FAQ提问:STM32F042F4P6 CAN初始化
苏柚 提问时间:2015-10-15 17:04 /
赞 收藏 评论2 发布时间:2015-10-15 17:04
阿平 回答时间:2016-3-20 23:53:21
我也碰到了, 请大神帮忙分析一下
任风吹吹 回答时间:2016-6-6 12:11:20
估计是重映射没有成功, SYSCFG的时钟没有打开.
在重映射PA11_PA12脚之前,必须先将SYS CFG的时钟打开,不然会重映射失败的,这个你可以在调试下查看系统配置寄存器的重映射标志状态确定是否重映射成功。
只有在重映射成功后再可以正确的初始化CAN。
如:
  1. #define __HAL_REMAP_PIN_ENABLE(__PIN_REMAP__)          do {assert_param(IS_HAL_REMAP_PIN((__PIN_REMAP__)));                 \
  2.                                                            SYSCFG->CFGR1 |= (__PIN_REMAP__);                                \
  3.                                                          }while(0)
  1. RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);
  2. __HAL_REMAP_PIN_ENABLE(HAL_REMAP_PA11_PA12);
  3. /* CAN configuration */
  4.   CAN_Config();
CAN_Config()如下所示  :
  1. static void CAN_Config(void)
  2. {
  3.   GPIO_InitTypeDef  GPIO_InitStructure;
  4.   NVIC_InitTypeDef  NVIC_InitStructure;
  5.   CAN_InitTypeDef        CAN_InitStructure;
  6.   CAN_FilterInitTypeDef  CAN_FilterInitStructure;
  7.
  8.   /* CAN GPIOs configuration **************************************************/
  9.   /* Enable GPIO clock */
  10.   RCC_AHBPeriphClockCmd(CAN_GPIO_CLK, ENABLE);
  11.   /* Connect CAN pins to AF7 */
  12.   GPIO_PinAFConfig(CAN_GPIO_PORT, CAN_RX_SOURCE, CAN_AF_PORT);
  13.   GPIO_PinAFConfig(CAN_GPIO_PORT, CAN_TX_SOURCE, CAN_AF_PORT);
  14.
  15.   /* Configure CAN RX and TX pins */
  16.   GPIO_InitStructure.GPIO_Pin = CAN_RX_PIN | CAN_TX_PIN;
  17.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  18.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  19.   GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  20.   GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_UP;
  21.   GPIO_Init(CAN_GPIO_PORT, &GPIO_InitStructure);
  22.   /* NVIC configuration *******************************************************/
  23.   NVIC_InitStructure.NVIC_IRQChannel = CEC_CAN_IRQn;
  24.   NVIC_InitStructure.NVIC_IRQChannelPriority = 0x0;
  25.   NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  26.   NVIC_Init(&NVIC_InitStructure);
  27.
  28.   /* CAN configuration ********************************************************/
  29.   /* Enable CAN clock */
  30.   RCC_APB1PeriphClockCmd(CAN_CLK, ENABLE);
  31.
  32.   /* CAN register init */
  33.   CAN_DeInit(CANx);
  34.   CAN_StructInit(&CAN_InitStructure);
  35.   /* CAN cell init */
  36.   CAN_InitStructure.CAN_TTCM = DISABLE;
  37.   CAN_InitStructure.CAN_ABOM = DISABLE;
  38.   CAN_InitStructure.CAN_AWUM = DISABLE;
  39.   CAN_InitStructure.CAN_NART = DISABLE;
  40.   CAN_InitStructure.CAN_RFLM = DISABLE;
  41.   CAN_InitStructure.CAN_TXFP = DISABLE;
  42.   CAN_InitStructure.CAN_Mode = CAN_Mode_Normal;
  43.   CAN_InitStructure.CAN_SJW = CAN_SJW_1tq;
  44.
  45.   /* CAN Baudrate = 1MBps (CAN clocked at 36 MHz) */
  46.   CAN_InitStructure.CAN_BS1 = CAN_BS1_9tq;
  47.   CAN_InitStructure.CAN_BS2 = CAN_BS2_8tq;
  48.   CAN_InitStructure.CAN_Prescaler = 2;
  49.   CAN_Init(CANx, &CAN_InitStructure);
  50.   /* CAN filter init */
  51.   CAN_FilterInitStructure.CAN_FilterNumber = 0;
  52.   CAN_FilterInitStructure.CAN_FilterMode = CAN_FilterMode_IdMask;
  53.   CAN_FilterInitStructure.CAN_FilterScale = CAN_FilterScale_32bit;
  54.   CAN_FilterInitStructure.CAN_FilterIdHigh = 0x0000;
  55.   CAN_FilterInitStructure.CAN_FilterIdLow = 0x0000;
  56.   CAN_FilterInitStructure.CAN_FilterMaskIdHigh = 0x0000;
  57.   CAN_FilterInitStructure.CAN_FilterMaskIdLow = 0x0000;
  58.   CAN_FilterInitStructure.CAN_FilterFIFOAssignment = 0;
  59.   CAN_FilterInitStructure.CAN_FilterActivation = ENABLE;
  60.   CAN_FilterInit(&CAN_FilterInitStructure);
  61.
  62.   /* Transmit Structure preparation */
  63.   TxMessage.StdId = 0x321;
  64.   TxMessage.ExtId = 0x01;
  65.   TxMessage.RTR = CAN_RTR_DATA;
  66.   TxMessage.IDE = CAN_ID_STD;
  67.   TxMessage.DLC = 1;
  68.
  69.   /* Enable FIFO 0 message pending Interrupt */
  70.   CAN_ITConfig(CANx, CAN_IT_FMP0, ENABLE);
  71. }
拿走不谢!
