按键消抖
在路上11111111 发布时间:2016-11-1 19:32
  1. #include "stdio.h"
    8 G7 L0 h: B9 O4 s' s' W: h
  2. #define _IO volatile. i$ `5 U$ @' `& s6 {0 _% d3 j
  3. typedef unsigned int uint32_t;; K# e' ?" A4 Y1 G/ {: m. l6 i- q
  4. typedef _IO uint32_t vu32;
    / e) f1 W, H& o! ~" |) X+ u( p' i
  5. typedef unsigned short int uint16_t;
    " g- k0 q& ], |% B! ]# D+ x
  6. #define GPIO_Pin_0         ((uint16_t)0x0001)
    6 X, W' q  D2 K* m% z" m
  7. #define GPIO_Pin_1         ((uint16_t)0x0002)' m0 d$ B& ^, Q! }
  8. #define GPIO_Pin_2         ((uint16_t)0x0004)+ e: t$ }& [- o
  9. #define GPIO_Pin_3         ((uint16_t)0x0008)
    * y$ }  K/ {0 E* a! m. y( i
  10. #define GPIO_Pin_4         ((uint16_t)0x0010)
    1 }# l, }4 B' ?# M' _
  11. #define GPIO_Pin_5         ((uint16_t)0x0020), b! W2 @' U# U1 }& G5 l. ?1 m- ~
  12. #define GPIO_Pin_6         ((uint16_t)0x0040)
    - K- |$ }' U1 s
  13. #define GPIO_Pin_7         ((uint16_t)0x0080)
    ( y, V! Y. d: F; ?9 T
  14. #define GPIO_Pin_8         ((uint16_t)0x0100)
    ' s# a% K. b: I( [$ o
  15. #define GPIO_Pin_9         ((uint16_t)0x0200)# {8 n5 V4 W# c, R/ w+ G/ h
  16. #define GPIO_Pin_10        ((uint16_t)0x0400)
    , ]5 U; a' v/ Z( X8 t- M) t0 o
  17. #define GPIO_Pin_11        ((uint16_t)0x0800)  k+ o/ e8 n* L
  18. #define GPIO_Pin_12        ((uint16_t)0x1000)
    . B6 r+ V2 J/ g! `. G
  19. #define GPIO_Pin_13        ((uint16_t)0x2000)# T/ `2 ]4 B/ y* m/ X7 M/ {
  20. #define GPIO_Pin_14        ((uint16_t)0x4000)3 D3 T) C2 Q2 b6 G6 \2 F' {: }
  21. #define GPIO_Pin_15        ((uint16_t)0x8000)/ J; L  }) d4 o# p
  22. #define GPIO_Pin_All       ((uint16_t)0xFFFF); l9 T1 `/ m5 ?& M' B  c9 r6 E
  23. * L+ g& s. V8 @2 _; k  c( o8 N
  24. 9 Q0 ?/ u, h* S: I- Q9 s/ h+ H
  25. #define   RCC_APB2Periph_AFIO      ((uint32_t)0x00000001)8 ~  {# i- L5 X. T- c
  26. #define   RCC_APB2Periph_GPIOA     ((uint32_t)0x00000004)
    8 O8 N4 s; O9 m, N& a
  27. #define   RCC_APB2Periph_GPIOB     ((uint32_t)0x00000008)
    3 u: Y- D7 u2 ~* I
  28. #define   RCC_APB2Periph_GPIOC     ((uint32_t)0x00000010)
    7 M" I( z1 j9 w3 }. g' B0 ]
  29. #define   RCC_APB2Periph_GPIOD     ((uint32_t)0x00000020), z' n1 `. h+ V
  30. $ _  r- f/ Z* M& Q7 h3 X
  31. #define LEDON    (GPIOD->BRR = GPIO_Pin_2)
    2 g8 X4 J+ l. {$ p/ r% L6 N/ A$ c
  32. #define LEDOFF   (GPIOD->BSRR = GPIO_Pin_2)9 ]; A( ^5 Y9 G6 X
  33. 5 f- i7 x+ A& a  Y1 `
  34. $ r6 P- B. j7 U* W9 ~7 c& z, x
