高手帮我看看STM32F101的RS485通信
shenshujing 提问时间:2011-4-20 10:42 /
这个采用的是USART3,RE/ED接在一起,我把这个控制位置高了,就是很简单的发送一个数据给PC机,这边采用的RS485转RS232与电脑连接。但是不能正常发送数据,复位一次在串口接受界面看到00。请高手帮帮忙!
* File Name          : main.c
* Author             : Wuhan R&D Center, Embest
* Date First Issued  : 08/08/2008
* Description        : Main program body
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x_lib.h"
#include
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
ErrorStatus HSEStartUpStatus;
/* Private function prototypes -----------------------------------------------*/
void RCC_Configuration(void);
void NVIC_Configuration(void);
void GPIO_Configuration(void);
void USART_Configuration(void);
/* Private functions ---------------------------------------------------------*/
* Function Name  : main
* Description    : Main program.
* Input          : None
* Output         : None
* Return         : None
int main(void)
{ // u16 i=0;
#ifdef DEBUG
  debug();
#endif
  /* Configure the system clocks */
  RCC_Configuration();
  /* NVIC Configuration */
  NVIC_Configuration();
  /* Configure the GPIOs */
  GPIO_Configuration();
  /* Configure the USART1 */
  USART_Configuration();
 // printf("\r\n Welcome to WUHAN R&D Center,Embest  \r\n");
 // printf("\r\n Please Input Character From Keyboard \r\n");
//while(1 )
//  if(USART_GetFlagStatus(USART1,USART_IT_RXNE)==SET)
//   i = USART_ReceiveData(USART1);
//   printf("  %c",i&0xFF);    /* print the input char */
  GPIOB->ODR = 0x0200;
 for(;;)
    USART_SendData(USART3, 8); //发送一位数据
    while(USART_GetFlagStatus(USART3, USART_FLAG_TXE) == RESET);
    GPIOA->ODR = 0x0002;
#ifdef  DEBUG
* Function Name  : assert_failed
* Description    : Reports the name of the source file and the source line number
*                  where the assert error has occurred.
* Input          : - file: pointer to the source file name
*                  - line: assert error line source number
* Output         : None
* Return         : None
void assert_failed(u8* file, u32 line)
  /* User can add his own implementation to report the file name and line number */
  printf("\n\r Wrong parameter value detected on\r\n");
  printf("       file  %s\r\n", file);
  printf("       line  %d\r\n", line);
  /* Infinite loop */
  /* while (1)
#endif
* Function Name  : RCC_Configuration
* Description    : Configures the different system clocks.
* Input          : None
* Output         : None
* Return         : None
  /* RCC system reset(for debug purpose) */
  RCC_DeInit();
  /* Enable HSE */
  RCC_HSEConfig(RCC_HSE_ON);
  /* Wait till HSE is ready */
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if(HSEStartUpStatus == SUCCESS)
    /* HCLK = SYSCLK */
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    /* PCLK2 = HCLK */
    RCC_PCLK2Config(RCC_HCLK_Div1);
    /* PCLK1 = HCLK/2 */
    RCC_PCLK1Config(RCC_HCLK_Div2);
    /* Flash 2 wait state */
    FLASH_SetLatency(FLASH_Latency_2);
    /* Enable Prefetch Buffer */
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    /* PLLCLK = 8MHz * 9 = 72 MHz */
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
    /* Wait till PLL is ready */
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
    /* Select PLL as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    /* Wait till PLL is used as system clock source */
    while(RCC_GetSYSCLKSource() != 0x08)
  /* Enable USART1 and GPIOA clock */
  RCC_APB2PeriphClockCmd(  RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOA, ENABLE);
  RCC_APB1PeriphClockCmd( RCC_APB1Periph_USART3,ENABLE);
* Function Name  : NVIC_Configuration
* Description    : Configures Vector Table base location.
* Input          : None
* Output         : None
* Return         : None
#ifdef  VECT_TAB_RAM
  /* Set the Vector Table base location at 0x20000000 */
  NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else  /* VECT_TAB_FLASH  */
  /* Set the Vector Table base location at 0x08000000 */
  NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
* Function Name  : GPIO_Configuration
* Description    : Configures the different GPIO ports.
