Open On-Chip Debugger 0.12.0-00024-gc3ff39f8b (2023-06-26-16:51) [https://github.com/STMicroelectronics/OpenOCD] Licensed under GNU GPL v2 For bug reports, read http://openocd.org/doc/doxygen/bugs.html srst_only srst_pulls_trst srst_gates_jtag srst_open_drain connect_deassert_srst Info : Listening on port 6666 for tcl connections Info : Listening on port 4444 for telnet connections Info : STLINK V2J43M28 (API v2) VID:PID 0483:3752 Info : Target voltage: 3.219856 Info : Unable to match requested speed 8000 kHz, using 4000 kHz Info : Unable to match requested speed 8000 kHz, using 4000 kHz Info : clock speed 4000 kHz Info : stlink_dap_op_connect(connect) Info : SWD DPIDR 0x6ba02477 Info : stlink_dap_op_connect(connect) Info : SWD DPIDR 0x6ba02477 Info : [STM32MP157DACx.cm4] Cortex-M4 r0p1 processor detected Info : [STM32MP157DACx.cm4] target has 6 breakpoints, 4 watchpoints Info : STM32MP157DACx.cpu0: hardware has 6 breakpoints, 4 watchpoints Info : STM32MP157DACx.cpu1: hardware has 6 breakpoints, 4 watchpoints Info : gdb port disabled Info : gdb port disabled Info : gdb port disabled Info : starting gdb server for STM32MP157DACx.cpu0 on 3334 Info : Listening on port 3334 for gdb connections Info : starting gdb server for STM32MP157DACx.cm4 on 3333 Info : Listening on port 3333 for gdb connections Info : [STM32MP157DACx.cm4] external reset detected Info : accepting 'gdb' connection on tcp/3333 Info : Halt timed out, wake up GDB. Error: timed out while waiting for target halted Error executing event gdb-attach on target STM32MP157DACx.cm4: Info : New GDB Connection: 1, Target STM32MP157DACx.cm4, state: reset Warn : GDB connection 1 on target STM32MP157DACx.cm4 not halted Warn : negative reply, retrying Warn : negative reply, retrying Info : accepting 'gdb' connection on tcp/3333 Info : Halt timed out, wake up GDB. Error: timed out while waiting for target halted Error executing event gdb-attach on target STM32MP157DACx.cm4: Info : New GDB Connection: 2, Target STM32MP157DACx.cm4, state: reset Warn : GDB connection 2 on target STM32MP157DACx.cm4 not halted Warn : negative reply, retrying Warn : negative reply, retrying Info : stlink_dap_op_connect(connect) Info : SWD DPIDR 0x6ba02477 Info : Deferring arp_examine of STM32MP157DACx.cm4 Info : Use arp_examine command to examine it manually! Info : stlink_dap_op_connect(reconnect) Info : SWD DPIDR 0x6ba02477 Info : stlink_dap_op_connect(connect) Info : SWD DPIDR 0x6ba02477 Info : [STM32MP157DACx.cm4] Cortex-M4 r0p1 processor detected Info : [STM32MP157DACx.cm4] target has 6 breakpoints, 4 watchpoints Info : Halt timed out, wake up GDB. Error: timed out while waiting for target halted Error: Failed to write memory at 0x10006e40 Error: Failed to write memory at 0x10007900 Polling target STM32MP157DACx.cpu0 failed, trying to reexamine Examination failed, GDB will be halted. Polling again in 100ms Polling target STM32MP157DACx.cpu1 failed, trying to reexamine Examination failed, GDB will be halted. Polling again in 100ms Info : dropped 'gdb' connection Polling target STM32MP157DACx.cpu0 failed, trying to reexamine Examination failed, GDB will be halted. Polling again in 300ms Polling target STM32MP157DACx.cm4 failed, trying to reexamine Error: Failed to read memory at 0xe000ed00 Examination failed, GDB will be halted. Polling again in 100ms shutdown command invoked Info : dropped 'gdb' connection |
[STM32CubeProgrammer]请问在STM32CubeProgrammer上面有实现A/B分区的升级方式吗?
[SD卡]关于SD卡升级的地址一致性
STM32MP135F OTP读写异常
STM32CUBE programmer 软件出错
ECK10-135A5M5M-I的开发板,烧录官方提供的nandflash镜像,结果起不来
stm32mp157 通过codesys 运行PLC程序
STM32MP157DAA1进行异核通信时配置初始化 函数无法进入
STM32MP157D调试M4内核的问题
在stm32mp135f-dk上搭建编译环境,应该需要怎么做,有哪个大佬能解答一下
社区无法登录
你好,请提供相关的复现步骤.
