STM32F030 PB14和PB15无法输出PWM求助
wayhe 提问时间:2016-4-6 23:41 /
我需要使用STM32f030 的TIM1 的CH2和CH3通道输出互补PWM信号,实际测试发现PB14(TIM1_CH2N)PB15(TIM1_CH3N)无法输出,而TIM1_CH2和TIM1_CH3能正常输出。一直找不到原因。TIM1初始化程序如下:
void Time1_Configuration(void)
    TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
        TIM_OCInitTypeDef        TIM_OCInitStructure;
        TIM_BDTRInitTypeDef      TIM_BDTRInitStructure;
    //TIM_PeriodÉèÖÃÁËÔÚÏÂÒ»¸ö¸üÐÂʼþ×°Èë»î¶¯µÄ×Ô¶¯ÖØ×°ÔؼĴæÆ÷ÖÜÆÚµÄÖµ¡£ËüµÄȡֵ±ØÐëÔÚ0x0000ºÍ0xFFFFÖ®¼ä
    TIM_TimeBaseStructure.TIM_Period = TimerPeriod;                                                              //ÉèÖö¨Ê±Æ÷Ô¤·ÖƵֵΪ0
        //TIM_PrescalerÉèÖÃÁËÓÃÀ´×÷ΪTIMxʱÖÓÆµÂʳýÊýµÄÔ¤·ÖƵֵ¡£ËüµÄȡֵ±ØÐëÔÚ0x0000ºÍ0xFFFFÖ®¼ä
    TIM_TimeBaseStructure.TIM_Prescaler = 0;                                                  //ÉèÖö¨Ê±Æ÷ʱÖÓ·ÖÆµÖµ
    TIM_TimeBaseStructure.TIM_ClockDivision = 0;                                                  //ʱÖÓ·Ö¸î
    TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;              //ÉèÖö¨Ê±Æ÷ÏòÉϼÆÊý
          TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;                                     //ÉèÖö¨Ê±Æ÷ÖØ×°ÔØÖµ
    TIM_TimeBaseInit(TIM1, & TIM_TimeBaseStructure);                                       //ÅäÖö¨Ê±Æ÷1
        /* ƵµÀ1£¬2£¬3£¬4µÄPWM ģʽÉèÖà */
        TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;                     //PWM1ģʽ
        TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;         //Êä³ö±È½Ï״̬
        TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;       //»¥²¹Êä³ö±È½Ï״̬
        TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;              //Êä³ö¼«ÐÔΪL
        TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;            //»¥²¹Êä³ö¼«ÐÔΪH
        TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Reset;            //¿ÕÏÐ״̬ÏÂÊä³ö¼«ÐÔReset
        TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;         //¿ÕÏÐ״̬»¥²¹ÏÂÊä³ö¼«ÐÔ
        TIM_OCInitStructure.TIM_Pulse = Channel2Pulse;                                                //ʹÄÜÆµµÀ2ÅäÖÃÖÜÆÚ
        TIM_OC2Init(TIM1, &TIM_OCInitStructure);
        TIM_OCInitStructure.TIM_Pulse = Channel3Pulse;                                                //ʹÄÜÆµµÀ3ÅäÖÃÖÜÆÚ
        TIM_OC3Init(TIM1, &TIM_OCInitStructure);
        //TIM_OC2PreloadConfig(TIM1, TIM_OCPreload_Enable);                                        //ʹÄÜͨµÀ2Ô¤×°ÔØ
        //TIM_OC3PreloadConfig(TIM1, TIM_OCPreload_Enable);                                        //ʹÄÜͨµÀ3Ô¤×°ÔØ
        //TIM_ARRPreloadConfig(TIM1, ENABLE);
        /* PWM ËÀÇøÊ±¼äÉèÖà */
        TIM_BDTRInitStructure.TIM_OSSRState = TIM_OSSRState_Enable;              //Enable Running State
        TIM_BDTRInitStructure.TIM_OSSIState = TIM_OSSIState_Enable;              //Enable Idle State
        TIM_BDTRInitStructure.TIM_LOCKLevel = TIM_LOCKLevel_1;                   //Set the lock level
        TIM_BDTRInitStructure.TIM_DeadTime = 20;                                 //ËÀÇøÊ±¼ä:0x00-0xff
        TIM_BDTRInitStructure.TIM_Break = TIM_Break_Enable;                      //Enable the Break function
        TIM_BDTRInitStructure.TIM_BreakPolarity = TIM_BreakPolarity_High;
        TIM_BDTRInitStructure.TIM_AutomaticOutput = TIM_AutomaticOutput_Enable;  //ʹÄÜ×Ô¶¯Êä³ö.