  35. #define BITBAND(addr,bitnum)  ((addr & 0xF0000000)+0x2000000+((addr & 0xFFFFF)<<5)+ (bitnum<<2))5 M' M3 K7 _) T' a0 P6 K: i9 L; |
  36. /*******这个的公式是FLASH的话,   0X4200 0000 + ((add-0x4000 0000)*8+n)*4;0 Y# t' q/ V# }2 Q( u, C, r2 M
  37.         其中add是你要绑定的寄存器的地址,n是你要绑定的寄存器的位,7 l; p, I+ B" S
  38.                 现在将其变成这种形式((addr & 0xF0000000)+0x2000000+((addr & 0xFFFFF)<<5 + (bitnum)<<2))+ E  X7 I7 O& k# M# E( W/ Y
  39.                 :addr & 0xF000 0000是将其保留最高的思位比如说addr地址是0x4201 8000那么他现在是0x4000 0000 ! i6 W7 G: i8 S: m
  40.                 +0x2000000变成了0x4200 0000;(addr-0x4000 0000)这其实就是保留它的后7位(在这里的改变的寄存器的地址都是
    ! Q+ |7 [2 [0 }$ F/ l( {! X) N
  41.                 0x4001 0000的那么就是说进一步保存的是后五位)(这里注意一点,0x2200_0000这个地址每增加1,实际上就是增加
    / B4 G" X% ?8 Y4 \0 l1 {: _1 x  s
  42.                 8个bit(一个地址对应一个字节),实际寄存器中的1个bit对应32个bit,所以就乘以4,地址本身增加1是8bit,7 L! n4 Z: x! x) J5 E
  43.                 8bit乘以4倍刚好是32bit。)那么现在(addr &0XFFFFF)其实就是保留后五位,<<5就是*32(2^5),<<2就是*4(2^2);# Y5 u* g9 I) r$ N2 G
  44.                 将((A-0x4000 0000)(这个就是addr &0xFFFFF)*8+n)*4拆开就是(addr & 0XFFFFF)<<5 +(bitnum)<<2了
    8 J. c. G& y7 o4 X4 ~" q
  45. **********/9 Y3 G6 w" x( ]( G& o
  46. #define MEM_ADDR(addr)   *((volatile unsigned  long *)(addr)), v6 @. h7 f8 S5 _  V& j7 U
  47. #define BIT_ADDR(addr,bitnum) MEM_ADDR(BITBAND(addr, bitnum))
    , T3 ^/ M3 k) }; |& [1 e/ ?
  48. #define PCin(n)    BIT_ADDR(GPIOC_IDR_Addr,n)( t2 \- i% v: |5 s+ m" _1 P
  49. #define KEY1   PCin(4): p# a" @! I9 b2 \  A
  50. " Z2 g4 |; I  a
  51. typedef struct) f4 H: r. j+ L, X5 `
  52. {) K0 J3 i, l8 O! N0 e% d6 E% [
  53.     _IO uint32_t   CRL;( k* ?4 s  f& e: x( [% c) j* v! A
  54.         _IO uint32_t   CRH;
    ) S4 q* f3 A  O/ E- W& e4 [
  55.         _IO uint32_t   IDR;# j2 w/ J, P7 a; w8 L
  56.         _IO uint32_t   ODR;# _9 E- `  H2 f* w7 q
  57.         _IO uint32_t   BSRR;
    3 b9 X1 T4 b) I) Y: l
  58.         _IO uint32_t   BRR;) `! O+ x7 m3 {/ E& g
  59.         _IO uint32_t   LCKR;
    * l2 B5 r6 U; ]7 s! [; H7 n
  60. }GPIO_TypeDef;! b: b& J1 }& A8 L
  61. 8 |' B6 ~2 m5 e' H- O
  62. 5 U* G( K8 u& x( l: h. I/ O
  63. typedef struct
    3 u  ^5 m3 n' G9 a$ M6 y# M
  64. {
    7 [- N, }8 X' t# q3 U+ t" R+ d
  65.     _IO uint32_t  ACR;
    ( K7 B9 @: x/ n; n( m. y! P5 r! B
  66.         _IO uint32_t  KEYR;
    7 K+ F3 m  I# C+ u" N$ Q
  67.         _IO uint32_t  OPTKEYR;) f  M) Z7 S: _- @
  68.         _IO uint32_t  SR;
