STM32F0的system_stm32f0xx.c文件发现官方格式不同。为什么
whb565938 提问时间:2012-11-20 14:19 /
研讨会光盘目录stm32f0discovery_fw下的system_stm32f0xx.c文件关键点如下:
#define PLL_SOURCE_HSI        // HSI (~8MHz) used to clock the PLL, and the PLL is used as system clock source
//#define PLL_SOURCE_HSE        // HSE (8MHz) used to clock the PLL, and the PLL is used as system clock source
//#define PLL_SOURCE_HSE_BYPASS // HSE bypassed with an external clock (8MHz, coming from ST-Link) used to clock
 static void SetSysClock(void)
  __IO uint32_t StartUpCounter = 0, HSEStatus = 0;
  /* SYSCLK, HCLK, PCLK configuration ----------------------------------------*/
#if defined (PLL_SOURCE_HSI)
  /* At this stage the HSI is already enabled */
  /* Enable Prefetch Buffer and set Flash Latency */
  FLASH->ACR = FLASH_ACR_PRFTBE | FLASH_ACR_LATENCY;
  /* HCLK = SYSCLK */
  RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
  /* PCLK = HCLK */
  RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE_DIV1;
  /* PLL configuration = (HSI/2) * 12 = ~48 MHz */
  RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL));
  RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSI_Div2 | RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLMULL12);
  /* Enable PLL */
  RCC->CR |= RCC_CR_PLLON;
  /* Wait till PLL is ready */
  while((RCC->CR & RCC_CR_PLLRDY) == 0)
  /* Select PLL as system clock source */
  RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
  RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
  /* Wait till PLL is used as system clock source */
  while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)RCC_CFGR_SWS_PLL)
#else
 #if defined (PLL_SOURCE_HSE)
  /* Enable HSE */
  RCC->CR |= ((uint32_t)RCC_CR_HSEON);
 #elif defined (PLL_SOURCE_HSE_BYPASS)
  /* HSE oscillator bypassed with external clock */
  RCC->CR |= (uint32_t)(RCC_CR_HSEON | RCC_CR_HSEBYP);
 #endif /* PLL_SOURCE_HSE */
  /* Wait till HSE is ready and if Time out is reached exit */
  do
    HSEStatus = RCC->CR & RCC_CR_HSERDY;
    StartUpCounter++;
  } while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
  if ((RCC->CR & RCC_CR_HSERDY) != RESET)
    HSEStatus = (uint32_t)0x01;
  else
    HSEStatus = (uint32_t)0x00;
  if (HSEStatus == (uint32_t)0x01)
    /* HCLK = SYSCLK */
    /* PCLK = HCLK */
    /* PLL configuration = HSE * 6 = 48 MHz */
    RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_PREDIV1 | RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLMULL6);
    /* Enable PLL */
  else
  { /* If HSE fails to start-up, the application will have wrong clock
         configuration. User can add here some code to deal with this error */
#endif /* PLL_SOURCE_HSI */
研讨会光盘目录STM32F0xx_StdPeriph_Lib_V1.0.0、下的system_stm32f0xx.c文件关键点如下:
/*            PLL (clocked by HSE) used as System clock source                */
  /* Enable HSE */
  do
    StartUpCounter++;
  else
    /* HCLK = SYSCLK */
    /* PCLK = HCLK */
    /* PLL configuration */
    /* Enable PLL */
  else
大家,第一个模版下的system_stm32f0xx.c里面比第二个样例模版多出了,时钟源部分,第一个是用宏定义选择内部和外部时钟。第二个直接是外部时钟。这两个模版的system_stm32f0xx.c文件不同,这两个模版有区别吗?恳请大哥指点
赞 收藏 评论0 发布时间:2012-11-20 14:19