        TIM_BDTRConfig(TIM1, &TIM_BDTRInitStructure);
        TIM_ClearFlag(TIM1, TIM_FLAG_Update);                                                             //Çå³ýÖжϱêÖ¾·ÀÖ¹ÅäÖÃÍê³É´ò¿ªÖжÏʱÁ¢¼´²úÉúÖжÏ
        //TIM_ITConfig(TIM1, TIM_IT_Update, ENABLE );                                              //ʹÄܶ¨Ê±Æ÷1¸üÐÂÖжÏ
        TIM_Cmd(TIM1, ENABLE);        //ʹÄܶ¨Ê±Æ÷1¹¦ÄÜ
        TIM_CtrlPWMOutputs(TIM1, ENABLE);                             //TIM1 Ö÷Êä³öʹÄÜ
IO初始化
    RCC_AHBPeriphClockCmd( RCC_AHBPeriph_GPIOA, ENABLE);
    GPIO_InitStruct.GPIO_Pin = TxD2 | RxD2 | PWM1L | PWM2L;             //¶Ë¿ÚTxD2 -> PA2 / RxD2 -> PA3 / PWM1L -> PA9 / PWM2L -> PA10
    GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF;                                 //¸´ÓÃ
    GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;                            //×î´óÊä³öËÙ¶È50MHz
    GPIO_InitStruct.GPIO_OType = GPIO_OType_PP;                                     //¸´Óù¦ÄÜÍÆÍìÊä³ö
    GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_UP ;                                //ÉÏÀ­
    GPIO_Init(GPIOA, &GPIO_InitStruct);
    GPIO_PinAFConfig(GPIOA, GPIO_PinSource2, GPIO_AF_1);                 //USART2_TX
          GPIO_PinAFConfig(GPIOA, GPIO_PinSource3, GPIO_AF_1);                 //USART2_RX
    GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_2);                 //TIM1_CH2
    GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_2);                //TIM1_CH3
     RCC_AHBPeriphClockCmd( RCC_AHBPeriph_GPIOB, ENABLE);
    GPIO_InitStruct.GPIO_Pin = TxD1 | RxD1 | PWM1H | PWM2H;             //¶Ë¿ÚTxD1 -> PB6 / RxD1 -> PB7 / PWM1H -> PB14 / PWM2H -> PB15
    GPIO_Init(GPIOB, &GPIO_InitStruct);
        GPIO_PinAFConfig(GPIOB, GPIO_PinSource6, GPIO_AF_0);                 //USART1_TX -> PB6
    GPIO_PinAFConfig(GPIOB, GPIO_PinSource7, GPIO_AF_0);                 //USART1_RX -> PB7
    GPIO_PinAFConfig(GPIOB, GPIO_PinSource14, GPIO_AF_2);                //TIM1_CH2N
    GPIO_PinAFConfig(GPIOB, GPIO_PinSource15, GPIO_AF_2);                //TIM1_CH3N
找了很久找不到问题点。
赞 收藏 评论11 发布时间:2016-4-6 23:41
11个回答
wayhe 回答时间:2016-4-7 16:02:37
有没有人遇到过,支支招呀。
suoma 回答时间:2016-4-7 20:19:22
这是PWM专用引脚还是?不是就要使能该功能
然后示波器观察波形
wayhe 回答时间:2016-4-7 22:15:39
PB14和PB15的复用功能2就是TIM1_CH2N,TIM1_CH3N,用示波器测试无信号输出。
alisa123 回答时间:2016-4-8 08:31:59
最好能对着寄存器看看,有没有使能PWM输出,直接用库有时候会很坑人的。
wayhe 回答时间:2016-4-8 17:15:17
alisa123 发表于 2016-4-8 08:31
最好能对着寄存器看看,有没有使能PWM输出,直接用库有时候会很坑人的。 ...
昨晚熬夜搞定了,确实是被库坑害了。对ST的库真是爱恨交加,害人的货。
手机用户3314123041 回答时间:2017-11-2 09:07:51
你好,请问是什么原因?最后怎么解决的呢?我现在也是遇到这个问题怎么搞都没有输出。。。。。。
samhong 回答时间:2017-11-2 11:09:36
寄存器,古老的是好东西。被很多人忘了...
wayhe 回答时间:2017-11-2 15:22:40
手机用户3314123041 发表于 2017-11-2 09:07
你好,请问是什么原因?最后怎么解决的呢?我现在也是遇到这个问题怎么搞都没有输出。。。。。。 ...
好久了,我也不记得改哪里了,要仔细核对一下寄存器。
手机用户3314123041 回答时间:2017-11-2 15:29:01
我改用TIM15了,谢谢了
a707083746 回答时间:2020-5-26 16:59:04
我用的标准库没问题这个库:
  * @file    stm32f0xx_tim.c
  * @author  MCD Application Team
  * @version V1.5.0
  * @date    05-December-2014
void GPIO_Configuration(void)
{//PB15
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB , ENABLE);
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;
void TIM1_Config(void)
{//TIM1_CH3N
TIM_DeInit(TIM1);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
TIM_TimeBaseStructure.TIM_Prescaler = 4000;
TIM_TimeBaseStructure.TIM_Period = 144;
TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
TIM_TimeBaseStructure.TIM_RepetitionCounter = 0x0;
TIM_TimeBaseInit(TIM1,&TIM_TimeBaseStructure);
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Disable;//关
TIM_OCInitStructure.TIM_Pulse = 50;
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCPolarity_Low;
TIM_OC3Init(TIM1,&TIM_OCInitStructure);
TIM_Cmd(TIM1,ENABLE);
TIM_CtrlPWMOutputs(TIM1,ENABLE);
拼图 回答时间:2024-7-26 16:17:31
注意CH1,CH1N;这样的区别,配置也会有所不同
