STM32F0 SPI
tanic 提问时间:2019-8-7 10:11 /
如图,为啥我SPI的 3个字节写完了 SCK信号不停止呢
  1. SPI_InitTypeDef  SPI_InitStructure;
  2.         GPIO_InitTypeDef GPIO_InitStructure;
  3.
  4.         RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE);
  5.         RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB  , ENABLE);
  6.
  7.         GPIO_PinAFConfig(GPIOB, GPIO_PinSource13, GPIO_AF_0);
  8.   GPIO_PinAFConfig(GPIOB, GPIO_PinSource14, GPIO_AF_0);
  9.   GPIO_PinAFConfig(GPIOB, GPIO_PinSource15, GPIO_AF_0);
  10.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
  11.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  12.   GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  13.   GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_UP;
  14.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;;
  15.         GPIO_Init(GPIOB,&GPIO_InitStructure);
  16.
  17.   SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  18.         SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
  19.   SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
  20.   SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
  21.   SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
  22.   SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
  23.   SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_64;
  24.   SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_LSB;
  25.   SPI_InitStructure.SPI_CRCPolynomial = 7;
  26.   SPI_Init(SPI2, &SPI_InitStructure);
  27.
  28.         SPI_RxFIFOThresholdConfig(SPI2,SPI_RxFIFOThreshold_QF);
  29.         SPI_Cmd(SPI2, ENABLE);
  1. uint8_t spi2_read_write(uint16_t a)
  2. {
  3.         while(RESET==(SPI2->SR & SPI_I2S_FLAG_TXE));
  4.         SPI2->DR = a;
  5.         while(RESET==(SPI2->SR & SPI_I2S_FLAG_RXNE));
  6.         a = SPI2->DR;
  7.         while(RESET==(SPI2->SR & SPI_I2S_FLAG_TXE));
  8.         while(RESET==(SPI2->SR & SPI_I2S_FLAG_RXNE));
  9.
  10.         SPI_I2S_ClearFlag(SPI2,SPI_I2S_FLAG_OVR);
  11.         return a;
  12. }
  1. void LensWriteReg(uint8_t addr,uint16_t data)
  2. {
  3.         uint8_t buf[3];
  4.         buf[0]=addr&0x3f;
  5.         buf[1]=data;
  6.         buf[2]=data>>8;
  7.         CS_1;
  8.         spi2_read_write(buf[0]);
  9.         spi2_read_write(buf[1]);
  10.         spi2_read_write(buf[2]);
  11.         CS_0;
  12. }
赞 收藏 评论5 发布时间:2019-8-7 10:11
5个回答
tanic 回答时间:2019-8-7 10:14:00
用HAL傻瓜式配置,是没有问题的
tanic 回答时间:2019-8-7 10:58:29
*(uint8_t*)&SPI2->DR = (uint8_t)a;
即可
参与人数 1ST金币 +1 收起 理由
linuxdaxia + 1 赞一个!
butterflyspring 回答时间:2019-8-7 17:22:38
对比一下两种配置后的寄存器内容呗
tanic 回答时间:2019-8-8 09:23:28
butterflyspring 发表于 2019-8-7 17:22
对比一下两种配置后的寄存器内容呗
神奇的操作
将DR地址转换为 uint8_t* 和 uint16_t* 是两种不同的情况,
在根据初始化配置的8bit(包含以下)用uint8_t*  高于8的用uint16_t*
tanic 回答时间:2019-8-8 09:25:53
(中文版)手册翻遍没找到相关说明,看库试出来的
