STM32F030F4P6系统时钟必须和AHB时钟一致吗
yanggong 提问时间:2015-11-21 15:59 /
STM32F030F4P6 外部晶振8M  设置AHB为系统时钟的2-512分频,程序在执行完初始化后就不在执行了,这是为什么 ?   不分频就可以执行
赞 收藏 评论8 发布时间:2015-11-21 15:59
8个回答
废鱼 回答时间:2015-11-21 16:11:43
时钟配置错误。
yanggong 回答时间:2015-11-21 16:15:05
if (HSEStatus == (uint32_t)0x01)
    /* Enable Prefetch Buffer and set Flash Latency */
    FLASH->ACR = FLASH_ACR_PRFTBE | FLASH_ACR_LATENCY;
    /* HCLK = SYSCLK */
    RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV2;//这里改成2分频就不行了
    /* PCLK = HCLK */
    RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE_DIV1;
chifen 回答时间:2015-11-21 16:31:32
不能只看这里一点,要看你的 是不是启用了外部时钟,你倍频是多少,才能知道下面的分频
yanggong 回答时间:2015-11-21 16:33:44
static void SetSysClock(void)
  __IO uint32_t StartUpCounter = 0, HSEStatus = 0;
/*            PLL (clocked by HSE) used as System clock source                */
  /* SYSCLK, HCLK, PCLK configuration ----------------------------------------*/
  /* Enable HSE */
  RCC->CR |= ((uint32_t)RCC_CR_HSEON);
  /* Wait till HSE is ready and if Time out is reached exit */
  do
    HSEStatus = RCC->CR & RCC_CR_HSERDY;
    StartUpCounter++;
  } while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
  if ((RCC->CR & RCC_CR_HSERDY) != RESET)
    HSEStatus = (uint32_t)0x01;
  else
    HSEStatus = (uint32_t)0x00;
    /* HCLK = SYSCLK */
    /* PCLK = HCLK */
    /* PLL configuration */
    RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL));
    RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_PREDIV1 | RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLMULL2);
    RCC_PREDIV1Config( RCC_PREDIV1_Div2);
    /* Enable PLL */
    RCC->CR |= RCC_CR_PLLON;
    /* Wait till PLL is ready */
    while((RCC->CR & RCC_CR_PLLRDY) == 0)
    /* Select PLL as system clock source */
    RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
    RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
    /* Wait till PLL is used as system clock source */
    while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)RCC_CFGR_SWS_PLL)
  else
  { /* If HSE fails to start-up, the application will have wrong clock
         configuration. User can add here some code to deal with this error */
chifen 回答时间:2015-11-21 16:50:29
system_stm32f0xx.c 里看一下
#define PLL_SOURCE_HSI        // HSI (~8MHz) used to clock the PLL, and the PLL is used as system clock source
//#define PLL_SOURCE_HSE        // HSE (8MHz) used to clock the PLL, and the PLL is used as system clock source
//#define PLL_SOURCE_HSE_BYPASS // HSE bypassed with an external clock (8MHz, coming from ST-Link) used to clock
   你启用的是哪个
yanggong 回答时间:2015-11-21 19:29:00
外部8M ,第二个
chifen 回答时间:2015-11-21 19:44:50
调试了你的代码,如果是第二个 可以正常运行的
yanggong 回答时间:2015-11-21 22:32:47
麻烦您帮我看下这个代码,程序执行完初始化 while(1)就不执行了,AD采样也不执行了
led.zip
299.29 KB, 下载次数: 16, 下载积分: ST金币 -1
