Connect the STM32U575 OCTOSPI interface to fm25w256 in single SPI mode. Configure OCTOSPI as shown in the following figure fm25w256 read and write function is realized by the conventional command protocol, the timing is as follows: How is the software implemented, please provide reference or guidance。 thank you |
STM32U575的LPTIM中断问题
STM32U575低功耗问题
stm32u5g9j-dk1, 设置tzen1,之后关闭变砖
STM32u575 USART 用GPDMA接收,DMA中断,usart 中断正常来,ROR数据正确,接收缓冲却不变
stm32u575 gpdma burst length=1 配置其他数值不工作
STM32U5进入standby模式时,待机电流有时候大的离谱,有时候却正常
STM32U5系列上电时序
STM32U585进入shutdown模式后偶发无法被唤醒引脚唤醒
DMA传输完成后,串口与DMA一直处于忙状态
But, the fm25w256 is a standard SPI interface chip, why don't you use the SPI directly?
