STM32F030C8的spi问题
z32437089 提问时间:2014-8-26 23:08 /
 大家好,调试STM32F030C8的时候出现问题,一直无法解决
SPI工作模式,从机状态下发送数据,数据帧大小8 Bits,时钟来源来自自身TIM1CH2产生的PWM。
SPI1的CS接GND,CLK接PA9(TIM1_CH2)
问题描述,从机发送数据,用逻辑分析仪捕捉发现与发送的不符,好像是错位的感觉。
SPI初始化部分
  • void spiinit()
  • GPIO_InitTypeDef GPIO_InitStructure;
  • SPI_InitTypeDef SPI_InitStructure;
  • SPI_I2S_DeInit(SPI1);
  • RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA,ENABLE);
  • GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7;
  • GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  • GPIO_InitStructure.GPIO_Speed = GPIO_Speed_Level_3;  //IO速度50MHZ
  • GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  • GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_DOWN;
  • GPIO_Init(GPIOA, &GPIO_InitStructure);
  • GPIO_PinAFConfig(GPIOA, GPIO_PinSource7, GPIO_AF_0);
  • GPIO_PinAFConfig(GPIOA, GPIO_PinSource6, GPIO_AF_0);
  • GPIO_PinAFConfig(GPIOA, GPIO_PinSource5, GPIO_AF_0);
  • RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1,ENABLE);
  • SPI_InitStructure.SPI_Direction = SPI_Direction_1Line_Tx;  //单线发送模式
  • SPI_InitStructure.SPI_Mode = SPI_Mode_Slave;                  //从机模式
  • SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;           //数据帧8Bits
  • SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;                  //空闲时钟状态低电平
  • SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;               //第一个边缘改变数值
  • SPI_InitStructure.SPI_NSS = SPI_NSS_Hard;
  • // SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_64;
  • SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
  • // SPI_InitStructure.SPI_CRCPolynomial = 7;
  • SPI_Init(SPI1, &SPI_InitStructure);
  • SPI_RxFIFOThresholdConfig(SPI1, SPI_RxFIFOThreshold_QF);
  • //SPI_CalculateCRC(SPI1, DISABLE);
  • SPI_Cmd(SPI1, ENABLE);
  • void send8(uint8_t dat)
  • while(!(SPI1->SR & SPI_SR_TXE));         //等待直到发送缓存区为空
  • *(__IO uint8_t *) (0x4001300C)=dat;  // 0x4001300C为 SPI1->DR偏移地址
  • TIM1->CCR2=Channel2Pulse;//使能PWM输出占空比50%
  • void main(void)
  • volatile uint32_t i;
  • SystemInit();
  • spiint();
  • while(1)
  •      for (i = 0; i < 0x055ff; i++);//delay
  • send8(0x01);send8(0x03);send8(0x07);send8(0x0f);  //循环发送01,03,07,0F
  • TIM1->CCR2=0;//change duty to 0,change clk to low level也就是disable spi clk
[color=#000099 !important]复制代码
程序循环发送01,03,07,0F,得到的数据不对。看逻辑分析仪捕捉。
发现好像是最后10个BIT的前8个BIT剪下来放到最前面就对了。实在搞不清什么问题了,就这么一个问题反反复复搞了好几天了还是这样。
各路大神请指导一下,ST的FAE也请帮帮忙,在此感谢
赞 收藏 评论4 发布时间:2014-8-26 23:08
4个回答
废鱼 回答时间:2014-8-27 09:11:08
RE:STM32F030C8的spi问题
为什么CS不用SPI模块本身自带的?建议先发送clk,然后再发送数据
z32437089 回答时间:2014-8-27 09:33:39
回复:STM32F030C8的spi问题
回复第 2 楼 于2014-08-27 09:11:08发表:
谢谢,试了一下,还是跟以前一样,想想也应该没什么区别,从机模式发送,没有CLK,缓存区里面的数据不会发送的
废鱼 回答时间:2014-8-27 11:04:41
从机模式,主机会提供CLK的。
z32437089 回答时间:2014-8-27 12:32:41
回复第 4 楼 于2014-08-27 11:04:41发表:
从机模式,主机会提供CLK的。
我没有主机,因为需要同步,所以必须使用从机模式由TIM提供CLK,这个CLK还有其他用途
用在主机模式时发送的数据是正确的,用从机对外发送就不对,就相当于当主机读我这个SPI口的时候,我返回的数据乱码错误。
