STM32F0 PB3中断部分程序: void EXTI2_3_IRQHandler(void) { if((EXTI-> R & ((uint32_t)0x00000008)) != 0) /* Check line 3 has triggered the IT */{ printf("EXTI2_3_IRQHandler R=%d\r\n",(EXTI-> R & ((uint32_t)0x00000008)));。。。。。。。。。。。 /* Clear the EXTI line 3 pending bit */ EXTI-> R = ((uint32_t)0x00000008);// printf("EXTI2_3_IRQHandler \r\n"); } } void init_zerox_pin(void) { GPIO_InitTypeDef GPIO_InitStruct = {0}; __HAL_RCC_GPIOB_CLK_ENABLE(); /*Configure GPIO pin : PB3 */ GPIO_InitStruct.Pin = GPIO_PIN_3; GPIO_InitStruct.Mode = GPIO_MODE_INPUT; GPIO_InitStruct.Pull = GPIO_NOPULL; HAL_GPIO_Init(GPIOB, &GPIO_InitStruct); } void config_exti_line3_to_zerox(unsigned char enable_disable) { /* Enable SYSCFG clock */ RCC->APB2ENR |= RCC_APB2ENR_SYSCFGEN; /* Connect EXTI3 Line to PB3 pin */ uint32_t tmp = 0x00; tmp = ((uint32_t)0x0F) << (0x04 * (((uint8_t)0x03) & (uint8_t)0x03)); //(uint8_t)0x03) B3SYSCFG->EXTICR[((uint8_t)0x03) >> 0x02] &= ~tmp; SYSCFG->EXTICR[((uint8_t)0x03) >> 0x02] |= (((uint32_t)((uint8_t)0x01)) << (0x04 * (((uint8_t)0x03) & (uint8_t)0x03))); /* Configure EXTI3 line */ tmp = (uint32_t)EXTI_BASE; if(enable_disable == ENABLE) { printf("config_exti_line3:ENABLE\r\n"); /* Clear EXTI line configuration */ EXTI->IMR &= ~((uint32_t)0x00000008); EXTI->EMR &= ~((uint32_t)0x00000008); tmp += 0x00; *(__IO uint32_t *) tmp |= ((uint32_t)0x00000008); /* Clear Rising Falling edge configuration */ EXTI->RTSR &= ~((uint32_t)0x00000008); EXTI->FTSR &= ~((uint32_t)0x00000008); /* Select the trigger for the selected interrupts */ tmp = (uint32_t)EXTI_BASE; /* falling edge set */ tmp += 0x0C; //EXTI_FTSR: Address offset: 0x0C *(__IO uint32_t *) tmp |= ((uint32_t)0x00000008); } else { printf("config_exti_line33 ISABLE\r\n");tmp += 0x00; /* Disable the selected external lines */ *(__IO uint32_t *) tmp &= ~((uint32_t)0x00000008); } /* Configure NVIC for External Interrupt */ /* Enable Interrupt on EXTI2_3 */ NVIC_EnableIRQ(EXTI2_3_IRQn); /* Set priority for EXTI2_3 */ NVIC_SetPriority(EXTI2_3_IRQn,0); } 更改为STM32G0后,程序如下: void EXTI2_3_IRQHandler(void) { if((EXTI->FPR1 & ((uint32_t)0x00000008)) != 0) /* Check line 3 has triggered the IT */ { printf("EXTI2_3_IRQHandler:FPR1=%d\r\n",(EXTI->FPR1 & ((uint32_t)0x00000008))); 。。。。。。。。。。。 /* Clear the EXTI line 3 pending bit */ EXTI->FPR1 = ((uint32_t)0x00000008); // printf("EXTI2_3_IRQHandler \r\n"); } else if((EXTI->RPR1 & ((uint32_t)0x00000008)) != 0) { printf("EXTI->RPR1 = ((uint32_t)0x00000008)\r\n"); EXTI->RPR1 = ((uint32_t)0x00000008); } } void init_zerox_pin(void) { GPIO_InitTypeDef GPIO_InitStruct = {0}; __HAL_RCC_GPIOB_CLK_ENABLE(); /*Configure GPIO pin : PB3 */ GPIO_InitStruct.Pin = GPIO_PIN_3; GPIO_InitStruct.Mode = GPIO_MODE_INPUT; GPIO_InitStruct.Pull = GPIO_NOPULL; HAL_GPIO_Init(GPIOB, &GPIO_InitStruct); } void config_exti_line3_to_zerox(unsigned char enable_disable) { /* Enable SYSCFG clock */ #if 0 RCC->APB2ENR |= RCC_APB2ENR_SYSCFGEN; #else // RCC->APBENR2 |= RCC_APBENR2_SYSCFGEN; __HAL_RCC_SYSCFG_CLK_ENABLE(); #endif /* Connect EXTI3 Line to PB3 pin */ uint32_t tmp = 0x00; #if 0 tmp = ((uint32_t)0x0F) << (0x04 * (((uint8_t)0x03) & (uint8_t)0x03)); SYSCFG->EXTICR[((uint8_t)0x03) >> 0x02] &= ~tmp; SYSCFG->EXTICR[((uint8_t)0x03) >> 0x02] |= (((uint32_t)((uint8_t)0x01)) << (0x04 * (((uint8_t)0x03) & (uint8_t)0x03))); #else tmp = ((uint32_t)0x0F) << (0x08 * (((uint8_t)0x03) & (uint8_t)0x03)); EXTI->EXTICR[((uint8_t)0x03) >> 0x02] &= ~tmp; EXTI->EXTICR[((uint8_t)0x03) >> 0x02] |= (((uint32_t)((uint8_t)0x01)) << (0x08 * (((uint8_t)0x03) & (uint8_t)0x03))); #endif /* Configure EXTI3 line */ tmp = (uint32_t)EXTI_BASE; if(enable_disable == ENABLE) { printf("config_exti_line3:ENABLE\r\n"); /* Clear EXTI line configuration */ #if 0 EXTI->IMR &= ~((uint32_t)0x00000008); EXTI->EMR &= ~((uint32_t)0x00000008); #else EXTI->IMR1 &= ~((uint32_t)0x00000008); EXTI->EMR1 &= ~((uint32_t)0x00000008); #endif tmp += 0x00; *(__IO uint32_t *) tmp |= ((uint32_t)0x00000008); /* Clear Rising Falling edge configuration */ #if 0 EXTI->RTSR &= ~((uint32_t)0x00000008); EXTI->FTSR &= ~((uint32_t)0x00000008); #else EXTI->RTSR1 &= ~((uint32_t)0x00000008); EXTI->FTSR1 &= ~((uint32_t)0x00000008); #endif /* Select the trigger for the selected interrupts */ tmp = (uint32_t)EXTI_BASE; /* falling edge set */ tmp += 0x04; //EXTI_FTSR1:Address offset: 0x04 *(__IO uint32_t *) tmp |= ((uint32_t)0x00000008); } else { printf("config_exti_line33 ISABLE\r\n");tmp += 0x00; /* Disable the selected external lines */ *(__IO uint32_t *) tmp &= ~((uint32_t)0x00000008); } /* Configure NVIC for External Interrupt */ /* Enable Interrupt on EXTI2_3 */ NVIC_EnableIRQ(EXTI2_3_IRQn); /* Set priority for EXTI2_3 */ NVIC_SetPriority(EXTI2_3_IRQn,0); }
STM32F0 程序移到STM32G0 PB3边沿中断不运行.docx
(15.26 KB, 下载次数: 0)
最近的ST研讨会在各个城市的议程有差别吗?
STM32全球线上峰会和NFC的线下会是不是时间重叠
stm32g431rbt怎么显示汉字
stm32n6570dk如何解锁保护程序?
openstlinux或者mp157怎么配置中文?
STM32H750 LTDC 超级奇怪的问题
2025嵌入式芯片与系统设计竞赛更换主控板的问题?
STM32MP157D-DK1与STM32MP157F-DK2重大区别和推荐选择哪块板子,想做智能家居方面的,
我在SY官网查询STM32MP157F-DK2的电路板制造和原理图方面的知识为什么给的都是MB系列的?
智能穿戴设备赛道作品能否运用电脑去处理信号
