【求助】用STM32F10x点亮led小灯,PC脚定义的问题
asdy00000 提问时间:2010-10-19 10:45 /
我的目的是用STM32F10x点亮led小灯,用的是IAR for ARM的编译软件,定义IO口的时候PA,PB是正常的,
  /* Enable GPIOC clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
  /* Configure PA.06  as Output push-pull */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 ;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
可是定义PC脚的时候,出现“identifier GPIOC is undenfined”,
 请问高手们,我这是什么东西的设置不对啊?!
我的总体main函数如下:
/******************** (C) COPYRIGHT 2007 STMicroelectronics ********************
* File Name          : main.c
* Author             : MCD Application Team
* Version            : V1.0
* Date               : 10/08/2007
* Description        : Main program body
* THE PRESENT SOFTWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
* AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
* INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
* CONTENT OF SUCH SOFTWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
* INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x_lib.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
ErrorStatus HSEStartUpStatus;
/* Private function prototypes -----------------------------------------------*/
void RCC_Configuration(void);
void NVIC_Configuration(void);
void Delay(vu32 nCount);
/* Private functions ---------------------------------------------------------*/
* Function Name  : main
* Description    : Main program.
* Input          : None
* Output         : None
* Return         : None
int main(void)
#ifdef DEBUG
  debug();
#endif
  /* Configure the system clocks */
  RCC_Configuration();
  /* NVIC Configuration */
  NVIC_Configuration();
   RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR, ENABLE);
   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
  /* Configure PC.06, PC.07, PC.08 and PC.09 as Output push-pull */
  GPIO_Init(GPIOC, &GPIO_InitStructure);
  while (1)
    /* Turn on led connected to PC.06 pin */
    GPIO_SetBits(GPIOA, GPIO_Pin_6);
    /* Insert delay */
    Delay(0xAFFFF);
    /* Turn on led connected to PC.07 and PC.08 pins */
    GPIO_SetBits(GPIOA, GPIO_Pin_7 | GPIO_Pin_8);
    /* Turn off led connected to PC.06 pin */
    GPIO_ResetBits(GPIOA, GPIO_Pin_6);
    /* Insert delay */
    Delay(0xAFFFF);
    /* Turn on led connected to PC.09 pin */
    GPIO_SetBits(GPIOA, GPIO_Pin_9);
    /* Turn off led connected to PC.07 and PC.08 pins */
    GPIO_ResetBits(GPIOA, GPIO_Pin_8 | GPIO_Pin_7);
    /* Insert delay */
    Delay(0xAFFFF);
    /* Turn off led connected to PC.09 pin */
    GPIO_ResetBits(GPIOA, GPIO_Pin_9);
* Function Name  : RCC_Configuration
* Description    : Configures the different system clocks.
* Input          : None
* Output         : None
* Return         : None
  /* RCC system reset(for debug purpose) */
  RCC_DeInit();
  /* Enable HSE */
  RCC_HSEConfig(RCC_HSE_ON);
  /* Wait till HSE is ready */
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if(HSEStartUpStatus == SUCCESS)
    /* Enable Prefetch Buffer */
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    /* Flash 2 wait state */
    FLASH_SetLatency(FLASH_Latency_2);
    /* HCLK = SYSCLK */
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    /* PCLK2 = HCLK */
    RCC_PCLK2Config(RCC_HCLK_Div1);
    /* PCLK1 = HCLK/2 */
    RCC_PCLK1Config(RCC_HCLK_Div2);
    /* PLLCLK = 8MHz * 9 = 72 MHz */
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
    /* Wait till PLL is ready */
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
    /* Select PLL as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    /* Wait till PLL is used as system clock source */
    while(RCC_GetSYSCLKSource() != 0x08)
* Function Name  : NVIC_Configuration
* Description    : Configures Vector Table base location.
* Input          : None
* Output         : None
* Return         : None
#ifdef  VECT_TAB_RAM
  /* Set the Vector Table base location at 0x20000000 */
  NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else  /* VECT_TAB_FLASH  */
  /* Set the Vector Table base location at 0x08000000 */
  NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
* Function Name  : Delay
* Description    : Inserts a delay time.
* Input          : nCount: specifies the delay time length.
* Output         : None
* Return         : None
  for(; nCount != 0; nCount--);
#ifdef  DEBUG
* Function Name  : assert_failed
* Description    : Reports the name of the source file and the source line number
*                  where the assert_param error has occurred.
* Input          : - file: pointer to the source file name
*                  - line: assert_param error line source number
* Output         : None
* Return         : None
void assert_failed(u8* file, u32 line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
赞 收藏 评论8 发布时间:2010-10-19 10:45
8个回答
废鱼 回答时间:2010-10-19 14:24:04
RE:【求助】用STM32F10x点亮led小灯,PC脚定义的问题
你用的什么芯片?是不是没有GPIOC?
可是定义PC脚的时候,出现“identifier GPIOC is undenfined”,说明没有定义GPIOC。
asdy00000 回答时间:2010-10-19 14:30:38
回复:【求助】用STM32F10x点亮led小灯,PC脚定义的问题
回复第 2 楼 安 于2010-10-19 06:24:04发表:
你用的什么芯片?是不是没有GPIOC?
我在IAR的的Device中定义的是STM32F10xxB,
废鱼 回答时间:2010-10-19 14:35:20
你可以看看你引用的这个头文件里面有没有GPIOC。
asdy00000 回答时间:2010-10-19 14:53:22
回复第 4 楼 安 于2010-10-19 06:35:20发表:
我用的是现有的文件移植过来的,main函数里头文件里不用定义GPIO的东西,而且PA,PB的引脚也没用定义,我都可以用他们的,我想用PC脚做一下程序,却运行不了的,不知道为什么定义不了,
废鱼 回答时间:2010-10-19 15:30:08
GPIOC在GPIO.H中定义的了,你看看有没有。这个说明没有这个定义,当然会提示你错误了。如果有定义了,就不会提示错误。
asdy00000 回答时间:2010-10-19 16:41:12
回复第 6 楼 安 于2010-10-19 07:30:08发表:
我在GPIO.h里找到关于GPIOC的定义,但是不知道是不是。我把我的程序发上来了,你有时间帮我看看吧?!麻烦了。。。
点亮小灯.rar
383.48 KB, 下载次数: 2
废鱼 回答时间:2010-10-19 18:44:48
我没有IAR,你把GPIO.C也添加进去。
asdy00000 回答时间:2010-10-20 15:58:11
回复第 8 楼 安 于2010-10-19 10:44:48发表:
我添加进去了,还是不好用的,我现在换了个模板解决以前的问题了,可是我现在有个的新问题:
我用IAR FOR ARM的编译软件编辑流水灯的,为了检查寄存器,我在while循环里的GPIO的每一行我都加了断点设置,发现程序不是按顺序进行的,这是为什么呢?!
