#include"main.h" const uint32_t SEG_SegPins[]= { GPIO_PIN_0,GPIO_PIN_1,GPIO_PIN_2,GPIO_PIN_3,GPIO_PIN_4,GPIO_PIN_5,GPIO_PIN_6,GPIO_PIN_7, }; const uint32_t SEG_DigPins[]= { GPIO_PIN_8,GPIO_PIN_9,GPIO_PIN_10,GPIO_PIN_11, }; void Seg_Init(void); void Seg_DisplaySingleDigit(uint8_t n); void Seg_DynamicScan(uint8_t n1,uint8_t n2,uint8_t n3,uint8_t n4); int main(void) { uint32_t tsStart; uint32_t counter=0; uint8_t n1,n2,n3,n4; HAL_Init(); Seg_Init(); while(1) { tsStart=HAL_GetTick(); n1=(counter/1000)%10; n2=(counter/100)%10; n3=(counter/10)%10; n4=counter%10; while(HAL_GetTick()-tsStart >=1000) { Seg_DynamicScan(n1,n2,n3,n4); } counter++; } } void Seg_Init(void) { GPIO_InitTypeDef gpioinit; uint32_t i; //1.初始化数码管的段选引脚 gpioinit.Mode=GPIO_MODE_OUTPUT_PP; gpioinit.Speed=GPIO_SPEED_FREQ_LOW; __HAL_RCC_GPIOA_CLK_ENABLE(); for(i=0;i<8;i++) { gpioinit.Pin=SEG_SegPins[i]; HAL_GPIO_WritePin(GPIOA,SEG_SegPins[i],GPIO_PIN_RESET); HAL_GPIO_Init(GPIOA,&gpioinit); } //2.初始化数码管的位选引脚 gpioinit.Mode=GPIO_MODE_OUTPUT_PP; gpioinit.Speed=GPIO_SPEED_FREQ_LOW; __HAL_RCC_GPIOA_CLK_ENABLE(); for(i=0;i<4;i++) { gpioinit.Pin=SEG_DigPins[i]; HAL_GPIO_WritePin(GPIOA,SEG_DigPins[i],GPIO_PIN_SET); HAL_GPIO_Init(GPIOA,&gpioinit); } } void Seg_DisplaySingleDigit(uint8_t n) { const uint8_t font[]= { 0x3f,0x06,0x5B,0x4F,0x66,0x6D,0X7D,0X07,0X7F,0X6F }; uint32_t i; for(i=0;i<8;i++) { if((font[n] & (0x1 << i))!=0) { HAL_GPIO_WritePin(GPIOA,SEG_SegPins [i],GPIO_PIN_SET); } else { HAL_GPIO_WritePin(GPIOA,SEG_SegPins [i],GPIO_PIN_RESET); } } } void Seg_DynamicScan(uint8_t n1,uint8_t n2,uint8_t n3,uint8_t n4) { uint32_t i, j; uint8_t numbers[4]; numbers[0]=n1; numbers[1]=n2; numbers[2]=n3; numbers[3]=n4; for(i=0;i<4;i++) { for(j=0;j<4;j++) { HAL_GPIO_WritePin(GPIOA,SEG_DigPins[j],GPIO_PIN_SET); } Seg_DisplaySingleDigit(numbers[i]); HAL_GPIO_WritePin(GPIOA,SEG_DigPins[i],GPIO_PIN_RESET); HAL_Delay(10); } } |
简单平稳过度-回顾2025&说说我心中的ST中文论坛
Error in final launch sequence: Failed to execute MI command: target remote localhost:61234
基于STM32F103的HAL库实现USB(HID) OTA升级
STM32F103C8T6单片机通过PA4、PA5、PB10、PB11接口与单个74HC595D连接,然后通过CAN发报0x87,74HC595D输出脚Q1和Q5是常高电平,但连接多个74HC595D时,Q1和Q5波形不正常,为什么会出现方波?
STM32的内部Flash操作是不是优先级最高?
cudeide执行run是烧录还是只是执行呢
STM32 GPIO 开漏,NMOS 导通能承受多大电流
L9663驱动开发
如何鉴别芯片的进口版本和国产版本
cubeIDE在run后出现错误
共阴的,所有的比划都点亮了是正常的,A0-A7接的8个段选引脚。A8-A11接的4个位选引脚。
所有的比划都点亮了是正常的,A0-A7接的8个段选引脚。A8-A11接的4个位选引脚。共阴的。
延时那部分检查下。
能帮检查指导下吗?我检查了好几遍没有发现问题
n3=(counter/10)%10;
n4=counter%10;
counter++;
红色部分能执行??????
先获取滴答定时器当前的时间是多少多少毫秒减去一刚开头记时的时间,如果这两个时间的差值大于1000的话。也就表示我刚开始计时到本次的时候,时间已经过去了1s。然后等完一秒后,我的counter自动加1。while循环里面就是用来做的刷新。
