stmf407VETx烧录时报错
张炫哲 提问时间:2024-6-8 15:22 / 未解决
  • 正在文件夹 MDK(V5) 中执行任务: "D:\keil\OpenOCD-20231002-0.12.0\bin\openocd.exe -s "c:\Users\86157\Desktop\stmf407\project\MDK(V5)" -f interface/stlink.cfg -f target/stm32f1x.cfg -c "program \"c:/Users/86157/Desktop/stmf407/project/MDK(V5)/build/Project/project.hex\" verify" -c "reset run" -c "exit""
Open On-Chip Debugger 0.12.0 (2023-10-02) [https://github.com/sysprogs/openocd] Licensed under GNU GPL v2 libusb1 09e75e98b4d9ea7909e8837b7a3f00dda4589dc3 For bug reports, read http://openocd.org/doc/doxygen/bugs.html Info : auto-selecting first available session transport "hla_swd". To override use 'transport select <transport>'. Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD Info : clock speed 1000 kHz Error: open failed in procedure 'program' OpenOCD init failed shutdown command invoked
  • 终端进程“cmd.exe /C "D:\keil\OpenOCD-20231002-0.12.0\bin\openocd.exe -s "c:\Users\86157\Desktop\stmf407\project\MDK(V5)" -f interface/stlink.cfg -f target/stm32f1x.cfg -c "program \"c:/Users/86157/Desktop/stmf407/project/MDK(V5)/build/Project/project.hex\" verify" -c "reset run" -c "exit""”已终止,退出代码: 1。
  • 终端将被任务重用,按任意键关闭。
赞 收藏 评论1 发布时间:2024-6-8 15:22
butterflyspring 回答时间:2024-6-11 10:14:58
可以先用STM32CubeProgrammer 这个免费软件试一下,验证一下硬件连接方面是否有问题。
