 q0 o- p  v
  11.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1,ENABLE);
    . W* F8 t9 p( z! n2 h% |! [
  12.         0 W' L+ R, C2 D( b- t* k* V. h( l
  13.         ! \9 `6 l$ B! Y- J6 M4 y6 w
  14.         GPIO_InitStructure.GPIO_Pin=GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10;
    & G; a  `; T7 P; h
  15.         GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;* {3 z6 C+ D3 R
  16.         GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
    & x, w5 G. j5 H- |
  17.         GPIO_Init(GPIOA,&GPIO_InitStructure);* c) W, R& G* }8 f
  18.
    ; t2 E; T" ^- `% N2 Y/ `
  19.
    0 G, Q- }! _) S& C! x
  20.         GPIO_InitStructure.GPIO_Pin=GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;5 B7 t- T; q7 y4 ]$ U4 v
  21.         GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;
    8 L9 `/ |5 L( V9 M9 S
  22.         GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
      o( B& O$ R4 N2 s
  23.         GPIO_Init(GPIOB,&GPIO_InitStructure);
    / p% F  `: h9 e7 f3 ^$ y* M
  24.
    4 H5 h4 t( f3 _: ^! M
  25.         TIM_BaseInitStructure.TIM_Period=1000-1;
    , X* i* W3 a. ~
  26.         TIM_BaseInitStructure.TIM_Prescaler=72-1;5 n( v7 d$ L; d& P
  27.         TIM_BaseInitStructure.TIM_ClockDivision=0;
    8 p6 M5 g5 F  V2 {# m9 P
  28.         TIM_BaseInitStructure.TIM_CounterMode=TIM_CounterMode_Up;
    " @+ D) w- n1 z; ~8 ]+ |' h
  29.         TIM_BaseInitStructure.TIM_RepetitionCounter=0;
    2 \$ a* P8 G7 _- ]/ v5 a( X
  30.         TIM_TimeBaseInit(TIM1,&TIM_BaseInitStructure);//启用ARR的影子寄存器(直到产生更新事件才更改设置) TIM_ARRPreloadConfig(TIM1,?ENABLE);
    ) ~5 C0 t: F: \5 b1 L
  31.
    ' O8 C0 ?0 c4 a+ o+ p$ h; d' |  F: P
  32.         //TIM1_OC1模块设置(设置1通道占空比)
    ! W/ J& q0 }: S
  33.         TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
    $ g- W0 v6 ~. X2 [5 ]  J* A* K
  34.         TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;9 C. H% |# Z7 J6 H* d* o9 Q
  35.         TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;3 Q4 e. e; d9 u5 q0 p
  36.         TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;- l! F& p  T/ c9 |
  37.         TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;- m7 K: v, ^' f
  38.         TIM_OCInitStructure.TIM_Pulse = 120;//TIM1_Pulse设置了待装入捕获比较寄存器的脉冲值  % h9 X+ X( S$ {4 R
  39.
    " Q/ T" u! q' U( q2 f) W3 q4 [  h( U/ P
  40.         TIM_OC1Init(TIM1,&TIM_OCInitStructure);  //启用CCR1寄存器的影子寄存器(直到产生更新事件才更改设置)
    : p& p* _4 P" Z7 A4 b
  41.         TIM_OC1PreloadConfig(TIM1,TIM_OCPreload_Enable);0 U1 o) R; i2 y
  42. , F- @# d/ \6 e& P" }; ]) S; q4 G& B3 l
  43. ' K6 m& D9 j2 }
  44.         //TIM1_OC2模块设置(设置2通道占空比)1 o1 t3 h/ _. _1 Z; B7 F! `5 _  w
  45. 7 @; R. P% J6 S1 \, k1 b
  46.         TIM_OC2Init(TIM1, &TIM_OCInitStructure); //启用CCR2寄存器的影子寄存器(直到产生更新事件才更改设置)
    ( K; f' Q! Y4 f' C$ M/ A7 w
  47.         TIM_OC2PreloadConfig(TIM1, TIM_OCPreload_Enable); 6 V' x6 G3 m3 \  r$ n
  48. + ~- h& J2 C4 \% x) ^+ c
  49.         //TIM1_OC3模块设置(设置3通道占空比)
    : p: {4 G, D( ]# S% s9 h
  50. / `4 ^* f7 Y( D5 a
  51.         TIM_OC3Init(TIM1, &TIM_OCInitStructure); //启用CCR2寄存器的影子寄存器(直到产生更新事件才更改设置)) e; N' }  ^! r- P3 @2 C4 c
  52.         TIM_OC3PreloadConfig(TIM1, TIM_OCPreload_Enable);
    , {/ m9 M) T( ?2 ]5 O$ h9 ^
  53.         //死区设置
    7 d2 V& J( R8 U, B  H
  54.         TIM_BDTRInitStructure.TIM_OSSRState = TIM_OSSRState_Enable;
    0 r- B; E* J! j: L9 F; \
  55.         TIM_BDTRInitStructure.TIM_OSSIState = TIM_OSSIState_Enable;
    ; F5 `6 T! g; {& N8 S7 P" O4 S
  56.         TIM_BDTRInitStructure.TIM_LOCKLevel = TIM_LOCKLevel_OFF;  v' ]2 E7 c  `2 `3 N: }: l
  57.         TIM_BDTRInitStructure.TIM_DeadTime = 0x90; //这里调整死区大小0-0xff" r. s2 p" N+ E& ~
  58.         TIM_BDTRInitStructure.TIM_Break = TIM_Break_Disable;# g7 n3 w0 Z, K, @' {/ l
  59.         TIM_BDTRInitStructure.TIM_BreakPolarity = TIM_BreakPolarity_High;; N5 o% B, B( H- R
  60.         TIM_BDTRInitStructure.TIM_AutomaticOutput = TIM_AutomaticOutput_Enable;
    8 L2 b5 o2 f$ ^) R
  61.         TIM_BDTRConfig(TIM1, &TIM_BDTRInitStructure);
    5 J9 u& v) L0 ^8 Z  Z; I; G
  62.
    1 n. `3 g# W: i0 t: X
  63.         //TIM1开启
    / l7 r6 a' [; v2 P- v; Q2 W& z
  64.         TIM_Cmd(TIM1, ENABLE);& e+ z, }0 w$ e& Q5 R& z) O
  65.         //TIM1_OC通道输出PWM(一定要加)
    6 D* L/ j. ~! D
  66.         TIM_CtrlPWMOutputs(TIM1, ENABLE);5 H  z/ K9 V/ i- ^
  67.         6 h! J) \( W$ Z& l' G
  68.         9 ]' U% D4 s- S2 b$ A6 p/ e
  69. }& H( U# {2 d: j$ B& I3 J
  70. & [6 D0 |$ ]9 e3 G7 _
  71. ' k! F  `9 K8 f
  72. 3 x0 k  t1 Y0 U: u) w+ c
) J* I9 b4 h: v$ T
赞 收藏 评论0 发布时间:2022-4-21 21:00
