使用Platformio平台的libopencm3开发框架来开发STM32G0,下面使用PWM来实现LED呼吸灯效果。 3 E/ c; H2 ?/ D/ ~$ Z+ ^' }
1 新建项目在PIO主页新建项目pwm,框架选择libopencm3,开发板选择 MonkeyPi_STM32_G070RB; 新建完成后在src目录新建主程序文件main.c; 然后更改项目文件platformio.ini的烧写和调试方式: % b6 T, w1 O. _5 r. t
- 1upload_protocol = cmsis-dap
9 T8 d% R3 i& e1 L - 2debug_tool = cmsis-dap
\1 [6 [* N& J/ |. ~& ~; I1 `2 PWM配置GPIO设置为复用PWM输出
: a' D' w( n2 C
- 1/**- t+ P* P8 h2 P8 l% O9 e( e
- 2 * @brief gpio config 5 O" C R8 T! H: l2 l- _
- 3 *
, {+ @' Y% e: [) Z& g8 ~ - 4 */
7 p/ t, Y' Z) @ - 5static void gpio_setup(void)/ ]) W3 q" E* \6 W1 W0 G! i
- 6{4 M4 `. X5 ?- i
- 7 rcc_periph_clock_enable(RCC_GPIOC);
$ }6 o6 Y o% c9 z - 8' |2 I0 P, p3 \+ h( t& H& a0 P
- 9 gpio_mode_setup(GPIOC,. ]7 L* }$ D( }5 C
- 10 GPIO_MODE_AF,
$ u. w2 _0 |7 z - 11 GPIO_PUPD_NONE,
' ]8 U# P! a3 p, L+ `# { - 12 GPIO12);3 ?; U9 O, l5 e& T
- 13
8 m2 `1 F8 C, @ - 14 gpio_set_output_options(GPIOC,GPIO_OTYPE_PP,GPIO_OSPEED_50MHZ,GPIO12);
( C2 l9 N. E- R6 V) R& M - 15
. h$ L5 |. r& m' J5 e: s0 t, y0 \ - 16 //TIM14_CH1 , AF2
" U4 |! Z* N) T( w( f% ]- U- M1 Z; ?4 V - 17 gpio_set_af(GPIOC,GPIO_AF2,GPIO12);$ y6 D# T+ E! q4 l# N$ s. t) m% ?9 X
- 18}
复制代码 9 u1 F% g" a1 p
, s$ h" A- X3 c7 ?8 F" Y- |PWM配置 : V/ y G, M3 r2 E% M
- 1/**
* C" R. ]6 k$ }, y( I) C - 2 * @brief pwm channel setup
! y* \/ c A i - 3 * ; K7 `! d8 T! b. g3 I( v a
- 4 */
4 @ @+ p4 C0 d" V+ s# M4 {2 y - 5static void pwm_setup(void)7 q1 P: P" ~: V2 G( ~* i
- 6{
0 e4 \# q( S/ u3 F - 7 rcc_periph_clock_enable(RCC_TIM14);
- L! d8 N- @* C5 L/ I% L - 8. X% J% M6 }& r
- 9 /* Timer global mode:
3 |. p' J3 I; Z5 G8 r" u# C - 10 * - No divider3 Z. i1 h. g; r. s2 |
- 11 * - Alignment edge; k9 B' z* I0 P/ J, a
- 12 * - Direction up' W: n, u- C. @4 z' D6 S
- 13 */9 O- |% c' D/ h' s. w
- 14 timer_set_mode(TIM14, TIM_CR1_CKD_CK_INT, TIM_CR1_CMS_EDGE, TIM_CR1_DIR_UP);
: j/ n/ R( h' B9 P - 15
7 G* G F5 U. N% d! x0 I - 16 /*9 f, P! S5 t* P' i A+ C
- 17 * APB1 PRE = 1, TIMPCLK = PCLK
/ r# ~9 e6 \- R- a# Y2 d - 18 * APB1 PRE != 1, TIMPCLK = PCLK * 2- z/ s$ }0 f+ I0 ]) D3 Q
- 19 */, f9 C# E# d$ C W/ v. M# a+ Y2 h
- 20 timer_set_prescaler(TIM14, (rcc_apb1_frequency/100000-1)); //100KHz5 s" v$ S: J; T) `7 k* L: q$ P
- 215 z& i, R7 @0 W W. P
- 22 /* Disable preload. */
