关于STM32F051K4 ADC_IN1 的问题请教
huangbo 提问时间:2017-1-22 16:08 /
STM32F051  ADC 配置为DAM 采集 ADIN0~ADIN3, 4通道。
ADIN1输入为0 实测单片机管脚也为0,但是AD出来不正常,
采集结果,串口上传如下:
----AD ch1~ch4 ----
CH0 value = 1.532601 V
CH1 value = 1.458608 V
CH2 value = 0.650549 V
CH3 value = 1.468132 V
CH0 value = 1.531868 V
CH1 value = 1.457143 V
CH2 value = 0.649817 V
CH3 value = 1.469597 V
需改代码继续做实验:
AD采样,采用查询方式AD,并串口打印到PC,分别单独作了两个通道采集。
AN2: (注入0.65V)
切换为 AN1 注入0V )
CH1 value = 1.588278 V
CH1 value = 1.509158 V
CH1 value = 1.463004 V
代码基于STM32CubMX 生成,单通道实验,adc.c  如下:
/* Includes ------------------------------------------------------------------*/
#include "adc.h"
#include "gpio.h"
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
ADC_HandleTypeDef hadc;
/* ADC init function */
void MX_ADC_Init(void)
  ADC_ChannelConfTypeDef sConfig;
    /**Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion)
  hadc.Instance = ADC1;
  hadc.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV1;
  hadc.Init.Resolution = ADC_RESOLUTION_12B;
  hadc.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  hadc.Init.ScanConvMode = ADC_SCAN_DIRECTION_FORWARD;
  hadc.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
  hadc.Init.LowPowerAutoWait = DISABLE;
  hadc.Init.LowPowerAutoPowerOff = DISABLE;
  hadc.Init.ContinuousConvMode = DISABLE;
  hadc.Init.DiscontinuousConvMode = DISABLE;
  hadc.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
  hadc.Init.DMAContinuousRequests = DISABLE;
  hadc.Init.Overrun = ADC_OVR_DATA_PRESERVED;
  if (HAL_ADC_Init(&hadc) != HAL_OK)
    Error_Handler();
    /**Configure for the selected ADC regular channel to be converted.
  sConfig.Channel = ADC_CHANNEL_1;
  sConfig.Rank = ADC_RANK_CHANNEL_NUMBER;
  sConfig.SamplingTime = ADC_SAMPLETIME_7CYCLES_5;
  if (HAL_ADC_ConfigChannel(&hadc, &sConfig) != HAL_OK)
    Error_Handler();
void HAL_ADC_MspInit(ADC_HandleTypeDef* adcHandle)
  GPIO_InitTypeDef GPIO_InitStruct;
  if(adcHandle->Instance==ADC1)
  /* USER CODE BEGIN ADC1_MspInit 0 */
  /* USER CODE END ADC1_MspInit 0 */
    /* Peripheral clock enable */
    __HAL_RCC_ADC1_CLK_ENABLE();
    /**ADC GPIO Configuration
    PA1     ------> ADC_IN1
    GPIO_InitStruct.Pin = GPIO_PIN_1;
    GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
    GPIO_InitStruct.Pull = GPIO_NOPULL;
    HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  /* USER CODE BEGIN ADC1_MspInit 1 */
  /* USER CODE END ADC1_MspInit 1 */
void HAL_ADC_MspDeInit(ADC_HandleTypeDef* adcHandle)
  /* USER CODE BEGIN ADC1_MspDeInit 0 */
  /* USER CODE END ADC1_MspDeInit 0 */
    /* Peripheral clock disable */
    __HAL_RCC_ADC1_CLK_DISABLE();
    PA1     ------> ADC_IN1
    HAL_GPIO_DeInit(GPIOA, GPIO_PIN_1);
  /* USER CODE BEGIN ADC1_MspDeInit 1 */
  /* USER CODE END ADC1_MspDeInit 1 */
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
求大神给予指点!!!谢谢!!
赞 收藏 1 评论1 发布时间:2017-1-22 16:08
huangbo 回答时间:2017-1-22 23:39:09
问题解决了,谢谢大家!
