STM8L 中,中断优先级通过下面函数设置,但此处仅 ITC_PriorityLevel_1,ITC_PriorityLevel_2,ITC_PriorityLevel_3 总共才3个中断优先级可设置,若我超过3个中断,该怎么设置? /** * @brief Sets the software priority of the specified interrupt source. * @note The modification of the software priority is only possible when * the interrupts are disabled. * @note The normal behavior is to disable the interrupt before calling * this function, and re-enable it after. * @note The priority level 0 cannot be set (see product specification * for more details). * @param IRQn : Specifies the peripheral interrupt source. * @param ITC_PriorityLevel : Specifies the software priority value to set * This parameter can be one of the following values: * @arg ITC_PriorityLevel_0: Software priority level 0 (cannot be written) * @arg ITC_PriorityLevel_1: Software priority level 1 * @arg ITC_PriorityLevel_2: Software priority level 2 * @arg ITC_PriorityLevel_3: Software priority level 3 * @retval None */ void ITC_SetSoftwarePriority(IRQn_TypeDef IRQn, ITC_PriorityLevel_TypeDef ITC_PriorityLevel) { } |
为何STM8S003F3进不了TIM1中断?
求STM8S105C6T6的安装软件完整版和安装步骤,谢谢!
STM8S003无法检测到引脚电平
STM8 @svlreg 问题
STM8AF62XX+L99PM62GXP LIN通讯的电路原理图有吗?官网提供了一套软件,没找到对应的原理图,请大家指教一下
求一个STM8S207例程
STMS005K6T6 如何采集内部参考电压。
stm8s003 adc中断和通道切换的问题
adc施密特触发器stm8
所以,这么几个优先级就够了。
优先级的含义是,可以打断低优先级的中断。实际上不允许你嵌套太多的中断。非常费堆栈。