, H8 d: ]7 d$ s, {6 T - 23 timer_disable_preload(TIM14);
0 K" h4 c. A" j; } - 24 timer_continuous_mode(TIM14);' @( `7 n! t: P. h* `
- 257 ?5 o3 v1 r4 }3 |# ?8 H
- 26 /* Timer Period */- c) d7 D8 l- M. W4 U P: P
- 27 timer_set_period(TIM14, 20-1); /* 100kHz /20 = 5 KHz */( D9 P% W" r$ o( y( O% M% O0 }) L
- 28
$ m/ N! T. a6 P# x - 29 /* Set the initual output compare value for OC1. */4 K/ g7 N; r0 O. E4 e! R9 c6 U
- 30 timer_set_oc_mode(TIM14, TIM_OC1, TIM_OCM_PWM1);
" \/ W3 X- u: b J - 31 timer_set_oc_value(TIM14, TIM_OC1, 20*0.3); //duty = 0.3
. z' C) ~2 `3 s - 32* D* {1 \8 {' [. N
- 33 /* Enable output */9 P, u, c9 s. I
- 34 timer_enable_oc_output(TIM14, TIM_OC1);
' V# X5 W6 m- c* U3 V9 r - 35 timer_enable_counter(TIM14);
1 [) N- }$ c9 n4 U9 F6 ` - 36}
( F: S1 a5 ~- z; S: g/ A; U- `
" J* Y3 X& \7 S' K先配置定时器的预分频和周期,这里设置到周期为5KHz,可以参考定时器章节的说明; 然后使用timer_set_oc_value 设置占空比,占空比根据定时器周期计算,比如这里设置为30%占空比;
( o9 d: M0 Y' _4 d2 z4 z6 e5 S' C
% s0 l7 d3 m1 ?- J2 Q! o$ `3 呼吸灯效果实现呼吸灯效果就是更改占空比,让其从0-100变化在从100-0变化即可; - 1int duty = 0;0 x* r" Z, ]1 l8 a9 C
- 2
% R* K; U% d4 E2 z" A0 O - 3while(1){ J' f* @$ c8 Z% D0 @; T" t3 q
- 4
h2 {) x/ @& x2 I - 5 //from 0 - 100- ~; q1 T7 o- N* D
- 6 for(duty=0; duty <= 100; duty++){
. R9 D' b4 @3 d9 R2 w; b6 {$ T - 7 duty = duty + 1;
# D t# d, ~ b V - 8 timer_set_oc_value(TIM14,TIM_OC1, 20*duty/100);
1 ]7 {+ \6 v! e' g- n - 9
! H! b6 Q) u, r2 a# x - 10 //delay some time
& [$ h0 D2 t, |- l. ? - 11 for(int i=0; i<600000; i++){
' e+ ?" A$ F& d$ j& u' t - 12 __asm__("nop");
; t$ Z6 C7 f- x6 v3 ? - 13 }
) E% Q* P$ z& J$ j - 14 }3 m e, @5 z! b4 t
- 15
. f) c+ N3 A/ z6 ^ - 16 //from 100-05 F& f6 l P1 V
- 17 for(duty=100;duty>=0; duty--){( J+ K F- e* l* T2 L( J6 d, t
- 18 duty = duty - 1;! {& |0 Z9 h, G6 D4 D0 R. E1 `, `0 `
- 19 timer_set_oc_value(TIM14,TIM_OC1, 20*duty/100);
$ I N) F1 f! @& @ - 20* a, B3 {( B- e+ k, J v0 v' n8 C
- 21 //delay some time
" m7 Z, v8 C9 }' i- n! t - 22 for(int i=0; i<600000; i++){$ G W2 ]2 T0 u; X" }) a
- 23 __asm__("nop");% n! q j/ _/ Z l
- 24 }
" `( B* F, u4 Y% f& ` - 25% Q: o' c$ a) u2 \) k
- 26 }- b+ V& m( \2 _' b5 {7 G- Z' v
- 27
9 _& K+ p" A' x0 l8 }/ Y- G; r - 28}
/ D3 p% p: {, a8 L4 y4 k$ J转载自:MakerInChina.cn$ V/ a6 R# H8 Z9 P( w' d
