本人使用自己画的板子,用usart1的pa9和pa10在stm32cubeprogrmmer中进行串口连接,也保留了swd串口调试接口,但始终无法正确连接,报错如下:00:37:16:773 : RTS low 00:37:16:774 : DTR Low 00:37:16:833 : Serial Port cu.usbmodem0000637289221 is successfully opened. 00:37:16:833 : Port configuration: parity = even, baudrate = 115200, data-bit = 8, stop-bit = 1.0, flow-control = off 00:37:16:833 : No Init bits value is : 0 00:37:16:833 : Sending init command: 00:37:16:833 : #byte 0x7F sent successfully to target 00:37:18:834 : Wait ends after 1 loop, dataready = 0, delay = 2001 00:37:18:835 : Timeout error occured while waiting for acknowledgement. 00:37:18:835 : No response from target received 00:37:18:836 : Retrying UART init connection... 00:37:18:836 : #byte 0x7F sent successfully to target 00:37:18:847 : Wait ends after 1 loop, dataready = 1, delay = 11 00:37:18:848 : #ack Received response from target: 0x1f 00:37:18:848 : Activating device: OK 00:37:18:848 : Board : -- 00:37:18:848 : Sending GetID command and its XOR: 00:37:18:848 : #byte 0x02 sent successfully to target 00:37:18:848 : #byte 0xFD sent successfully to target 00:37:18:859 : Wait ends after 1 loop, dataready = 1, delay = 11 00:37:18:859 : #ack Received response from target: 0x79 00:37:18:859 : Received 4 data bytes from target : 0x01045079 00:37:18:859 : Chip ID: 0x450 00:37:18:859 : Sending Get command and its XOR: 00:37:18:860 : #byte 0x00 sent successfully to target 00:37:18:860 : #byte 0xFF sent successfully to target 00:37:18:874 : Wait ends after 1 loop, dataready = 1, delay = 14 00:37:18:874 : #ack Received response from target: 0x79 00:37:18:874 : Received 1 data bytes from target : 0x0b 00:37:18:874 : size of bytes in the response: 11 00:37:18:874 : Received 13 data bytes from target 00:37:18:874 : Full received response: 0b31000102112131446373829279 00:37:18:874 : BootLoader protocol version: 3.1 00:37:18:874 : #byte 0x11 sent successfully to target 00:37:18:874 : #byte 0xEE sent successfully to target 00:37:19:000 : #data sent successfully to target: 0x0800000008 00:37:20:011 : Sending GetID command and its XOR: 00:37:20:011 : #byte 0x02 sent successfully to target 00:37:20:011 : #byte 0xFD sent successfully to target 00:37:20:020 : Wait ends after 1 loop, dataready = 1, delay = 8 00:37:20:020 : #ack Received response from target: 0x1f 00:37:20:020 : Response received from device: NACK 00:37:20:020 : Error: GETID command not acknowledged! 00:37:20:145 : Reemission of GetID command 00:37:20:146 : Sending GetID command and its XOR: 00:37:20:146 : #byte 0x02 sent successfully to target 00:37:20:146 : #byte 0xFD sent successfully to target 00:37:20:161 : Wait ends after 1 loop, dataready = 1, delay = 14 00:37:20:162 : #ack Received response from target: 0x79 00:37:20:163 : Received 4 data bytes from target : 0x01045079 00:37:20:205 : #byte 0x11 sent successfully to target 00:37:20:205 : #byte 0xEE sent successfully to target 00:37:20:308 : #data sent successfully to target: 0x0800000008 00:37:21:310 : Sending Read command and its XOR: 00:37:21:310 : #byte 0x11 sent successfully to target 00:37:21:311 : #byte 0xEE sent successfully to target 00:37:21:321 : Wait ends after 1 loop, dataready = 1, delay = 11 00:37:21:322 : #ack Received response from target: 0x1f 00:37:21:322 : Response received from device: NACK 00:37:21:322 : Error: READ command not acknowledged at address: 0x8000000 00:37:21:322 : Database: Config 0 is active. 00:37:21:323 : Sending GetID command and its XOR: 00:37:21:324 : #byte 0x02 sent successfully to target 00:37:21:324 : #byte 0xFD sent successfully to target 00:37:21:337 : Wait ends after 1 loop, dataready = 1, delay = 14 00:37:21:337 : #ack Received response from target: 0x79 00:37:21:337 : Received 4 data bytes from target : 0x01045079 00:37:22:582 : Sending GetID command and its XOR: 00:37:22:582 : #byte 0x02 sent successfully to target 00:37:22:582 : #byte 0xFD sent successfully to target 00:37:22:582 : Wait ends after 1 loop, dataready = 1, delay = 14 00:37:22:582 : #ack Received response from target: 0x79 00:37:22:582 : Received 4 data bytes from target : 0x01045079 00:37:22:582 : #byte 0x11 sent successfully to target 00:37:22:582 : #byte 0xEE sent successfully to target 00:37:22:582 : #data sent successfully to target: 0x0800000008 00:37:22:582 : UPLOADING OPTION BYTES DATA ... 00:37:22:583 : Bank : 0x00 00:37:22:583 : Address : 0x5200201c 00:37:22:583 : Size : 308 Bytes 00:37:22:583 : Sending Read command and its XOR: 00:37:22:583 : #byte 0x11 sent successfully to target 00:37:22:583 : #byte 0xEE sent successfully to target 00:37:22:583 : Wait ends after 1 loop, dataready = 1, delay = 10 00:37:22:583 : #ack Received response from target: 0x1f 00:37:22:583 : Response received from device: NACK 00:37:22:583 : Error: READ command not acknowledged at address: 0x5200201C 00:37:22:583 : Error: Uploading Option Bytes bank: 0 failed 00:37:22:610 : Error: Initializing the Option Bytes failed 00:37:22:639 : UART PORT CLOSE 00:37:22:639 : Disconnected from device. 00:37:31:421 : Error: Connection to target must be established before performing the erase command. 00:37:31:532 : Disconnected from device. 本人的mcu是在嘉立创买的,应该不存在盗版二手的问题,想问下这是被读保护了吗,是几级呢?有什么解决方案吗 |
STM32H755使用DMA接收数据不正常
CubeMX 生成的 STM32H7 CMake 工程打开串口 DMA 无法正常发送数据,如何解决?
STM32H7S78-DK 官方TOUCHGFX的DEMO源码在哪里呢?
STM32H723VG实现usb通讯
STM32H750VBT6挂接外部NAND Flash
STM32H7 openamp
如何利用TIM1触发HRTIM TIMA生成频率为20Hz的100ns脉冲波?
STM32双核H7核间通信的方法
stm32上部署yolo的问题
STM32H723VGT6的唯一DFSDM的时钟可以同时输出给2个sigma-delta吗?
你这贴出来的信息跟一锅粥一样的,
感觉你的bootloader已经跑起来了,也执行了部分命令,的确是像读保护了。
你不是预留了SWD口吗?用STM32CubeProgrammer连接看看,RDP的等级,如果是L1倒是
小问题,修改为RDP0即可,如果L2就换个芯片吧。
排查一下硬件,保证可以有升级功能的 RX 脚不要出现扰动信号(尝试接个上拉电阻)。
[md]用jlink连接比串口还差,似乎都连接不太上
最好用ST-LINK,有一些小伙伴的J-LINK 并非正版,总是有些怪现象。
