VL53L5CX如何实现超过15HZ的采样?超频会引发什么现象?
xu@xupt 提问时间:2023-11-2 10:55 / 已解决
赞 收藏 评论3 发布时间:2023-11-2 10:55
3个回答
深圳好星星 最优答案 回答时间:2023-11-6 14:08:54
8x8模式最大可以跑到50Hz,但是要改一下寄存器。
int example17(void) {
// / VL53L5CX ranging variables / //
uint8_t status, isAlive, isReady, i, j; uint16_t loop; VL53L5CX_Configuration Dev; / Sensor configuration / uint16_t distance[VL53L5CX_RESOLUTION_8X8]; / Array of 64 zones which returns the data / uint32_t timestamp = 0;
// / Customer platform / //
/* Fill the platform structure with customer's implementation. For this
  • example, only the I2C address is used. */ Dev.platform.address = VL53L5CX_DEFAULT_I2C_ADDRESS;
/ (Optional) Reset sensor toggling PINs (see platform, not in API) / //Reset_Sensor(&(Dev.platform));
/* (Optional) Set a new I2C address if the wanted address is different
  • from the default one (filled with 0x20 for this example). */ //status = vl53l5cx_set_i2c_address(&Dev, 0x20);
// / Power on sensor and init / //
/ (Optional) Check if there is a VL53L5CX sensor connected / status = vl53l5cx_is_alive(&Dev, &isAlive); if(!isAlive || status) { printf("VL53L5CX not detected at requested address\n"); return status; }
/ (Mandatory) Init VL53L5CX sensor / status = vl53l5cx_init(&Dev); if(status) { printf("VL53L5CX ULD Loading failed\n"); return status; }
printf("VL53L5CX ULD ready ! (Version : %s)\n", VL53L5CX_API_REVISION);
// / Set some params / //
/ Program continuous mode (best one for speed) / status = vl53l5cx_set_ranging_mode(&Dev, VL53L5CX_RANGING_MODE_CONTINUOUS);
/ Change resolution. Use 8x8 for this example, but 4x4 is also supported / //status = vl53l5cx_set_resolution(&Dev, VL53L5CX_RESOLUTION_8x8);
status = vl53l5cx_set_resolution(&Dev, VL53L5CX_RESOLUTION_8X8);
/ Reduce sharpener. This is mandatory as the signal strength is very low / status = vl53l5cx_set_sharpener_percent(&Dev, 0);
/ Increase max frequency. Dedicated function to be created in the future / uint8_t frequency_hz = 50; // Max 4x4: 150 fps / max 8x8: 50 fps status = vl53l5cx_dci_replace_data(&Dev, Dev.temp_buffer, VL53L5CX_DCI_FREQ_HZ, 4,(uint8_t*)&frequency_hz, 1, 0x01);
// / Ranging loop / //
/ Use dedicated start ranging function in “plugin_fast_ranging” / status = vl53l5cx_start_fast_ranging(&Dev);
loop = 0; while(loop < 1000) { /* Use polling function to know when a new measurement is ready.
  • Another way can be to wait for HW interrupt raised on PIN A3
  • (GPIO 1) when a new measurement is ready */
status = vl53l5cx_check_data_ready(&Dev, &isReady);
if(isReady)
    /* Get all the distances and decompress them */
    status = vl53l5cx_get_fast_ranging_data(&Dev, distance);
    /* Print 8x8 zones */
    for(i = 0; i < 8; i++){
        for(j = 0; j < 8; j++){
            /* Check if distance is valid. Max distance has been limited to 2047 mm in the
             * firmware. When a target status is flagged as invalid, the distance is set to 2048. It
             * allows to easily detect invalid data.
            if(distance[i * 8 + j] == VL53L5CX_FAST_RANGING_INVALID_STATUS)
                printf("xxxx, ");
            else
                printf("%4u, ", distance[i * 8 + j]);
        printf("\n");
    printf("\n");
    /* For STM32 only: print the time elapsed since last frame */
    printf("Time %d ms\n",(int)(HAL_GetTick() - timestamp));
    timestamp = HAL_GetTick();
    // loop++;
/* Wait a few ms to avoid too high polling (function in platform
 * file, not in API) */
//WaitMs(&(Dev.platform), 5);
/ Stop the sensor: use dedicated stop ranging function in “plugin_fast_ranging” / status = vl53l5cx_stop_fast_ranging(&Dev); printf("End of ULD demo\n"); return status; }
xu@xupt 回答时间:2023-11-3 16:06:54
自己顶一下
xu@xupt 回答时间:2023-11-6 19:19:57
深圳好星星 发表于 2023-11-6 14:08
[md]8x8模式最大可以跑到50Hz,但是要改一下寄存器。
[md]感谢
