谁能解释一下STM32F0的RTC_IRQHandler中断中EXTI_Line17的作用?
【STM32F0开发日志/评测/笔记】+互补PWM波的产生
STM32F030 PB14和PB15无法输出PWM求助
【STM32F030探索套件】序列之五 外部中断
【STM32F0开发日志---二】+ucosii.2.92移植在STM32F030
上传个STM32F0+5110+内部温度传感器的菜鸟实例
【STM32F030探索套件使用问题】STM32F030 SPI方式驱动ST7565LCD失败
求一份STM32F051 I2C驱动LCD 12864的例程
STM32F0 M0 向结构体赋值进入HardFault异常
STM32F0 ADC-DMA方式采集2路数据时出现问题
F0不是103
* @brief Writes data to the specified GPIO data port.
* @param GPIOx: where x can be (A or B) to select the GPIO peripheral.
* @param GPIO_PinSource: specifies the pin for the Alternate function.
* This parameter can be GPIO_PinSourcex where x can be (0..15).
* @param GPIO_AF: selects the pin to used as Alternate function.
* This parameter can be one of the following value:
* @arg GPIO_AF_0: WKUP, EVENTOUT, TIM15, SPI1, TIM17,MCO, SWDAT, SWCLK, TIM14,
* USART1, CEC, IR_OUT, SPI2
* @arg GPIO_AF_1: USART2, CEC, Tim3, USART1, IR_OUT,EVENTOUT, I2C1, I2C2, TIM15
* @arg GPIO_AF_2: TIM2, TIM1, EVENTOUT, TIM16, TIM17
* @arg GPIO_AF_3: TS, I2C1, TIM15, EVENTOUT
* @arg GPIO_AF_4: TIM14, I2C1 (only for STM32F0XX_LD and STM32F030X6 devices)
* @arg GPIO_AF_5: TIM16, TIM17
* @arg GPIO_AF_6: EVENTOUT
* @arg GPIO_AF_7: COMP1 OUT, COMP2 OUT
* @note The pin should already been configured in Alternate Function mode(AF)
* using GPIO_InitStruct->GPIO_Mode = GPIO_Mode_AF
* @note Refer to the Alternate function mapping table in the device datasheet
* for the detailed mapping of the system and peripherals'alternate
* function I/O pins.
* @retval None
void GPIO_PinAFConfig(GPIO_TypeDef* GPIOx, uint16_t GPIO_PinSource, uint8_t GPIO_AF)
uint32_t temp = 0x00;
uint32_t temp_2 = 0x00;
/* Check the parameters */
assert_param(IS_GPIO_LIST_PERIPH(GPIOx));
assert_param(IS_GPIO_PIN_SOURCE(GPIO_PinSource));
assert_param(IS_GPIO_AF(GPIO_AF));
temp = ((uint32_t)(GPIO_AF) << ((uint32_t)((uint32_t)GPIO_PinSource & (uint32_t)0x07) * 4));
GPIOx->AFR[GPIO_PinSource >> 0x03] &= ~((uint32_t)0xF << ((uint32_t)((uint32_t)GPIO_PinSource & (uint32_t)0x07) * 4));
temp_2 = GPIOx->AFR[GPIO_PinSource >> 0x03] | temp;
GPIOx->AFR[GPIO_PinSource >> 0x03] = temp_2;
默认是 GPIO_AF_0,是swd,那做普通io呢?
f030
这个还真没有试过,各种配置方式都试试,把引脚配置成复用模式,试试。
pins. The reset states of the GPIO control registers put the I/Os in the equivalent states:
• SWDIO: input pull-up
• SWCLK: input pull-down
Having embedded pull-up and pull-down resistors removes the need to add external
resistors.
F0参考手册,如2楼所说,你需要释放掉SWD功能
把它做普通IO配置就好了。具体就是将GPIOX_MODER寄存器相关位做配置就好,比STM32F1配置更为简洁。