    7 `/ e& `2 E$ `
  69.         _IO uint32_t  CR;. }5 B1 S* K. V, O7 c* e% |
  70.         _IO uint32_t  AR;
    + E2 y2 {+ D5 Z" y5 ^
  71.         _IO uint32_t  OBR;/ Z4 j, O/ Q, @1 A4 \9 L
  72.         _IO uint32_t  WRPR;) I+ Q$ p6 l, t$ t/ g3 Z$ `% _
  73. }FLASH_TypeDef;% i6 o9 D2 l4 q8 b( Y- y
  74. ! Q' [/ N1 E- c6 C0 o
  75. 0 z' D! V6 p1 `$ C1 U7 c; d
  76. 2 B3 g) I- |( B3 G! T% n# K
  77. /************GPIOD管脚的内存对应地址********/: z7 {1 n' E0 d1 `1 g0 T! R2 l
  78. #define PERIPH_BASE          ((uint32_t)0x40000000)
    2 ]5 G1 L$ k% p' Q) }" j4 L$ P
  79. #define APB2PERIPH_BASE      (PERIPH_BASE + 0x10000)
    - L- [! m# ^5 k
  80. #define GPIOD_BASE           (APB2PERIPH_BASE + 0x1400)
    # W9 j) H' s2 o/ l8 M9 A
  81. #define GPIOD                     ((GPIO_TypeDef *)GPIOD_BASE)
    & m. _: ?$ |& G9 O% x" \
  82. 8 W0 d, W* V- N- O: {/ x: X2 C
  83. % I+ G4 B2 ]! F8 l/ M
  84. //#define PERIPH_BASE          ((uint32_t) 0x40000000)( m$ J" B* J; D9 s# p- A
  85. //#define APB2PERIPH_BASE      (PERIPH_BASE + 0x10000); F4 j3 V0 p+ Y3 H* h  d- e
  86. #define GPIOC_BASE           (APB2PERIPH_BASE + 0x1000). X% U, J7 v* r& |' J8 g( W
  87. #define GPIOC                ((GPIO_TypeDef *)GPIOC_BASE)
    ; d/ w: l( D" R+ d7 G4 \3 o
  88. #define GPIOC_IDR_Addr       (GPIOC_BASE+8)7 E* d" M8 {7 H1 D% [
  89. 2 `" X  P: G1 Y5 o5 ^
  90. 8 [( i0 _7 [* R1 y6 ~
  91. #define FLASH_BASE           ((uint32_t)0x40022000)0 P) L! U' @+ K) P' a' _  E
  92. #define FLASH                ((FLASH_TypeDef *)FLASH_BASE)
    8 d* l$ W# Y1 X3 u/ x. g# p
  93. typedef struct
    # O4 \# d& O3 _( D7 T% k! D) P
  94. {+ w2 N9 z* F' N4 A) ?
  95.    _IO uint32_t CR;, ]& T' y# O0 Y  `- p! i/ d
  96.    _IO uint32_t CFGR;$ A9 U8 f& [; B8 ^- T
  97.    _IO uint32_t CIR;% z( C" H4 u; p0 U% K
  98.    _IO uint32_t APB2RSTR;
    7 a) [: z# j& _) T8 X; V7 T# b
  99.    _IO uint32_t APB1RSTR;% D$ G2 v: Z9 U- ]% }
  100.    _IO uint32_t AHBENR;0 t$ k- A2 q$ Z8 Y; F$ @
  101.    _IO uint32_t APB2ENR;
    , C6 f& }+ B+ V1 R; j. x
  102.    _IO uint32_t APB1ENR;; {; p! n0 e% y  z8 }8 F( c
  103.    _IO uint32_t BDCR;
    " @2 x& z- |4 r9 |
  104.    _IO uint32_t CSR;, b/ A2 O' m2 B! k) F+ `+ O! U* k2 S) B
  105.    _IO uint32_t AHBRSTR;
    2 [& i5 \, j2 s. e5 X
  106.    _IO uint32_t CFGR2;6 P. w$ w7 [  E% J
  107. }RCC_TypeDef;9 o6 E$ y- r; v; M  p
  108. + A/ ~/ n& [+ V- o
  109. ! [) Q; x6 \0 s. I: z
  110. /****************RCC时钟************/) T; G7 ?9 x) F+ e* x
