/* MAIN.C file * * Copyright (c) 2002-2005 STMicroelectronics */ #include <stm8s003f3.h> // - - 定义函数 #define BIAS 0x52 //0b1000 0101 0010 1/3duty 4com #define SYSDIS 0X00 //0b1000 0000 0000 关振系统荡器和LCD偏压发生器 #define SYSEN 0X02 //0b1000 0000 0010 打开系统振荡器 #define LCDOFF 0X04 //0b1000 0000 0100 关LCD偏压 #define LCDON 0X06 //0b1000 0000 0110 打开LCD偏压 #define XTAL 0x28 //0b1000 0010 1000 外部接时钟 #define RC256 0X30 //0b1000 0011 0000 内部时钟 #define TONEON 0X12 //0b1000 0001 0010 打开声音输出 #define TONEOFF 0X10 //0b1000 0001 0000 关闭声音输出 #define WDTDIS 0X0A //0b1000 0000 1010 禁止看门狗 #define WDTDIS 0X0A unsigned int b,v,v1,i,miao,fen,shi,e,f,yu; unsigned char m,n,m1,n1,miaodian; unsigned int flag,year,month,day,hour,min,a,keytime,set; unsigned char Ht1621wTab[]={0x0b,0x00,0x07,0x05,0x0c,0x0d,0x0f,0x00,0x0f,0x0d}; //seg 16 unsigned char Ht1621cTab[]={0x0f,0x07,0x0d,0x0f,0x07,0x0b,0x0b,0x0f,0x0f,0x0f}; //seg 17 unsigned char Ht1621dTab[]={0x0e,0x06,0x0c,0x0e,0x06,0x0a,0x0a,0x0e,0x0e,0x0e}; //seg 17 unsigned char Ht1621eTab[]={0x00,0x0a,0x0d,0x0e}; _Bool CS @PC_ODR:5; _Bool WR @PC_ODR:6; _Bool DAT @PC_ODR:7; _Bool SCLK @PD_ODR:4; _Bool SDA @PD_ODR:5; _Bool RST @PD_ODR:6; _Bool k1 @PB_IDR:4; _Bool k2 @PC_IDR:3; _Bool k3 @PC_IDR:4; //HT1621控制位(液晶模块接口定义,根据自已的需要更改) #define CLS_HT_WR WR = 0 //拉低 #define SET_HT_WR WR = 1 //拉高 #define CLS_HT_CS CS = 0 //拉低 #define SET_HT_CS CS = 1 //拉高 #define SET_HT_DAT DAT= 1 //数据位 #define CLS_HT_DAT DAT = 0 //数据位 //GPIO口设置 void port_init(void) { PB_DDR |= 0x20; PB_CR1 |= 0x20; PB_CR2 |= 0x00; PD_DDR |= 0x74; PD_CR1 |= 0x04; PD_CR2 |= 0x00; PC_DDR |= 0xe0; PC_CR1 |= 0xe0; PC_CR2 |= 0x00; } void Init(void) { // CLK_ICKR |= 0x01; //打开内部高速RC //CLK_CKDIVR = 0x10; //HSI--4MHZ CLK_CKDIVR = 0x00; } //----------------------------------------------------------------------------------------- //函数名称:Delay() //功 能:延时子程序 //----------------------------------------------------------------------------------------- void Delay(char us) //5,7,9 { while(--us); } //----------------------------------------------------------------------------------------- //函数名称:DelayMS() //功 能:延时子程序 //----------------------------------------------------------------------------------------- void DelayMS(int iMs) { int i,j; for(i=0;i<iMs;i++) for(j=0;j<65;j++) { Delay(1); } } void writebyb(unsigned char temp) { unsigned char i; SCLK=0; Delay(20); for(i=0;i<8;i++) { SDA=temp&0x01; Delay(5); SCLK=1; Delay(5); SCLK=0; temp>>=1; } } void write(unsigned char adress,unsigned char dat) { RST=0; SCLK=0; RST=1; Delay(20); writebyb(adress); writebyb(dat); SCLK=1; RST=0; } unsigned char readbybe(void) { unsigned i,dat; Delay(2); for(i=0;i<8;i++) { dat>>=1; if(SDA==1) { dat|=0x80; } else { dat&=0x7f; } SCLK=1; Delay(5); SCLK=0; Delay(5); } return dat; } unsigned char read(unsigned char adress) { unsigned char temp; RST=0; SCLK=0; RST=1; Delay(1); writebyb(adress); temp=readbybe(); SCLK=1; RST=0; SDA=0; return temp; } void ds1302(void) { write(0x8e,0x00); write(0x80,((0/10)<<4|(0%10))); //根据写秒寄存器命令字,写入秒的初始值 write(0x82,((0/10)<<4|(0%10))); //根据写分寄存器命令字,写入分的初始值 write(0x84,((12/10)<<4|(12%10))); //根据写小时寄存器命令字,写入小时的初始值 write(0x86,((16/10)<<4|(16%10))); //根据写日寄存器命令字,写入日的初始值 