新手求助~~~STM32F051 ADC出来的数据一直为0【悬赏问答】
wang496952046 提问时间:2012-8-7 14:58 /
用STM32F051调试AD转换程序,出来的数据一直是0.0V,不知道哪边有问题,以下是程序代码,请游过的大虾帮帮忙呗,万分感激!!
#include "stm32f0xx.h"        //这个头文件包括STM32F0xx所有外围寄存器、位、内存映射的定义
#include "delay.h"
#include "type_def.h"
#include
#define                USART1_BaudRate                        115200
#define ADC1_DR_Address                0x40012440
vu16  AD_Value;       //用来存放ADC转换结果,也是DMA的目标地址
#ifdef __GNUC__
  /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
     set to 'Yes') calls __io_putchar() */
#define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
#define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
/*GPIO管脚的配置
选用ADC的通道9,分别对应的管脚为PB1
串口使用USART1其中TX为PA9,RX为PA10 */
void GPIO_Configuration(void)
        GPIO_InitTypeDef  GPIO_InitStructure;
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE);
        //PB1 作为模拟通道输入引脚
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;                //模拟输入引脚
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
/*USART1管脚的配置
void USART_Configuration(void)
        RCC_AHBPeriphClockCmd( RCC_AHBPeriph_GPIOA, ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE );
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource9,GPIO_AF_1);
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource10,GPIO_AF_1);
        *  USART1_TX -> PA9 , USART1_RX ->        PA10
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9|GPIO_Pin_10;
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
        USART_InitStructure.USART_BaudRate = USART1_BaudRate;
        USART_InitStructure.USART_Parity = USART_Parity_No;
        USART_Init(USART1, &USART_InitStructure);
        USART_Cmd(USART1, ENABLE);
/*配置ADC1*/
void ADC1_Configuration(void)
        ADC_InitTypeDef  ADC_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE );
        ADC_DeInit(ADC1);        //将外设 ADC1 的全部寄存器重设为缺省值
        ADC_StructInit(&ADC_InitStructure);
        /* ADC1 configuration ------------------------------------------------------*/
        ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;                                                //ADC1分辨率12位
        ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;                                                        //模数转换工作在连续转换模式
        ADC_InitStructure.ADC_ExternalTrigConvEdge=ADC_ExternalTrigConvEdge_None;        //外部触发转换关闭
        ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;                                                //ADC数据右对齐
        ADC_InitStructure.ADC_ScanDirection = ADC_ScanDirection_Backward;                        //顺序进行规则转换的ADC通道的数目
        ADC_Init(ADC1, &ADC_InitStructure);        //根据ADC_InitStruct中指定的参数初始化外设ADCx的寄存器
        ADC_ChannelConfig(ADC1, ADC_Channel_9, ADC_SampleTime_239_5Cycles );
        ADC_GetCalibrationFactor(ADC1);
        /* Enable ADC1 */
        ADC_Cmd(ADC1, ENABLE);        //使能指定的ADC1
        while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_ADEN));                                                //获取指定ADC1的校准程序,设置状态则等待
        ADC_StartOfConversion(ADC1);
/*配置DMA*/
void DMA_Configuration(void)
        /* ADC1  DMA1 Channel Config */
        DMA_InitTypeDef DMA_InitStructure;
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
        DMA_DeInit(DMA1_Channel1);   //将DMA的通道1寄存器重设为缺省值
        DMA_InitStructure.DMA_PeripheralBaseAddr =  (u32)ADC1_DR_Address;  //DMA外设ADC基地址
        DMA_InitStructure.DMA_MemoryBaseAddr = (u32)AD_Value;  //DMA内存基地址
        DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;  //内存作为数据传输的目的地
        DMA_InitStructure.DMA_BufferSize = 2;  //DMA通道的DMA缓存的大小
        DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;  //外设地址寄存器不变
        DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;  //内存地址寄存器递增
        DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;  //数据宽度为16位
        DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; //数据宽度为16位
        DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;  //工作在循环缓存模式
        DMA_InitStructure.DMA_Priority = DMA_Priority_High; //DMA通道 x拥有高优先级
        DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;  //DMA通道x没有设置为内存到内存传输
        DMA_Init(DMA1_Channel1, &DMA_InitStructure);  //根据DMA_InitStruct中指定的参数初始化DMA的通道
        DMA_Cmd(DMA1_Channel1, ENABLE);
        ADC_DMARequestModeConfig(ADC1, ADC_DMAMode_Circular);
        ADC_DMACmd(ADC1, ENABLE);
//配置所有外设
void Init_All_Periph(void)
        GPIO_Configuration();
        USART_Configuration();
        DMA_Configuration();
        ADC1_Configuration();
/*获取ADC的值,将二进制换算为十进制*/
u16 GetVolt(u16 advalue)
   return (u16)(advalue * 330 / 4096);   //求的结果扩大了100倍,方便下面求出小数
PUTCHAR_PROTOTYPE
  /* Place your implementation of fputc here */
  /* e.g. write a character to the USART */
  USART_SendData(USART1, (uint8_t) ch);
  /* Loop until the end of transmission */
  while (USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET)
  return ch;
int main(void)
        u16 value;
    Init_All_Periph();
    while(1)
                while(USART_GetFlagStatus(USART1,USART_FLAG_TXE)==RESET);//等待传输完成否则第一位数据容易丢失
                value = GetVolt(AD_Value);
                printf("value:\t%d.%dv\n  ",value/100,value%100) ;
                Delay_ms(100);
赞 收藏 评论9 发布时间:2012-8-7 14:58
9个回答
火木 回答时间:2012-8-8 14:00:17
回复:新手求助~~~STM32F051 ADC出来的数据一直为0【悬赏问答】
这句话有问题,你应该把AD-Value的地址赋值过去,而不是把AD_Value的内容赋值过去,改成这样试试 DMA_InitStructure.DMA_MemoryBaseAddr = (&AD_Value);
wang496952046 回答时间:2012-8-7 15:01:00
RE:新手求助~~~STM32F051 ADC出来的数据一直为0
自己顶啊
wang496952046 回答时间:2012-8-7 15:02:28
在线等大婶的到来
阿呆 回答时间:2012-8-8 10:43:57
社区第3期悬赏问答活动开始咯~详见:https://www.stmcu.org.cn/bbs/article_1188_456334.html
无论你是大神还是大婶,都快来帮忙吧!