  111. #define AHBPERIPH_BASE     (PERIPH_BASE         + 0x20000)
    8 {5 W; y- S1 M6 y
  112. #define RCC_BASE           (AHBPERIPH_BASE + 0x1000)7 C# |2 s( }( W. a5 w7 g; m
  113. #define RCC                ((RCC_TypeDef *)RCC_BASE)
    . f1 A- _6 f+ \1 g! Z/ C! ~
  114. void RCC_init(void)1 ~, Z9 m7 _: e% U1 C9 V$ t
  115. {
    . ?5 j. [" p0 W
  116.            RCC->CR|=1<<16;1 t5 m4 t, D3 z) i9 b; `1 V: O6 |1 @5 c
  117.         while(!(RCC->CR>>17));5 ^6 ^# l: s$ |& w# ^
  118.         RCC->CFGR2|=4<<4;3 L4 J" ?: m0 K  M
  119.         RCC->CFGR2|=6<<8;
    ) B9 X: V  p5 ~9 y1 W7 g
  120.         RCC->CFGR2|=1<<16;( Z6 Z1 L( \3 J, [
  121.         RCC->CR|=1<<26;
    # |: z2 Y+ {3 u
  122.         while(!(RCC->CR>>27));
    5 C# g$ {7 E6 C/ y1 H
  123.         RCC->CFGR2|=1<<2;
    ! f! P1 R6 X, L4 G0 Y
  124.         RCC->CFGR|=1<<16;
    $ z! R5 a2 w- ~+ {3 ]
  125.         RCC->CFGR|=7<<18;
    : h6 H1 j5 L8 q
  126.         FLASH->ACR|=0x32;1 ^& H6 R0 O2 ^4 D; v
  127.         RCC->CR|=1<<24;5 ]0 z* c4 Q/ v/ ^8 U; d- J4 \
  128.         while(!(RCC->CR>>25));
    ' T& c5 M5 b) d) V# J6 r
  129.         //FLASH->ACR|=0x32;//" r# T" ]2 q- M; d) N( C" ?  ~
  130.         RCC->CFGR|=1<<1;& t8 {& B& l- K! F9 D, {: |
  131. }0 }1 [) |0 ?+ |
  132. 7 L1 T( B* ~) a& C+ ]2 c7 E* v4 O
  133. 3 q# D: v7 x8 Q5 @6 Y$ K8 ^: r
  134. void LED_init()
    $ I! @+ S) i6 v" g
  135. {
    . x& C6 [( e# a* M; G! h8 v
  136.    RCC->APB2ENR|=RCC_APB2Periph_GPIOD;
    3 n' z7 B' n! y0 T: L1 n$ o& R
  137.    GPIOD->CRL&=0xFFFFF0FF;
    6 X0 A( m! p" P5 T; x  e& S% t
  138.    GPIOD->CRL|=0x00000300;
    5 r# Z7 N4 B8 b7 G1 K+ W
  139. }$ C5 T/ t: ~4 \  O5 u5 B8 ?4 u  M) K
  140. void Delay(vu32 nCount)
    0 j% z, O& p, c; P5 ]! f& g
  141. {" B8 P! _3 Z- I
  142.    for(;nCount!=0;nCount--);) U% L+ C2 y; r( `
  143. }
    4 W5 q% s# `# ?! x  n: L0 E1 R* b
  144. void Key_init(). A' e  o: S5 n6 \" @
  145. {# O9 U; U5 d7 [! M3 Y- J7 x& ]
  146.     RCC->APB2ENR|=RCC_APB2Periph_GPIOC;//如果你写成RCC->APB2ENR=RCC_APB2Periph_GPIOC;
    ' t, y' k9 j" W4 N6 b8 K7 k) }+ S9 I' k; C
  147.         //就不行了,因为这样的话RCC的时钟只为GPIOC打开了,
    - w. N& X/ J$ I4 S
  148.         GPIOC->CRL&=0xFFF0FFFF;. o+ `. c7 T; i# S9 y
  149.         GPIOC->CRL|=0x00080000;
    / k" F  d" c+ u: f5 H
  150. }
    5 d2 z2 ?- T9 f5 ?' u* i
  151. int main(void)
    3 O1 ]  @+ w9 z
  152. {9 m& N  y( \1 m6 b  v% P$ H/ _
  153.
