STM32F042F6P 串口2问题
zzfd97 提问时间:2018-2-20 17:28 /
最近用STM32F042F6P用于双串口通信,串口1通信正常,串口2一直调试不成功,不知道是什么问题,故求助大神们;串口2的配置信息如下:
void RCC_Configuration(void)
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);//设置A端口时钟使能
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE);//设置B端口时钟使能
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOF, ENABLE);//设置F端口时钟使能
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE); //设置串口1时钟使能
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);//设置串口2时钟使能
void USART2_Configuration(void)
                        //gpio配置
                        /* Connect PXx to USARTx_Tx */
                        GPIO_PinAFConfig(GPIOA, GPIO_PinSource2, GPIO_AF_1);//PA2复用功能打开
                        /* Connect PXx to USARTx_Rx */
                        GPIO_PinAFConfig(GPIOA, GPIO_PinSource3, GPIO_AF_1); //PA3复用功能打开
                        /* Configure USART2 Tx (PA.02) as alternate function push-pull */
                        GPIO_InitStructure.GPIO_Pin    = USART2_TX;
                        GPIO_InitStructure.GPIO_Mode   = GPIO_Mode_AF;
                        GPIO_InitStructure.GPIO_OType  = GPIO_OType_PP;
                        GPIO_InitStructure.GPIO_Speed  = GPIO_Speed_50MHz;
                        GPIO_InitStructure.GPIO_PuPd   = GPIO_PuPd_NOPULL;
                        /* Configure USART2 Rx (PA.3) as input mode */
                        GPIO_InitStructure.GPIO_Pin    = USART2_RX;
                        /* USART2 mode config */
                        USART_InitStructure.USART_BaudRate = 9600;
                        USART_InitStructure.USART_Parity = USART_Parity_No ;
                        USART_Init(USART2, &USART_InitStructure);
                         //打开空闲中断
                         //USART_ITConfig(USART2,USART_IT_IDLE, ENABLE);
                         //打开接收中断
                         USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);
                         USART_Cmd(USART2, ENABLE);
                           USART_ClearFlag(USART2, USART_FLAG_TC);
                        //允许UART2中断
                        NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;
                        NVIC_InitStructure.NVIC_IRQChannelPriority = 0;
void Uart2PutChar(unsigned char ch)
        USART_SendData(USART2,ch);
        while(USART_GetFlagStatus(USART2,USART_FLAG_TXE)==RESET);
void Send2_Mesg(void)
        Uart2PutChar('F');
        Uart2PutChar('I');
        Uart2PutChar('S');
        Uart2PutChar('R');
        Uart2PutChar('T');
        Uart2PutChar('0');
        Uart2PutChar('2');
        Uart2PutChar('\n');
赞 收藏 评论3 发布时间:2018-2-20 17:28
3个回答
wenyangzeng 回答时间:2018-2-20 22:02:39
楼主应该先检查一下USART2的硬件连接是否正常,然后才进入软件的故障排除步骤。
Angel_YY_ST 回答时间:2018-2-21 08:45:53
Tcreat 回答时间:2018-2-21 21:57:02
串口二引脚宏定义部分是否修改一致了? GPIO_InitStructure.GPIO_Pin    = USART2_TX;    GPIO_InitStructure.GPIO_Pin    = USART2_RX;