yjwpm 回答时间:2012-8-8 10:54:48
RE:新手求助~~~STM32F051 ADC出来的数据一直为0【悬赏问答】
不知到你有没有好好的看一下,官方的例程呢
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
__IO uint16_t  ADC1ConvertedValue = 0, ADC1ConvertedVoltage = 0;
__IO uint16_t RegularConvData_Tab[4];
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
  * @brief  Main program.
  * @param  None
  * @retval None
int main(void)
  /*!< At this stage the microcontroller clock setting is already configured,
       this is done through SystemInit() function which is called from startup
       file (startup_stm32f0xx.s) before to branch to application main.
       To reconfigure the default setting of SystemInit() function, refer to
       system_stm32f0xx.c file
  /* LCD Display init  */
  Display_Init();
  /* ADC1 and DMA configuration */
  ADC1_DMA_Config();
  /* Infinite loop */
  while (1)
    /* Test DMA1 TC flag */
    while((DMA_GetFlagStatus(DMA1_FLAG_TC1)) == RESET );
    /* Clear DMA TC flag */
    DMA_ClearFlag(DMA1_FLAG_TC1);
    /* Display converted data on the LCD */
    Display();
  * @brief  ADC1 channel with DMA configuration
  * @param  None
  * @retval None
void ADC1_DMA_Config(void)
  /* ADC1 DeInit */
  ADC_DeInit(ADC1);
  /* GPIOC Periph clock enable */
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOC, ENABLE);
   /* ADC1 Periph clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
  /* DMA1 clock enable */
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1 , ENABLE);
  /* Configure ADC Channel11 as analog input */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 ;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
  /* DMA1 Channel1 Config */
  DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC1_DR_Address;
  DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)RegularConvData_Tab;
  DMA_InitStructure.DMA_BufferSize = 4;
  /* DMA1 Channel1 enable */
  /* ADC DMA request in circular mode */
  /* Enable ADC_DMA */
  /* Initialize ADC structure */
  /* Configure the ADC1 in continous mode withe a resolutuion equal to 12 bits  */
  ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
  /* Convert the ADC1 Channel 1 with 55.5 Cycles as sampling time */
  ADC_ChannelConfig(ADC1, ADC_Channel_11 , ADC_SampleTime_55_5Cycles);
  /* Convert the ADC1 temperature sensor  with 55.5 Cycles as sampling time */
  ADC_ChannelConfig(ADC1, ADC_Channel_TempSensor , ADC_SampleTime_55_5Cycles);
  ADC_TempSensorCmd(ENABLE);
  /* Convert the ADC1 Vref  with 55.5 Cycles as sampling time */
  ADC_ChannelConfig(ADC1, ADC_Channel_Vrefint , ADC_SampleTime_55_5Cycles);
  ADC_VrefintCmd(ENABLE);
  /* Convert the ADC1 Vbat with 55.5 Cycles as sampling time */
  ADC_ChannelConfig(ADC1, ADC_Channel_Vbat , ADC_SampleTime_55_5Cycles);
  ADC_VbatCmd(ENABLE);
  /* ADC Calibration */
  /* Enable ADC1 */
  /* Wait the ADCEN falg */
  /* ADC1 regular Software Start Conv */
  * @brief  Display ADC converted value on LCD
  * @param  None
  * @retval None
void Display(void)
  uint32_t v=0,mv=0;
  uint8_t text[50],index;
  /* Set the LCD Back Color and Text Color*/
  LCD_SetBackColor(White);
  LCD_SetTextColor(Green);
  for(index=0;index
航天航海 回答时间:2012-8-8 17:32:32
不懂,学习学习。
zykzyk-93033 回答时间:2012-8-9 20:30:35
尝试吧DMA关掉,然后一步一步调试观察。
liuqs-359554 回答时间:2012-8-18 10:33:11
6楼说的对,我看官方的是个数组,数组名本身就是个地址,而你的AD_VALUE只是个数据!所以没有数据传到AD_VALUE这个变量,只能是0,DMA只是负,内存和CPU ,内存和内存,内存和外设通道之间的数据传输,其实你想得到的AD_VALUE值,是DMA负责从AD通道寄存器那取回来的,其实你也可以自己取,等它AD转换完,你自己手动就可以数据寄存器中拿回来!
高山-404205 回答时间:2013-6-2 10:32:25
我用没问题,1年了,不知道是否还需要回答?