write(0x88,((11/10)<<4|(11%10))); //根据写月寄存器命令字,写入月的初始值 write(0x8c,((8/10)<<4|(8%10))); //根据写小时寄存器命令字,写入小时的初始值 write(0x8e,0x80); } void settime(void) { unsigned char ReadValue; ReadValue = read(0x81); //从秒寄存器读数据 miao=((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F);//将读出数据转化 ReadValue = read(0x83); //从分寄存器读 min=((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F); //将读出数据转化 ReadValue = read(0x85); //从分寄存器读 hour=((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F); //将读出数据转化 ReadValue = read(0x87); //从分寄存器读 day=((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F); //将读出数据转化 ReadValue = read(0x89); //从分寄存器读 month=((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F); //将读出数据转化 ReadValue = read(0x8d); //从分寄存器读 year=((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F); //将读出数据转化 } ------------------------------------------------------------------------------------ void Ht1621_Init(void) { SET_HT_CS;//HT1621_CS=1; SET_HT_WR;//HT1621_WR=1; SET_HT_DAT;//HT1621_DAT=1; DelayMS(20); //延时使LCD工作电压稳定 Ht1621WrCmd(BIAS); Ht1621WrCmd(RC256); //使用内部振荡器 Ht1621WrCmd(SYSDIS); Ht1621WrCmd(WDTDIS); Ht1621WrCmd(SYSEN); Ht1621WrCmd(LCDON); Ht1621WrCmd(TONEON); Ht1621WrCmd(TONEOFF); } void dispaytemp(int a) { int ge,shi,bai; bai=a/100; shi=(a-bai*100)/10; ge=a%10; Ht1621WrOneData(0x16,Ht1621wTab[bai]); Ht1621WrOneData(0x15,Ht1621cTab[bai]); Ht1621WrOneData(0x14,Ht1621wTab[shi]); Ht1621WrOneData(0x13,Ht1621cTab[shi]); Ht1621WrOneData(0x12,Ht1621wTab[ge]); Ht1621WrOneData(0x11,Ht1621cTab[ge]); } void dispaytime(int b) { int fge,fshi,sge,sshi; fshi=b/10; fge=b%10; Ht1621WrOneData(0x08,Ht1621cTab[fge]); Ht1621WrOneData(0x09,Ht1621wTab[fge]); Ht1621WrOneData(0x0a,Ht1621dTab[fshi]); Ht1621WrOneData(0x0b,Ht1621wTab[fshi]); } void dispaytime2(int c,int d) { int fge,fshi,sge,sshi; fshi=d/10; fge=d%10; sshi=c/10; sge=c%10; Ht1621WrOneData(0x08,Ht1621cTab[fge]); Ht1621WrOneData(0x09,Ht1621wTab[fge]); Ht1621WrOneData(0x0a,Ht1621cTab[fshi]); Ht1621WrOneData(0x0b,Ht1621wTab[fshi]); Ht1621WrOneData(0x0c,Ht1621cTab[sge]); Ht1621WrOneData(0x0d,Ht1621wTab[sge]); Ht1621WrOneData(0x0e,Ht1621eTab[sshi]); } void dispaynian(int nian,int yue,int ri) { int niange,nianshi,rige,rishi,yueshi,yuege; nianshi=nian/10; niange=nian%10; yueshi=yue/10; yuege=yue%10; rishi=ri/10; rige=ri%10; Ht1621WrOneData(0x1e,Ht1621cTab[nianshi]); Ht1621WrOneData(0x1f,Ht1621wTab[nianshi]); Ht1621WrOneData(0x1c,Ht1621cTab[niange]); Ht1621WrOneData(0x1d,Ht1621wTab[niange]); Ht1621WrOneData(0x19,Ht1621eTab[rishi]); Ht1621WrOneData(0x17,Ht1621cTab[rige]); Ht1621WrOneData(0x18,Ht1621wTab[rige]); if(yueshi==1) { Ht1621WrOneData(0x1a,Ht1621cTab[yuege]); Ht1621WrOneData(0x1b,Ht1621wTab[yuege]); } else { Ht1621WrOneData(0x1a,Ht1621dTab[yuege]); Ht1621WrOneData(0x1b,Ht1621wTab[yuege]); } } void CLK_Init(void) { CLK_CKDIVR = 0x00; } void di(void)//蜂鸣器 { Ht1621WrCmd(TONEON); DelayMS(2000); Ht1621WrCmd(TONEOFF); } void main( void ) { ADC_Init(); ADC_CR1|=0x01; _asm("sim"); CLK_Init(); TIM1_Init(); _asm("rim"); Init(); //时钟初始化 port_init();//GPIO初始化 Ht1621_Init(); //上电初始化LCD ds1302(); DelayMS(50); //延时一段时间 Ht1621WrAllData(); flag=6; while(1) { dispaytemp(b); key(); settime(); } } |
求STM8S105C6T6的安装软件完整版和安装步骤,谢谢!
