STM32F072RB I2C遇到TXIS无法置位的问题
huochaosuma 提问时间:2017-7-29 17:52 /
hi:
   大家好,遇到一个I2C的问题,请大家帮分析一下,不胜感激!
   系统使用I2C接2片 MPC23017实现GPIO的扩展,使用STM32F072RB 的I2C 2,引脚GPIO都配置了AF ,且I2C初始化也是参考了ST的例子。
   发送数据时i2c_expand_gpio_writeBuffer函数里,while(I2C_GetFlagStatus(GPIO_EXT_I2C, I2C_ISR_TXIS) == RESET) 直到超时一直得不到TXIS置位,请大家帮分析下。
uint8_t i2c_expand_gpio_writeBuffer(uint8_t i2c_chip_addr,uint8_t* pBuffer, uint16_t WriteAddr, uint16_t* NumByteToWrite)
  uint32_t DataNum = 0;
  uint32_t i2cTimeout = 0;
  /* Configure slave address, nbytes, reload and generate start */
  I2C_TransferHandling(GPIO_EXT_I2C, i2c_chip_addr, 1, I2C_Reload_Mode, I2C_Generate_Start_Write);
  /* Wait until TXIS flag is set */
  i2cTimeout = GPIO_EXT_I2C_LONG_TIMEOUT;
    if((i2cTimeout--) == 0) return I2C_ERROR_TIMEOUT;
  /* Send  address */
  I2C_SendData(GPIO_EXT_I2C, (uint8_t)WriteAddr);
  /* Wait until TCR flag is set */
  while(I2C_GetFlagStatus(GPIO_EXT_I2C, I2C_ISR_TCR) == RESET)
  /* Update CR2 : set Slave Address , set write request, generate Start and set end mode */
  I2C_TransferHandling(GPIO_EXT_I2C, i2c_chip_addr, (uint8_t)(*NumByteToWrite), I2C_AutoEnd_Mode, I2C_No_StartStop);
  while (DataNum != (*NumByteToWrite))
    /* Write data to TXDR */
    I2C_SendData(GPIO_EXT_I2C, (uint8_t)(pBuffer[DataNum]));
    /* Update number of transmitted data */
    DataNum++;
  /* Wait until STOPF flag is set */
  while(I2C_GetFlagStatus(GPIO_EXT_I2C, I2C_ISR_STOPF) == RESET)
  /* Clear STOPF flag */
  I2C_ClearFlag(GPIO_EXT_I2C, I2C_ICR_STOPCF);
  i2c_expand_gpio_waitStandbyState(i2c_chip_addr);
  /* If all operations OK, return sEE_OK (0) */
  return OK;
赞 收藏 1 评论5 发布时间:2017-7-29 17:52
5个回答
huochaosuma 回答时间:2017-7-29 17:55:54
void i2c_expand_gpio_Init(void)
  I2C_InitTypeDef  I2C_InitStructure;
  GPIO_InitTypeDef  GPIO_InitStructure;
  /* Configure the I2C clock source. The clock is derived from the HSI */
  RCC_I2CCLKConfig(RCC_I2C1CLK_HSI);
  /* GPIO_EXT_I2C_SCL_GPIO_CLK and GPIO_EXT_I2C_SDA_GPIO_CLK Periph clock enable */
  RCC_AHBPeriphClockCmd(GPIO_EXT_I2C_SCL_GPIO_CLK | GPIO_EXT_I2C_SDA_GPIO_CLK, ENABLE);
  /* GPIO_EXT_I2C Periph clock enable */
  RCC_APB1PeriphClockCmd(GPIO_EXT_I2C_CLK, ENABLE);
  /* Connect PXx to I2C_SCL*/
  GPIO_PinAFConfig(GPIO_EXT_I2C_SCL_GPIO_PORT, GPIO_EXT_I2C_SCL_SOURCE, GPIO_EXT_I2C_SCL_AF);
  /* Connect PXx to I2C_SDA*/
  GPIO_PinAFConfig(GPIO_EXT_I2C_SDA_GPIO_PORT, GPIO_EXT_I2C_SDA_SOURCE, GPIO_EXT_I2C_SDA_AF);
  /* GPIO configuration */
  /* Configure GPIO_EXT_I2C pins: SCL */
  GPIO_InitStructure.GPIO_Pin = GPIO_EXT_I2C_SCL_PIN;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_OD;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
  GPIO_Init(GPIO_EXT_I2C_SCL_GPIO_PORT, &GPIO_InitStructure);
  /* Configure GPIO_EXT_I2C pins: SDA */
  GPIO_InitStructure.GPIO_Pin = GPIO_EXT_I2C_SDA_PIN;
  GPIO_Init(GPIO_EXT_I2C_SDA_GPIO_PORT, &GPIO_InitStructure);
  /* I2C configuration */
  /* GPIO_EXT_I2C configuration */
  I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;
  I2C_InitStructure.I2C_AnalogFilter = I2C_AnalogFilter_Enable;
  I2C_InitStructure.I2C_DigitalFilter = 0x00;
  I2C_InitStructure.I2C_OwnAddress1 = 0x00;
  I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;
  I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
  I2C_InitStructure.I2C_Timing = GPIO_EXT_I2C_TIMING;
  /* Apply GPIO_EXT_I2C configuration after enabling it */
  I2C_Init(GPIO_EXT_I2C, &I2C_InitStructure);
  /* GPIO_EXT_I2C Peripheral Enable */
  I2C_Cmd(GPIO_EXT_I2C, ENABLE);
  /*Init I2C Slave MPC23017, all port is output*/
  mpc23017Init();
这是我的I2C初始化,端口 和 I2C 2的选择宏定义,已经检查好多遍了,不会有什么问题。
huochaosuma 回答时间:2017-7-29 17:57:03
GPIO_EXT_I2C_TIMING   我使用了ST的工具excel 和 Cube 按照APB1的外设时钟值生成过,但是没什么效果。
斜阳 回答时间:2017-10-11 10:07:11
帮顶
anguswang 回答时间:2017-10-11 10:40:05
你 I2C 使用的是 HSI 时钟,你却用 APB1 时钟来生成 TIMING ?
另外你时钟配置的是多少? 超过 400K 需要打开 SYSCFG 的 FastMode 控制位。
参与人数 1ST金币 +2 收起 理由
无薪税绵 回答时间:2017-10-11 10:44:38
楼主可以检查一下,硬件是否有问题。
找个其它正常的IIC器,试试,
看看是硬件还是软件的问题。
参与人数 1ST金币 +2 收起 理由
