看Freertos头文件Semphr.h的注释。 : P1 S0 n% ?' S2) Resource management. - S" L0 ^! V8 m* g0 h. p. z9 O% Z* In this usage scenario the count value indicates the number of resources/ F0 ^$ Y$ }9 T, H
* available. To obtain control of a resource a task must first obtain a & F! L& I, O2 ~' y( U4 |9 A * semaphore - decrementing the semaphore count value. When the count value + g- q" T2 w8 a6 l * reaches zero there are no free resources. When a task finishes with the . y' O$ A. }# Q2 s `% `7 k * resource it 'gives' the semaphore back - incrementing the semaphore count 6 q' y4 |) Y. h. g4 W, ? * value. In this case it is desirable for the initial count value to be; P4 x: U& o" }
* equal to the maximum count value, indicating that all resources are free.
刚刚贴的代码怎么不见了?再贴一遍头文件中的注释,很明了:$ h, t0 _: W2 p+ w2 v2 X
* Counting semaphores are typically used for two things:0 x( C1 K; D! U5 H J# w
*2 ~8 F5 u- R5 |$ B
* 1) Counting events. . F+ P/ \( L z5 j4 R- y$ ?, ~ * $ g- Q( Z1 A2 Q0 F d7 } * In this usage scenario an event handler will 'give' a semaphore each time# G- v* [ k3 W0 ^" r
* an event occurs (incrementing the semaphore count value), and a handler0 ?6 s* \2 w" ~+ P3 A+ H& e
* task will 'take' a semaphore each time it processes an event1 [ r3 @2 |9 F
* (decrementing the semaphore count value). The count value is therefore6 }' g$ \ I; J, I3 _2 H D* [
* the difference between the number of events that have occurred and the3 b. h. r4 C6 k% Z: P U
* number that have been processed. In this case it is desirable for the- _& c) D8 T4 V2 Q: B
* initial count value to be zero.! r6 q% N/ Y/ d0 H
*: t9 |( J- F0 _2 i
* 2) Resource management.- Q) Q6 L2 K- K- p5 V% E* ~+ @+ W
*/ W# C$ _3 K3 ~3 S8 d
* In this usage scenario the count value indicates the number of resources 6 V' O6 I: _2 [# w4 u) u( E * available. To obtain control of a resource a task must first obtain a- C8 O& y' y5 T3 Y5 p
* semaphore - decrementing the semaphore count value. When the count value 9 i' g- A" z5 T; f- u7 N * reaches zero there are no free resources. When a task finishes with the: S* g" \. w% x# {
* resource it 'gives' the semaphore back - incrementing the semaphore count - Y2 @$ K( k% X& R+ Z8 R8 b * value. In this case it is desirable for the initial count value to be+ H7 o7 g0 u, G" U' N0 t- I6 M
看帖 应该 就知道很好用了 基本上 点几下鼠标就创建一个可以直接使用的 工程
那只是可用,效率怎么样呢
本人建议 库只用于 比较复杂的 外设初始化 比如 串口 ,SPI SDIO等等
初始化完成之后的操作 建议使用寄存器
*2 ~8 F5 u- R5 |$ B
*: t9 |( J- F0 _2 i
是的 因为我的 资源一开始是不可用的 ) ^% ]1 ]1 n& r ]" f
5 q% i* ^! T8 [ O/ A2 ]! M$ H: ^
这是典型的 生产消费问题
$ C; ?& i% P# u$ H# Z4 J" I
串口接收数据(生产) . Y' T7 Y6 w# D9 y
: u9 U3 m0 ~! e' A$ _ Q# f; }
线程消费数据 9 ] q1 ]- r! B% a' Z
8 U: Z: e, q7 [% U* i
一开始是没有现成的数据的
a6 c8 O! `# C- w$ b' J8 y
而这个 函数接口 只能以另一种方式使用那就是一开始就存在资源,这在实际使用中是不合理的!!
哈哈 你来晚了钱都被他们拿完了~~