* Input          : None
* Output         : None
* Return         : None
 /* Configure PC. as Output push-pull */
  GPIO_InitStructure.GPIO_Pin =GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_11|GPIO_Pin_12;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;//输出
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  /* Configure USART1 Tx (PB.10) as alternate function push-pull */
  /* Configure USART1 Rx (PAB.11) as input floating */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
* Function Name  : USART_Configuration
* Description    : Configures the USART1.
* Input          : None
* Output         : None
* Return         : None
  USART_ClockInitTypeDef  USART_ClockInitStructure;
/* USART1 configuration -----------------------------------------------
  /* USART1 configured as follow:
        - BaudRate = 115200 baud
        - Word Length = 8 Bits
        - One Stop Bit
        - No parity
        - Hardware flow control disabled (RTS and CTS signals)
        - Receive and transmit enabled
        - USART Clock disabled
        - USART CPOL: Clock is active low
        - USART CPHA: Data is captured on the middle
        - USART LastBit: The clock pulse of the last data bit is not
output to
                         the SCLK pin
USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
/* Configure the USART1 synchronous paramters */
USART_ClockInit(USART3, &USART_ClockInitStructure);
USART_InitStructure.USART_BaudRate = 9600;
USART_InitStructure.USART_Parity = USART_Parity_No ;
USART_InitStructure.USART_HardwareFlowControl =
USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Rx |  USART_Mode_Tx;
/* Configure USART1 basic and asynchronous paramters */
USART_Init(USART3, &USART_InitStructure);
  /* Enable USART1 */
  USART_Cmd(USART3, ENABLE);
* Function Name  : fputc
* Description    : Retargets the C library printf function to the USART.
* Input          : None
* Output         : None
* Return         : None
int fputc(int ch, FILE *f)
  /* Place your implementation of fputc here */
  /* e.g. write a character to the USART */
  USART_SendData(USART3, (u8) ch);
  /* Loop until the end of transmission */
  while(USART_GetFlagStatus(USART3, USART_FLAG_TC) == RESET)
  return ch;
/******************* (C) COPYRIGHT 2007 STMicroelectronics *****END OF FILE****/
#include
* Input          : None
* Output         : None
* Return         : None
int main(void)
{ // u16 i=0;
#ifdef DEBUG
  debug();
#endif
//while(1 )
 for(;;)
#ifdef  DEBUG
* Output         : None
* Return         : None
  /* Infinite loop */
  /* while (1)
#endif
* Input          : None
* Output         : None
* Return         : None
  RCC_DeInit();
  /* Enable HSE */
    /* HCLK = SYSCLK */
    /* PCLK2 = HCLK */
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
* Input          : None
* Output         : None
* Return         : None
#ifdef  VECT_TAB_RAM
#endif
* Input          : None
* Output         : None
* Return         : None
* Input          : None
* Output         : None
* Return         : None
        - One Stop Bit
        - No parity
output to
                         the SCLK pin
  /* Enable USART1 */
* Input          : None
* Output         : None
* Return         : None
  return ch;
main.txt
9.28 KB, 下载次数: 16, 下载积分: ST金币 -1
赞 收藏 评论4 发布时间:2011-4-20 10:42
4个回答
瘦猪呆兔 回答时间:2011-4-20 11:25:01
RE:高手帮我看看STM32F101的RS485通信
貌似没有这个函数啊! USART_SendData();
废鱼 回答时间:2011-4-20 14:42:18
你配置了串口,但是没有配置串口的IO口。你把IO口再重新配置一下。还有就是要注意你使用的是串口3是不是需要映射。
zhouke58 回答时间:2011-4-20 15:50:24
你的配置看起来没有问题.给你说下接RS485的注意事项:
1.RE/ED端在转换发送接收时一定要加足够的延时,因为485IC比不了我们的STM32F101快.即使没有改变也最好加点延时
2.还有你的IO口: GPIOB->ODR = 0x0200;和GPIOA->ODR = 0x0002;是干什么用的?你是否有控制RE/ED端为发送.
shenshujing 回答时间:2011-4-20 16:59:40
谢谢高位的意见,软件应该没有问题,我选定芯片UASRT3貌似没有。
Available only on devices with a Flash memory density equal or higher than 64 Kbytes.
我选的是STM32F101C6。
我换了个UASRT2试了试可用发送了。