STM8S003无法检测到引脚电平
STM8 @svlreg 问题
STM8AF62XX+L99PM62GXP LIN通讯的电路原理图有吗?官网提供了一套软件,没找到对应的原理图,请大家指教一下
求一个STM8S207例程
STMS005K6T6 如何采集内部参考电压。
stm8s003 adc中断和通道切换的问题
adc施密特触发器stm8
stm8l051f3 TSSOP20 封装,待机模式下,2天后,电流突然增加到140UA
if(temp&0x01)
SDA=1;
else
SDA=0;
// SDA=temp&0x01;
Delay(5);
SCLK=1;
Delay(5);
SCLK=0;
temp>>=1;
这个底层操作改这样看看
#define __DS1302_CONFIG_H__
#include <stm8s.h>
#include "delay.h"
//PB4 ->SCLK; PB5 ->IO; PC3 ->CE;
// 1:自动转换成10进制 0:BCD格式
#define DS1302_AUTO_TO_DEC 1
// 端口控制命令定义
#define DS1302_IO_0 GPIO_WriteLow(GPIOB,GPIO_PIN_5)
#define DS1302_IO_1 GPIO_WriteHigh(GPIOB,GPIO_PIN_5)
#define DS1302_IO_IN GPIO_Init(GPIOB,GPIO_PIN_5,GPIO_MODE_IN_PU_NO_IT)
#define DS1302_IO_OUT GPIO_Init(GPIOB,GPIO_PIN_5,GPIO_MODE_OUT_PP_LOW_FAST)
#define DS1302_IO_VALUE GPIO_ReadInputPin(GPIOB,GPIO_PIN_5)
#define DS1302_SCLK_0 GPIO_WriteLow(GPIOB,GPIO_PIN_4)
#define DS1302_SCLK_1 GPIO_WriteHigh(GPIOB,GPIO_PIN_4)
#define DS1302_SCLK_OUT GPIO_Init(GPIOB,GPIO_PIN_4,GPIO_MODE_OUT_PP_LOW_FAST)
#define DS1302_CE_0 GPIO_WriteLow(GPIOC,GPIO_PIN_3)
#define DS1302_CE_1 GPIO_WriteHigh(GPIOC,GPIO_PIN_3)
#define DS1302_CE_OUT GPIO_Init(GPIOC,GPIO_PIN_3,GPIO_MODE_OUT_PP_LOW_FAST)
// 延时时间定义(参照datasheet)
#define DS1302_DELAY_T_DC delay_us(1)
#define DS1302_DELAY_T_CDH delay_us(1)
#define DS1302_DELAY_T_CDD delay_us(1)
#define DS1302_DELAY_T_CL delay_us(1)
#define DS1302_DELAY_T_CH delay_us(1)
#define DS1302_DELAY_T_CC delay_us(4)
#define DS1302_DELAY_T_CCH delay_us(1)
#define DS1302_DELAY_T_CWH delay_us(4)
#endif /* __DS1302_CONFIG_H__ */
#ifndef __DS1302_H__
#define __DS1302_H__
#include "ds1302_config.h"
// 寄存器地址定义
#define DS1302_SECOND_ADDR 0x80
#define DS1302_MINUTE_ADDR 0x82
#define DS1302_HOUR_ADDR 0x84
#define DS1302_DATE_ADDR 0x86
#define DS1302_MONTH_ADDR 0x88
#define DS1302_DAY_ADDR 0x8a
#define DS1302_YEAR_ADDR 0x8c
#define DS1302_WRITE_PROTECT_ADDR 0x8e // 写保护
#define DS1302_TRICKLE_CHARGE_ADDR 0x90 // 涓流充电
#define DS1302_CLOCK_BURST_ADDR 0xbe // 连续读写
#if DS1302_AUTO_TO_DEC == 1
#define DEC_TO_BCD(d) DecToBcd(d)
#define BCD_TO_DEC(b) BcdToDec(b)
#else
#define DEC_TO_BCD(d) d
#define BCD_TO_DEC(b) b
#endif /* DS1302_AUTO_TO_DEC == 1 */
typedef enum
_12_hours, _24_hours
}HourMode_t;
typedef enum
am, pm
}AM_PM_t;
// DS1302日期时间结构
typedef struct
unsigned char Year; // 年 0 - 99
unsigned char Month; // 月 1 - 12
unsigned char Date; // 日 1 - 31
unsigned char Hour; // 时 1 - 12 或 0 - 23
