STM32F103VBT6的串口2不能发送数据,请FAE帮忙看一下,谢谢!
yang100 提问时间:2018-4-20 09:55 /
这几天调试modbus,使用STM32F103VBT6的串口2,在配置完成后查询方式和中断方式都不能发送数据。不知道是配置还是哪里出错,请帮忙看下,谢谢!
  * @brief  串口初始化
  * @param  ucPORT      串口号
  *         ulBaudRate  波特率
  *         ucDataBits  数据位
  *         eParity     校验位
  * @retval None
BOOL
xMBPortSerialInit( UCHAR ucPORT, ULONG ulBaudRate, UCHAR ucDataBits, eMBParity eParity )
        (void)ucPORT;     //不修改串口
  (void)ucDataBits; //不修改数据位长度
  (void)eParity;    //不修改校验格式
  //使能USART2,GPIOA
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);//使能GPIOA时钟
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2,ENABLE);//使能USART2时钟
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;        //PA2
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;        //复用推挽
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;//PA3
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //浮空输入
// RCC_APB1PeriphResetCmd(RCC_APB1Periph_USART2,ENABLE);//复位串口2
// RCC_APB1PeriphResetCmd(RCC_APB1Periph_USART2,DISABLE);//停止复位
  USART_InitStructure.USART_BaudRate = ulBaudRate;            //只修改波特率
  USART_InitStructure.USART_Parity = USART_Parity_No;
  //串口初始化
  USART_Init(USART2, &USART_InitStructure);
  USART_ITConfig(UART2, USART_IT_RXNE, ENABLE);        /* 使能接收中断*/
  USART_ITConfig(UART2, USART_IT_TC, ENABLE);        /* 使能接收中断*/
  //使能USART2
  USART_Cmd(USART2, ENABLE);
  USART_ClearFlag(UART2, USART_FLAG_TC);
  //设定USART2 中断优先级
  NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 3;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;
  return TRUE;
  * @brief  通过串口发送数据
  * @param  None
  * @retval None
BOOL
xMBPortSerialPutByte( CHAR ucByte )
  //发送数据
  USART_SendData(USART2, ucByte);
  return TRUE;
  * @brief  从串口获得数据
  * @param  None
  * @retval None
BOOL
xMBPortSerialGetByte( CHAR * pucByte )
  //接收数据
  *pucByte = USART_ReceiveData(USART2);
  return TRUE;
/* Create an interrupt handler for the transmit buffer empty interrupt
* (or an equivalent) for your target processor. This function should then
* call pxMBFrameCBTransmitterEmpty( ) which tells the protocol stack that
* a new character can be sent. The protocol stack will then call
* xMBPortSerialPutByte( ) to send the character.
static void prvvUARTTxReadyISR( void )
  //mb.c eMBInit函数中
  //pxMBFrameCBTransmitterEmpty = xMBRTUTransmitFSM
  //发送状态机
  pxMBFrameCBTransmitterEmpty();
/* Create an interrupt handler for the receive interrupt for your target
* processor. This function should then call pxMBFrameCBByteReceived( ). The
* protocol stack will then call xMBPortSerialGetByte( ) to retrieve the
* character.
static void prvvUARTRxISR( void )
  //mb.c eMBInit函数中
  //pxMBFrameCBByteReceived = xMBRTUReceiveFSM
  //接收状态机
  pxMBFrameCBByteReceived();
  * @brief  USART2中断服务函数
  * @param  None
  * @retval None
void USART2_IRQHandler(void)
  //发生接收中断
  if(USART_GetITStatus(USART2, USART_IT_RXNE) == SET)
    prvvUARTRxISR();
    //清除中断标志位
    USART_ClearITPendingBit(USART2, USART_IT_RXNE);
  //发生完成中断
  if(USART_GetITStatus(USART2, USART_IT_TC) == SET)
    prvvUARTTxReadyISR();
    //清除中断标志
    USART_ClearITPendingBit(USART2, USART_IT_TC);
赞 收藏 评论3 发布时间:2018-4-20 09:55
3个回答
wenyangzeng 回答时间:2018-4-20 10:14:46
PA3也应该
队长shiwo 回答时间:2018-8-31 16:01:11
wenyangzeng 发表于 2018-4-20 10:14
PA3也应该
RX也要设置GPIO_Mode_AF_PP?这样你就收不到数据了,GPIO_Mode_AF_PP是复用推挽输出的
wenyangzeng 回答时间:2018-8-31 16:08:17
队长shiwo 发表于 2018-8-31 16:01
RX也要设置GPIO_Mode_AF_PP?这样你就收不到数据了,GPIO_Mode_AF_PP是复用推挽输出的 ...
官方的例程参考一下看看能否解决:
Interrupt.rar (14.97 KB, 下载次数: 888)
