STM32F030K6的TIM3定时器可否捕捉两路PWM输入
xieweibiao 提问时间:2015-10-18 18:00 /
已经调试了一整天发现CH1和CH2可以捕捉一路信号,但是CH3和CH4怎么调试都没有数值,度娘中有说可以,有些又说不能,求解答
赞 收藏 评论5 发布时间:2015-10-18 18:00
5个回答
你好我好大家好! 回答时间:2015-10-18 18:17:47
看参考手册比问谁都权威
xieweibiao 回答时间:2015-10-18 18:50:55
我就是看着手册来写程序的,结果CH3和CH4的值一动不动的,手册上应该是支持的
lkl0305 回答时间:2015-10-18 20:54:04
刚声打火机 回答时间:2015-10-19 09:02:40
两路都是可以捕获的哈
我公司产品中有实际应用
给你贴上源码 可以参考一下
#define TIM1_PRESCALER        2
typedef void (*tim1_cc_irq_t)(void);
/* 使能TIM1 */
#define START_TIM1() \
        do {\
                RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);\
                TIM_Cmd(TIM1, ENABLE);\
        } while (0);
/* 停止TIM1 */
#define STOP_TIM1() \
        do {\
                TIM_Cmd(TIM1, DISABLE);\
                RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, DISABLE);\
        } while (0);
void bsp_tim1_init(void);
void tim1_ch3_set_irq_callback(tim1_cc_irq_t func);
void tim1_ch4_set_irq_callback(tim1_cc_irq_t func);
static tim1_cc_irq_t __tim1_cc3_irq = NULL;
static tim1_cc_irq_t __tim1_cc4_irq = NULL;
*  |                     TIM1初始化               | *
        TIM_ICInitTypeDef TIM_ICInitStructure;
        TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
        /* TIM1 clock enable */
        /* TIM1 CC CH3 */
        bsp_gpio_init(GPIOA,
                                  GPIO_Pin_10,
                                  GPIO_Mode_AF,
                                  GPIO_Speed_50MHz,
                                  GPIO_OType_PP,
                                  GPIO_PuPd_UP);
        /* TIM1 CC CH4 */
                                  GPIO_Pin_11,
                                  GPIO_Mode_AF,
                                  GPIO_Speed_50MHz,
                                  GPIO_OType_PP,
                                  GPIO_PuPd_UP);
        /* Connect TIM pins to AF2 */
        GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_2);
        GPIO_PinAFConfig(GPIOA, GPIO_PinSource11, GPIO_AF_2);
        TIM_TimeBaseStructure.TIM_Period = 0xFFFFFFFF;
    /* 累计 TIM_Period个频率后产生一个更新或者中断 */
    TIM_TimeBaseStructure.TIM_Prescaler = TIM1_PRESCALER - 1;                // 24M
    TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;                 // 采样分频
    TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;     // 向上计数模式
    TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
        TIM_ICInitStructure.TIM_Channel = TIM_Channel_3;
        TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising;
        TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;
        TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;
        TIM_ICInitStructure.TIM_ICFilter = 0x0;
        TIM_ICInit(TIM1, &TIM_ICInitStructure);
        TIM_ICInitStructure.TIM_Channel = TIM_Channel_4;
        TIM_ITConfig(TIM1, TIM_IT_CC3, ENABLE);
        TIM_ITConfig(TIM1, TIM_IT_CC4, ENABLE);
        nvic_config(TIM1_CC_IRQn, TIM1_CC_PRIOR, ENABLE);
* |         TIM1 CH3  初始化回调函数   | *
        __tim1_cc3_irq = func;
* |         TIM1 CH4  初始化回调函数   | *
        __tim1_cc4_irq = func;
* |                  TIM1 CC 中断                 | *
void TIM1_CC_IRQHandler(void)
        if (TIM_GetITStatus(TIM1, TIM_IT_CC3) == SET) {
                TIM_ClearITPendingBit(TIM1, TIM_IT_CC3);
                if (NULL != __tim1_cc3_irq) {
                        (__tim1_cc3_irq)();
        if (TIM_GetITStatus(TIM1, TIM_IT_CC4) == SET) {
                TIM_ClearITPendingBit(TIM1, TIM_IT_CC4);
                if (NULL != __tim1_cc4_irq) {
                        (__tim1_cc4_irq)();
补充一下:
bsp_gpio_init()   这个函数我自己封装过,定义是这样的:
* |            封装了一层GPIO初始化函数     | *
/* GPIO Group Periph Manager*/
typedef struct ggm_s {
        GPIO_TypeDef *gpio_x;
        u32 periph;
        vu32 bit_map;
} ggpm_t;
static ggpm_t ggpm[MAX_GPIO_GROUP_NUM] = {
        {GPIOA, RCC_AHBPeriph_GPIOA, 0x0},
        {GPIOB, RCC_AHBPeriph_GPIOB, 0x0},
        {GPIOC, RCC_AHBPeriph_GPIOC, 0x0},
        {GPIOD, RCC_AHBPeriph_GPIOD, 0x0},
        {GPIOE, RCC_AHBPeriph_GPIOE, 0x0},
        {GPIOF, RCC_AHBPeriph_GPIOF, 0x0},
void bsp_gpio_init(GPIO_TypeDef *gpio_x, u32 gpio_pin, GPIOMode_TypeDef mode, GPIOSpeed_TypeDef speed, GPIOOType_TypeDef otype, GPIOPuPd_TypeDef pupd)
        GPIO_InitTypeDef gpio_init_struct;
        int i = 0;
        for (i = 0; i < (sizeof(ggpm) / sizeof(ggpm_t)); i++) {
                if (ggpm.gpio_x == gpio_x) {
                        if ( ! (ggpm.bit_map & GPIO_PIN_NUM_MASK) ) {
                                RCC_AHBPeriphClockCmd(ggpm.periph, ENABLE);
                        ggpm.bit_map |= gpio_pin;
                        gpio_init_struct.GPIO_Pin = gpio_pin;
                        gpio_init_struct.GPIO_Mode = mode;
                        gpio_init_struct.GPIO_Speed = speed;
                        gpio_init_struct.GPIO_OType = otype;
                        gpio_init_struct.GPIO_PuPd = pupd;
                        GPIO_Init(gpio_x, &gpio_init_struct);
                        break;
后知后觉 回答时间:2016-7-27 00:13:46
刚声打火机 发表于 2015-10-19 09:02
两路都是可以捕获的哈
我公司产品中有实际应用
给你贴上源码 可以参考一下
  你这个代码封装的还是不错的
