STM32F030 SPI配置IO口复用功能
yougen3344 提问时间:2014-1-20 22:57 /
配置SPI功能,一旦配置:
后就进入了硬件错误,也就是进入这个函数:
QQ截图20140120225146.jpg ,
具体来说就是在配置第二个复用功能时进入的硬件错误,我把后面两个复用功能配置屏蔽掉就可以正常跑起来,不进入硬件错误,,,
这是神马情况???想知道有木有小伙伴遇到相同的情况?????欢迎各种指导。。。
继续阅读原创汇总:
STM32F030探索套件开发日志,中文教程,使用问答80篇
赞 收藏 评论9 发布时间:2014-1-20 22:57
9个回答
axiulo118 回答时间:2014-1-20 23:34:57
回复:STM32F030 SPI配置IO口复用功能
请注意void GPIO_PinAFConfig(GPIO_TypeDef* GPIOx, uint16_t GPIO_PinSource, uint8_t GPIO_AF);是GPIO_PinSource哦,上语句应改为GPIO_PinAFConfig(GPIOB, GPIO_PinSource13, GPIO_AF_0);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource14, GPIO_AF_0);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource15, GPIO_AF_0);你可以看一下头文件里面的GPIO_Pin 和 GPIO_PinSource定义是不一样的
axiulo118 回答时间:2014-1-20 23:36:53
我也遇到过这个问题,检查了好久才搞明白,自己太脑残了
lkl0305 回答时间:2014-1-21 07:55:17
RE:STM32F030 SPI配置IO口复用功能
是呀,这就是要仔细阅读库文件了
lkl0305 回答时间:2014-1-21 07:58:24
是呀,这就是要仔细阅读库文件了
#define  GPIO_PinSource0   ((uint8_t)0x00)
#define  GPIO_PinSource1   ((uint8_t)0x01)
#define  GPIO_PinSource10   ((uint8_t)0x0A)
#define  GPIO_PinSource11   ((uint8_t)0x0B)
#define  GPIO_PinSource12   ((uint8_t)0x0C)
#define  GPIO_PinSource13   ((uint8_t)0x0D)
#define  GPIO_PinSource14   ((uint8_t)0x0E)
#define  GPIO_PinSource15   ((uint8_t)0x0F)
#define  GPIO_PinSource2   ((uint8_t)0x02)
#define  GPIO_PinSource3   ((uint8_t)0x03)
#define  GPIO_PinSource4   ((uint8_t)0x04)
#define  GPIO_PinSource5   ((uint8_t)0x05)
#define  GPIO_PinSource6   ((uint8_t)0x06)
#define  GPIO_PinSource7   ((uint8_t)0x07)
#define  GPIO_PinSource8   ((uint8_t)0x08)
#define  GPIO_PinSource9   ((uint8_t)0x09)
#define  GPIO_Pin_0   ((uint16_t)0x0001)
#define  GPIO_Pin_1   ((uint16_t)0x0002)
#define  GPIO_Pin_10   ((uint16_t)0x0400)
#define  GPIO_Pin_11   ((uint16_t)0x0800)
#define  GPIO_Pin_12   ((uint16_t)0x1000)
#define  GPIO_Pin_13   ((uint16_t)0x2000)
#define  GPIO_Pin_14   ((uint16_t)0x4000)
#define  GPIO_Pin_15   ((uint16_t)0x8000)
#define  GPIO_Pin_2   ((uint16_t)0x0004)
#define  GPIO_Pin_3   ((uint16_t)0x0008)
#define  GPIO_Pin_4   ((uint16_t)0x0010)
#define  GPIO_Pin_5   ((uint16_t)0x0020)
#define  GPIO_Pin_6   ((uint16_t)0x0040)
#define  GPIO_Pin_7   ((uint16_t)0x0080)
#define  GPIO_Pin_8   ((uint16_t)0x0100)
#define  GPIO_Pin_9   ((uint16_t)0x0200)
#define  GPIO_Pin_All   ((uint16_t)0xFFFF)
废鱼 回答时间:2014-1-21 09:52:15
楼上几位解释正确。
有缘于你 回答时间:2014-1-21 14:11:30
以后先看看例程,常用外设都有官方例程的
yougen3344 回答时间:2014-1-22 15:04:03
回复第 2 楼 于2014-01-20 23:34:57发表:
奥。。。原来是酱紫,,,太脑残了。。。
leitianyilty 回答时间:2014-6-18 16:10:01
look啊啊啊 啊
jumping1967 回答时间:2014-10-1 21:04:28