unsigned char Minute; // 分 0 - 59
unsigned char Second; // 秒 0 - 59
unsigned char Day; // 星期 1 - 7 星期天 = 7
HourMode_t HourMode; // 小时模式 _12_hours 或 _24_hours
AM_PM_t AM_PM; // 上午下午标志 12时制时有效 am 或 pm
}DS1302_DateTime_t;
// 更新标记 1:已更新 0:未更新
// 调用 DS1302_GetDateTime 后自动清零
extern volatile unsigned char DS1302_Update;
/* 存放日期和时间的变量
执行 DS1302_GetDateTime 后 时间日期写入到该变量
修改此值,并执行 DS1302_SetDateTime, 更新到DS1302 */
extern DS1302_DateTime_t DS1302_DateTime;
extern DS1302_DateTime_t DS1302_DateTime_Now;
// 初始化
void DS1302_Init(void);
// 读取日期和时间, DS1302 -> DS1302_DateTime
void DS1302_GetDateTime(void);
// 设置日期和时间, DS1302_DateTime -> DS1302
void DS1302_SetDateTime(void);
// 扫描(轮询)函数, 扫描频率应大于1Hz
void DS1302_Scan(void);
void DS1302_SetDataTimeInit(void);
#endif /* __DS1302_H__ */
#include "ds1302.h"
volatile unsigned char DS1302_Update = 0;
static unsigned char GetDayFromDate(unsigned char year, unsigned char month, unsigned char date);
// 发送一个字节,不操作CE
static void DS1302_TxByte(unsigned char byte)
unsigned char i = 0;
DS1302_IO_OUT;
for (i = 0; i < 8; i++)
DS1302_SCLK_0;
DS1302_DELAY_T_CL;
if (byte & 0x01)
DS1302_IO_1;
else
DS1302_IO_0;
DS1302_DELAY_T_DC;
DS1302_SCLK_1;
DS1302_DELAY_T_CH;
byte >>= 1;
// 接收一个字节,不操作CE
static unsigned char DS1302_RxByte(void)
unsigned char byte = 0;
DS1302_IO_IN;
DS1302_IO_1;
DS1302_SCLK_0;
DS1302_DELAY_T_CDD;
byte >>= 1;
if (DS1302_IO_VALUE)
byte |= 0x80;
DS1302_SCLK_1;
DS1302_DELAY_T_CH;
return byte;
static void DS1302_WriteByte(unsigned char address, unsigned char _data)
DS1302_SCLK_0;
DS1302_CE_1;
DS1302_DELAY_T_CC;
DS1302_TxByte(address);
DS1302_TxByte(_data);
DS1302_SCLK_0;
DS1302_DELAY_T_CCH;
DS1302_CE_0;
DS1302_DELAY_T_CWH;
static unsigned char DS1302_ReadByte(unsigned char address)
unsigned char _data = 0;
DS1302_SCLK_0;
DS1302_CE_1;
DS1302_DELAY_T_CC;
DS1302_TxByte(address | 0x01);
_data = DS1302_RxByte();
DS1302_SCLK_0;
DS1302_DELAY_T_CCH;
DS1302_CE_0;
DS1302_DELAY_T_CWH;
return _data;
static unsigned char DecToBcd(unsigned char d)
return ((((d) / 10) << 4) + ((d) % 10));
static unsigned char BcdToDec(unsigned char b)
return ((((b) >> 4) * 10) + ((b) & 0x0f));
unsigned char temp = 0;
DS1302_WriteByte(DS1302_WRITE_PROTECT_ADDR, 0x00); // 关闭写保护
DS1302_WriteByte(DS1302_YEAR_ADDR, DEC_TO_BCD(DS1302_DateTime.Year));
DS1302_WriteByte(DS1302_MONTH_ADDR, DEC_TO_BCD(DS1302_DateTime.Month));
