void NRF24L01_Configuration(void) { GPIO_InitTypeDef GPIO_InitStructure; RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA,ENABLE); // RCC_APB2PeriphClockCmd(RCC_NRF24L01_CE, ENABLE); //ʹÄÜGPIOµÄʱÖÓ GPIO_InitStructure.GPIO_Pin = NRF24L01_CE; //NRF24L01 Ä£¿éƬѡÐźŠGPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT; //ÍÆÍìÊä³ö GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; GPIO_Init(GPIO_NRF24L01_CE, &GPIO_InitStructure); // RCC_APB2PeriphClockCmd(RCC_NRF24L01_CSN, ENABLE); //ʹÄÜGPIOµÄʱÖÓ GPIO_InitStructure.GPIO_Pin = NRF24L01_CSN; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT; //ÍÆÍìÊä³ö GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; GPIO_Init(GPIO_NRF24L01_CSN, &GPIO_InitStructure); Set_NRF24L01_CE; Set_NRF24L01_CSN; //ÅäÖÃNRF2401µÄIRQ GPIO_InitStructure.GPIO_Pin = NRF24L01_IRQ; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN ; //ÉÏÀÊäÈë GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; GPIO_Init(GPIO_NRF24L01_IRQ, &GPIO_InitStructure); GPIO_SetBits(GPIO_NRF24L01_IRQ,NRF24L01_IRQ); SPI1_Configuration(); //³õʼ»¯SPI Clr_NRF24L01_CE; //ʹÄÜ24L01 Set_NRF24L01_CSN; //SPIƬѡȡÏû } void SPI1_Configuration(void) { SPI_InitTypeDef SPI_InitStructure; GPIO_InitTypeDef GPIO_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1,ENABLE); RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA,ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7 ; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; GPIO_Init(GPIOA, &GPIO_InitStructure); GPIO_PinAFConfig(GPIOA,GPIO_PinSource5|GPIO_PinSource6|GPIO_PinSource7,GPIO_AF_0);//Á¬½Óµ½ÍâÉè // GPIO_SetBits(GPIOA,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7); GPIO_ResetBits(GPIOA, GPIO_Pin_1); // SPI_I2S_DeInit(SPI1); SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex; //ÉèÖÃSPIµ¥Ïò»òÕßË«ÏòµÄÊý¾Ýģʽ:SPIÉèÖÃΪ˫ÏßË«Ïòȫ˫¹¤ SPI_InitStructure.SPI_Mode = SPI_Mode_Master; //ÉèÖÃSPI¹¤×÷ģʽ:ÉèÖÃΪÖ÷SPI SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; //ÉèÖÃSPIµÄÊý¾Ý´óС:SPI·¢ËͽÓÊÕ8λ֡½á¹¹ SPI_InitStructure.SPI_CPOL = SPI_CPOL_High; //Ñ¡ÔñÁË´®ÐÐʱÖÓµÄÎÈ̬:ʱÖÓÐü¿Õ¸ß SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge; //Êý¾Ý²¶»ñÓÚµÚ¶þ¸öʱÖÓÑØ SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; //NSSÐźÅÓÉÓ²¼þ£¨NSS¹Ü½Å£©»¹ÊÇÈí¼þ£¨Ê¹ÓÃSSI룩¹ÜÀí:ÄÚ²¿NSSÐźÅÓÐSSIλ¿ØÖÆ SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_8; //¶¨Òå²¨ÌØÂÊÔ¤·ÖƵµÄÖµ:²¨ÌØÂÊÔ¤·ÖƵֵΪ256 SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; //Ö¸¶¨Êý¾Ý´«Êä´ÓMSBλ»¹ÊÇLSBλ¿ªÊ¼:Êý¾Ý´«Êä´ÓMSBλ¿ªÊ¼ SPI_InitStructure.SPI_CRCPolynomial = 7; //CRCÖµ¼ÆËãµÄ¶àÏîʽ SPI_RxFIFOThresholdConfig(SPI1,SPI_RxFIFOThreshold_QF);//ÅäÖà SPI µÄ FIFO ½ÓÊÕãÐÖµ(½ÓÊÕ8bits¾ÍÖà SPI_I2S_FLAG_RXNE) SPI_Init(SPI1, &SPI_InitStructure); //¸ù¾ÝSPI_InitStructÖÐÖ¸¶¨µÄ²ÎÊý³õʼ»¯ÍâÉèSPIx¼Ä´æÆ÷ SPI_Cmd(SPI1, ENABLE); //ʹÄÜSPIÍâÉè // SPI1_ReadWriteByte(0xff); GPIO_SetBits(GPIOA, GPIO_Pin_1); } u8 SPI1_ReadWriteByte(u8 TxData) //SPI¶ÁдÊý¾Ýº¯Êý { while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET); SPI_SendData8(SPI1, TxData); // SPI_I2S_SendData16(SPI1, TxData); while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET); return SPI_ReceiveData8(SPI1); // return SPI_I2S_ReceiveData16(SPI1); } 各位大神看看哪里出问题了啊! |
请都大神--STM32F072CB芯片开启HSI48时钟问题
谁能解释一下STM32F0的RTC_IRQHandler中断中EXTI_Line17的作用?
