设计目的:实现一个可以控制的U盘 USB口选用高速口,MSC选用SD卡(我用的eMMC) 设计思路:选择标准的历程MSC当做基础历程,U盘的功能就实现了,那么怎么做一个HID上去呢,就是修改描述符了,做一个复合设备的描述符,将HID历程的一些必须函数拼接到MSC里面,做好了设备驱动怎么弄呢,我也不会写 ,但是我安装了NI VISA 可以自己生成驱动文件,再用LABVIEW在线编程。8 l% q# [2 U& ]7 L1 G _ALIGN_BEGIN uint8_t USBD_MSC_CfgDesc[USB_MSC_CONFIG_DESC_SIZ] __ALIGN_END = { " n+ O! L$ T. f) |+ ^ 0x09, /* bLength: Configuation Descriptor size */4 Z! l, t$ E# g v( N; r% | USB_DESC_TYPE_CONFIGURATION, /* bDescriptorType: Configuration */. O& v0 m& V! P% \: ^ USB_MSC_CONFIG_DESC_SIZ, 0x00,9 q: k, f/ v' F2 p5 I! R 0x02, /* bNumInterfaces: 1 interface 既然是复合设备就应该有两个端口*/! F7 G7 H+ ^1 ^# i 0x01, /* bConfigurationValue: */ 0x04, /* iConfiguration: */2 L8 v# k' R$ M, v0 o! q! ? 0xC0, /* bmAttributes: */ 0x64, /* MaxPower 100 mA */9 |% ]. u2 R( P5 E! O& {: _ /************** Descriptor of Joystick Mouse interface ****************/# U& O0 j2 h6 u- ` B- _3 J /* 09 */ 0x09, /*bLength: Interface Descriptor size*/( e ^! }! Q, P1 [& K USB_INTERFACE_DESCRIPTOR_TYPE,/*bDescriptorType: Interface descriptor type*/# Q" @# d# n! e! ~' o2 r1 L N 0x00, /*bInterfaceNumber: Number of Interface*/ 0x00, /*bAlternateSetting: Alternate setting*/! w' W; s5 W( X! _ 0x02, /*bNumEndpoints*/$ _) W( U' e) ~+ m/ b( P 0x03, /*bInterfaceClass: HID*/ 0x00, /*bInterfaceSubClass : 1=BOOT, 0=no boot*/ 0x00, /*nInterfaceProtocol : 0=none, 1=keyboard, 2=mouse*/1 Z: F7 D+ t- n: V V 0, /*iInterface: Index of string descriptor*/8 m2 K& R: v. j ^' |$ a* X# h /******************** Descriptor of Joystick Mouse HID ********************/% D7 c% y/ M$ q2 E" v5 W5 d( ~- z1 o /* 18 */ 0x09, /*bLength: HID Descriptor size*/ HID_DESCRIPTOR_TYPE, /*bDescriptorType: HID*/' D8 P' n1 m+ f2 T1 M9 w1 j' I* D3 {. _ 0x11, /*bcdHID: HID Class Spec release number*/2 i" c/ I1 g" b3 j 0x01,$ x" | g/ q7 z 0x00, /*bCountryCode: Hardware target country*/ 0x01, /*bNumDescriptors: Number of HID class descriptors to follow*/4 l4 ~! L: [( I) q6 u- y 0x22, /*bDescriptorType*/ 33,/*wItemLength: Total length of Report descriptor*/ 0x00,% _: F% Y# C2 P( C. @; V /******************** Descriptor of Mouse endpoint ********************/ /* 27 */) {8 k+ R) b0 @# S 0x07, /*bLength: Endpoint Descriptor size*/5 n" w t# ~7 B$ J USB_ENDPOINT_DESCRIPTOR_TYPE, /*bDescriptorType:*/! ^' @/ s) [. g$ _# i$ o - [0 F+ x: ?- V. E+ f HID_IN_EP, /*bEndpointAddress: Endpoint Address (IN)*/3 f8 d6 J m ?3 R6 U: l 0x02, /*bmAttributes: Interrupt endpoint*/ HID_IN_PACKET, /*wMaxPacketSize: 64 Byte max */ 0x00, 0x0A, /*bInterval: Polling Interval (10 ms)*/ /* 34 */ 0x07, /*bLength: Endpoint Descriptor size*/- o3 _7 y, w, T3 I USB_ENDPOINT_DESCRIPTOR_TYPE, /*bDescriptorType:*/ u% q' T2 B$ h ) x: F- C' e' D) X9 p HID_OUT_EP, /*bEndpointAddress: Endpoint Address (IN)*/ 0x02, /*bmAttributes: Interrupt endpoint*/ HID_IN_PACKET, /*wMaxPacketSize: 64 Byte max */ 0x00, 0x0A, /*bInterval: Polling Interval (10 ms)*/ /*41*/' R. U9 Q9 { l/ y /******************** Mass Storage interface ********************/* L3 g% ~) | t$ o0 Y. ~ 0x09, /* bLength: Interface Descriptor size */8 i" R9 U- R( l# C0 p. M8 n 0x04, /* bDescriptorType: */ 0x01, /* bInterfaceNumber: Number of Interface */ 0x00, /* bAlternateSetting: Alternate setting */0 d0 D+ A% s' E; ]4 M; W/ V; @ 0x02, /* bNumEndpoints*/# l0 P5 L" S5 D5 B# r" H5 h 0x08, /* bInterfaceClass: MSC Class */ 0x06, /* bInterfaceSubClass : SCSI transparent*/+ X0 ~, G6 V0 L) L" ` 0x50, /* nInterfaceProtocol */ 0x05, /* iInterface: */ /******************** Mass Storage Endpoints ********************/: Y6 u' a7 G# | 0x07, /*Endpoint descriptor length = 7*/' u8 a# l3 d6 @- q/ G1 j 0x05, /*Endpoint descriptor type */ MSC_IN_EP, /*Endpoint address (IN, address 1) */% v; c& u9 \+ _ a1 k9 d 0x02, /*Bulk endpoint type */5 l7 Y% j0 j+ `5 e- j LOBYTE(MSC_MAX_PACKET), HIBYTE(MSC_MAX_PACKET),4 n- n3 I1 C5 ]2 X 0x00, /*Polling interval in milliseconds */ 0x07, /*Endpoint descriptor length = 7 */ 0x05, /*Endpoint descriptor type */ MSC_OUT_EP, /*Endpoint address (OUT, address 1) */9 x Q$ ~ G& [( t& A 0x02, /*Bulk endpoint type */+ ~) A! k2 E' I& v, Z1 d LOBYTE(MSC_MAX_PACKET), HIBYTE(MSC_MAX_PACKET),1 j2 H s) ]) S r' L8 A5 s 0x00, /*Polling interval in milliseconds*/ }; E: \2 J% J( z; R 3 |7 R7 Y7 k) \" R6 [4 v% y% @ 在usb_conf.h里; {# Y: q8 p& D* y/ l7 J3 S #define USBD_CFG_MAX_NUM 1) w' L# c" E/ d, _1 z4 m3 ~; F) O #define USBD_ITF_MAX_NUM 1 #define USB_MAX_STR_DESC_SIZ 64 + R- o& E6 C0 X. v) L# u #define USBD_SELF_POWERED /* Class Layer Parameter */ / J" i. y5 @7 d: W# @' c1 I1 c #define MSC_IN_EP 0x82 /// 用于U盘 #define MSC_OUT_EP 0x02 /// 用于U盘$ t2 Y d* ^: d #ifdef USE_USB_OTG_HS , T# {6 [& C# B( i #ifdef USE_ULPI_PHY #define MSC_MAX_PACKET 512! P' I6 j/ m# r. d& f1 k" n #else7 H6 |) }9 A! ^ #define MSC_MAX_PACKET 64$ A: x# h, p- T* }/ J) m& w #endif #else /*USE_USB_OTG_FS*/6 d M+ K( F' ~ z8 F+ U #define MSC_MAX_PACKET 64 #endif, j$ A f0 K) K5 }$ P1 _# ` #define HID_IN_EP 0x81 用于控制( B; M0 v- Z# ^) Z+ v #define HID_OUT_EP 0x01 用于控制: D) r7 D# T6 U0 v h , s' i& }- ?0 d# b) V/ Q0 z: K2 _ #define HID_IN_PACKET 0x40 #define HID_OUT_PACKET 0x407 e, J# N) E. w7 h. | #define MSC_MEDIA_PACKET 4096 添加相应的端口定义9 g/ z5 g+ k) p* N4 T( @ 将HID历程的一些必须函数拼接到MSC里面 QQ:393441746- U! D. ?4 p( j4 N' d. y2 y* Y 欢迎一起交流STM32的知识,我使用过103 407 030& g/ Q6 Z5 p2 R4 x 或者直接在帖子里讨论 我常来的 库函数加快了我的开发 你还在使用串口吗,像当年玩串口一样使用USB 将是不一样的体验目前自己创业在做PM2.5传感器 http://shop144438126.taobao.com/?spm=a1z10.1-c.0.0.A2q64T ; w2 x# c" {" D0 W |
【福利三:雨露均沾·逢7狂欢】之四:用一个定时器同步另外两个定时器输出PWM
【逢7发帖赢大礼】STM32开发之WIFI实时时钟
【逢7发帖赢大礼】STM32开发之指纹识别!
【逢7发帖赢大礼】STM32开发之环境空气质量监测
【逢7发帖赢大礼】STM32开发之人体实时运动信息监测!
【逢7发帖赢大礼】全网最简单的Arduino_STM32开发环境搭建教程!
STM32F4中文用户手册
STM32F400、STM32F402 Cortex-M4超值单片机
最全USB HID开发资料,悉心整理一个月,亲自测试
RE:【MCU实战经验】+STM32F407=USB符合设备(HID+MSC)
回复:【MCU实战经验】+STM32F407=USB符合设备(HID+MSC)
在windows下,这个需要做驱动么?
我说了 用NI VISA 再用labview 操作 如果会C++的可以自己写一个4 p' e; s8 ?. C1 S* e& \
但是,你要实现的是什么功能呢?能够识别就说明驱动已经识别成功了。你再做的应该是app,而不是driver了吧?不过用labview可能要装它自己另外做的驱动,而不用windows的通用驱动了。关键还是不知道你要实现啥功能,开始我以为是一个既当鼠标又当优盘的实现 % W) l2 P& J2 `# n, d* I
* ] S l- {+ s: c: l: E$ U- ]% q
我在里面配置时间 配置校准参数 配置采样率 配置等等 做成数据记录仪
你好,楼主,你的usb存储设备的程序是什么写的,可以参考一下吗- R* }/ u& D3 W b% x; m9 j+ h
5 m/ w* ^( B* G: L7 v4 _0 T6 D5 b
- a/ T8 Y! F+ L. W' S( F9 Z2 v4 B
keil 项目应用 不好意思
你好,楼主,你的usb存储设备的程序是什么写的,可以参考一下吗% H$ \6 a' i& v8 N& M9 Z+ y9 }
就这块描述符比较重要 剩下的没多大改动 在官方驱动上修改, k% k+ k9 F1 X+ \( f# R