DS1302_WriteByte(DS1302_DATE_ADDR, DEC_TO_BCD(DS1302_DateTime.Date));
DS1302_WriteByte(DS1302_MINUTE_ADDR, DEC_TO_BCD(DS1302_DateTime.Minute));
DS1302_WriteByte(DS1302_SECOND_ADDR, DEC_TO_BCD(DS1302_DateTime.Second));
DS1302_WriteByte(DS1302_DAY_ADDR, DEC_TO_BCD(GetDayFromDate(DS1302_DateTime.Year, DS1302_DateTime.Month, DS1302_DateTime.Date)));
temp = DEC_TO_BCD(DS1302_DateTime.Hour);
if (DS1302_DateTime.HourMode == _12_hours)
temp |= 0x80;
temp |= (DS1302_DateTime.AM_PM == pm ? 0x20 : 0);
DS1302_WriteByte(DS1302_HOUR_ADDR, temp);
DS1302_WriteByte(DS1302_WRITE_PROTECT_ADDR, 0x80); // 写入完毕后设置写保护
DS1302_Update = 0;
DS1302_DateTime_Now.Year = BCD_TO_DEC(DS1302_ReadByte(DS1302_YEAR_ADDR));
DS1302_DateTime_Now.Month = BCD_TO_DEC(DS1302_ReadByte(DS1302_MONTH_ADDR));
DS1302_DateTime_Now.Date = BCD_TO_DEC(DS1302_ReadByte(DS1302_DATE_ADDR));
DS1302_DateTime_Now.Hour = BCD_TO_DEC(DS1302_ReadByte(DS1302_HOUR_ADDR));
DS1302_DateTime_Now.Minute = BCD_TO_DEC(DS1302_ReadByte(DS1302_MINUTE_ADDR));
DS1302_DateTime_Now.Second = BCD_TO_DEC(DS1302_ReadByte(DS1302_SECOND_ADDR));
DS1302_DateTime_Now.Day = BCD_TO_DEC(DS1302_ReadByte(DS1302_DAY_ADDR));
temp = DS1302_ReadByte(DS1302_HOUR_ADDR);
if (temp & 0x80)
DS1302_DateTime_Now.HourMode = _12_hours;
DS1302_DateTime_Now.AM_PM = ((temp & 0x20) ? pm : am);
temp &= 0x1f;
DS1302_DateTime_Now.Hour = BCD_TO_DEC(temp);
static unsigned second_last = 0;
DS1302_DateTime.Second = BCD_TO_DEC(DS1302_ReadByte(DS1302_SECOND_ADDR));
if (second_last != DS1302_DateTime.Second)
second_last = DS1302_DateTime.Second;
DS1302_Update = 1;
// 端口初始化
DS1302_CE_0;
DS1302_CE_OUT;
DS1302_SCLK_0;
DS1302_SCLK_OUT;
DS1302_WriteByte(DS1302_TRICKLE_CHARGE_ADDR, 0xa7); // 使能涓流充电 1 Diode, 8kΩ
if (DS1302_ReadByte(DS1302_SECOND_ADDR) & 0x80) // 振荡器未启动
DS1302_WriteByte(DS1302_SECOND_ADDR, 0x00); // 启动振荡器
DS1302_WriteByte(DS1302_WRITE_PROTECT_ADDR, 0x80); // 打开写保护
// 计算2000~2099年任一天星期几
// year : 00-99
// month : 01-12
// day : 01-31
// 返回 1 -> 7 : 星期一 -> 星期天
if (month == 1 || month == 2)
month += 12;
if (year > 0)
year--;
else
year = 4;
return (1 + ((date + 2 * month + 3 * (month + 1) / 5 + year + year / 4) % 7));
DS1302_DateTime.Year = 15;
DS1302_DateTime.Month = 4;
DS1302_DateTime.Date = 29;
DS1302_DateTime.Hour = 00;
DS1302_DateTime.Minute = 58;
DS1302_DateTime.Second = 00;
DS1302_DateTime.Day = 2;
DS1302_DateTime.HourMode = _24_hours;
DS1302_DateTime.AM_PM = am;