【STM32F0开发日志/评测/笔记】+互补PWM波的产生
STM32F030 PB14和PB15无法输出PWM求助
【STM32F030探索套件】序列之五 外部中断
【STM32F0开发日志---二】+ucosii.2.92移植在STM32F030
上传个STM32F0+5110+内部温度传感器的菜鸟实例
【STM32F030探索套件使用问题】STM32F030 SPI方式驱动ST7565LCD失败
求一份STM32F051 I2C驱动LCD 12864的例程
STM32F0 M0 向结构体赋值进入HardFault异常
与这也有关系啊?看很多程序都是这样写的啊
我现在在移植程序,需要050的例程,您有吗?
RE:STM32F030 的SPI问题
RE:STM32F030 的SPI问题
RE:STM32F030 的SPI问题
RE:STM32F030 的SPI问题
RE:STM32F030 的SPI问题
改成分开配置试试。
GPIO_PinAFConfig(GPIOA,GPIO_PinSource5,GPIO_AF_0);
GPIO_PinAFConfig(GPIOA,GPIO_PinSource6,GPIO_AF_0);
GPIO_PinAFConfig(GPIOA,GPIO_PinSource7,GPIO_AF_0);
因为官网库函数例程还是其它,没有见合并配置
GPIO_NRF24L01_CSN
GPIO_NRF24L01_CE
GPIO_NRF24L01_IRQ
是不是GPIOA呢,没见宏定义,若否,换成 GPIOA
回复:STM32F030 的SPI问题
GPIO_PinAFConfig(GPIOA,GPIO_PinSource5|GPIO_PinSource6|GPIO_PinSource7,GPIO_AF_0); 为什么不分开映射。
分开还是没效果啊!
回复:STM32F030 的SPI问题
看了一下,其它配置没什么问题,下面这一句
改成分开配置试试。
GPIO_NRF24L01_CSN
GPIO_NRF24L01_CE
GPIO_NRF24L01_IRQ
是GPIOA ,上面分开配置了也没有用!
回复:STM32F030 的SPI问题
你那出的是什么问题?建议看一下你的.h文件定义的芯片类型。
那个H文件的定义啊?
RE:STM32F030 的SPI问题
回复:STM32F030 的SPI问题
SPI在时钟的边沿进行采样,所以在时钟的边沿,MOSI应该保持一段时间;另外循环中应该有一定的延时.楼主的程序具体是哪些方面报错呢?
程序没有报错,就是通不过NRF24L01的硬件检测,说明SPI没有配置成功,还有就是现在我用的MDK4.72没有 030的单片机,型号只能用STM32F050的代替,所以debug调试进步去!
RE:STM32F030 的SPI问题
RE:STM32F030 的SPI问题
回复:STM32F030 的SPI问题
调试一下啊,这个新的芯片能调试么?
我用的是MDK4.72a 不能调试030
回复:STM32F030 的SPI问题