    & q0 l) y& w+ s6 G2 p$ j
  154.   unsigned int key_up=1,flag;  Z4 F+ u: t/ \
  155.   RCC_init();) @9 b1 p0 l9 X8 ]3 _, h" ]( \$ F
  156.   LED_init();
    ( D9 m: t) s% K4 Q
  157.   Key_init();
    6 f9 L. @. t) E* p$ R1 q; n
  158.   while(1)
    ' g) P5 `* p6 I4 S; S# C9 u! E# |( I
  159.   {
    % g4 F  ?: H- b& B2 z
  160.       if(key_up)7 `3 o) Y  @" e+ O8 u9 t
  161.             LEDON;
    1 ~+ @8 b, V% b0 _
  162.           else
    9 D  r' ~# r6 _% P& F$ i8 F) L
  163.             LEDOFF;
    4 M2 v( p3 h4 {$ _. {
  164.           /************键盘消抖**********
    + N1 u8 {; |( g4 e
  165.           这里,因为键盘按下的时候,会有一段波动,不稳定.所以在这里,我们需要消抖8 h7 V3 }2 E1 G  A
  166.           首先,我们的按键是按下的时候是0,所以进来一个while()循环(主要是stm32的运转速率太快了)
    7 m1 l( o3 S# Z; G: P+ b
  167.           然后在里面我们进行延时等待,为了防止按一下按键stm32跑了很多次的情况,我们设置一个标志flag9 ~. t$ ~0 |% f
  168.           ,只让他按一下不论多长时间,LED只亮一次。*/+ m3 ~% z2 v9 j" O1 f* V' o9 Z2 Q
  169.           while(KEY1==0)//键盘消抖7 S/ P- d# c0 j5 V; U- d* _
  170.           {0 `* E5 Y6 I2 k8 ~
  171.                Delay(0xfffff);
    % x7 }5 E2 h- V- r/ Y$ \
  172.                    flag++;( r5 T$ G: j/ K' F0 F9 e
  173.                    if(flag==1)) f% q+ o- M, v& `) `: w) q. B
  174.                    {
    6 e0 A) u( a! o* ^. l0 U
  175.                        key_up=!key_up;3 E! P& s* e5 P3 F
  176.                    }
      W3 n8 ~% T, f7 G$ s
  177.           }+ i  F( l8 D1 s! J0 N
  178.           flag=0;
    % A) c6 m7 P& y& b2 n, a
  179.   }: o. ?, b4 i8 U" |
  180. }
    2 [$ N5 @" z4 z6 F2 t
  181. $ M! h% m/ V- v% T
  182.
这里有一些关于位绑定的知识大家可以去看看。http://blog.sina.com.cn/s/articlelist_1989261580_0_1.html* O; i* \  n& _/ {
参与人数 1 ST金币 +10 收起 理由
zero99 + 10
赞 收藏 2 评论23 发布时间:2016-11-1 19:32
23个回答
在路上11111111 回答时间:2016-11-2 13:03:34
wdshuang09 发表于 2016-11-1 22:09# r4 l/ I' @2 X; d: b( r* m
Delay(0xfffff);让系统一直在这等待,不明智的选择,
" t$ O. [" f' S! T  v
刚入门,还没接触STM32的定时器,只玩过51的,所以我只能先写个延时的,等学到那个地方,再回来改进
wdshuang09 回答时间:2016-11-2 19:34:44
在路上11111111 发表于 2016-11-2 13:03
; v) H. P  t- J, X刚入门,还没接触STM32的定时器,只玩过51的,所以我只能先写个延时的,等学到那个地方,再回来改进 ...
$ s8 g- u% V% c# W. Z用定时器做,定期采样,
在路上11111111 回答时间:2016-11-2 13:06:27
高二毛 发表于 2016-11-2 08:39' w# s" }" R  U
不能这样去抖动的。楼上几位说的很好,不能这样阻塞掉。应该用中断处理。 ...
: H# Y# A' B! N" X# d' D* Z7 e/ [还没接触STM32的定时器,所以才采用了这个
wdshuang09 回答时间:2016-11-1 22:09:25
peter001 回答时间:2016-11-2 00:20:04
其实不需要这么复杂,利用系统毫秒滴答,定期采样即可,很稳定
zengyi703-16313 回答时间:2016-11-2 08:03:17
谢楼主分享
黑皮男 回答时间:2016-11-2 08:08:20
peter001 发表于 2016-11-2 00:20
% q% w; @2 f. }1 O) w其实不需要这么复杂,利用系统毫秒滴答,定期采样即可,很稳定
5 c, p2 x5 J* P2 D1 O# U赞同,定期采样,程序不会阻塞,效率高
高二毛 回答时间:2016-11-2 08:39:48
anobodykey 回答时间:2016-11-2 09:47:24
在路上11111111 回答时间:2016-11-2 13:05:30
peter001 发表于 2016-11-2 00:20: Y$ j/ U# m  h" n5 }' K6 ^- h
  M1 c  a4 l# J2 |9 J& b- V定时器吗
在路上11111111 回答时间:2016-11-2 13:05:54
黑皮男 发表于 2016-11-2 08:08
- r% x- a, S- P/ q( T赞同,定期采样,程序不会阻塞,效率高
# {/ ?# Q) P$ t' x
还没接触STM32的定时器
加拿大 回答时间:2016-11-2 15:44:29
放在中断函数定时几十毫秒扫描按键即可,不要延时
zbber 回答时间:2016-11-2 17:44:26
不能这样去抖动的
在路上11111111 回答时间:2016-11-2 19:41:47
好的,先记下了
12下一页
