STM32L475 ADC+DMA 配置问题,采集值一直为0
gaomoumou 提问时间:2020-4-28 14:41 /
adc配置:
void MY_ADC_Init(void)
     ADC_ChannelConfTypeDef ADC1_ChanConf;
    ADC1_Handler.Instance = ADC1;
    ADC1_Handler.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV2;
    ADC1_Handler.Init.Resolution = ADC_RESOLUTION_12B;
    ADC1_Handler.Init.DataAlign = ADC_DATAALIGN_RIGHT;
    ADC1_Handler.Init.ScanConvMode = ADC_SCAN_ENABLE;
    ADC1_Handler.Init.EOCSelection = DISABLE;
     ADC1_Handler.Init.ContinuousConvMode = ENABLE;
    ADC1_Handler.Init.DiscontinuousConvMode = DISABLE;
    ADC1_Handler.Init.NbrOfConversion = 2;
       ADC1_Handler.Init.NbrOfDiscConversion = 0;
    ADC1_Handler.Init.ExternalTrigConv = ADC_SOFTWARE_START;
    ADC1_Handler.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
    ADC1_Handler.Init.LowPowerAutoWait = DISABLE;
    ADC1_Handler.Init.DMAContinuousRequests = ENABLE;
    ADC1_Handler.Init.Overrun = ADC_OVR_DATA_PRESERVED;
    ADC1_Handler.Init.OversamplingMode = DISABLE;
                ADC1_ChanConf.Channel = ADC_CHANNEL_1;
    ADC1_ChanConf.Rank = ADC_REGULAR_RANK_1;
    ADC1_ChanConf.SamplingTime = ADC_SAMPLETIME_47CYCLES_5;
    ADC1_ChanConf.SingleDiff = ADC_SINGLE_ENDED;
    ADC1_ChanConf.OffsetNumber = ADC_OFFSET_NONE;
    ADC1_ChanConf.Offset = 0;
    HAL_ADC_ConfigChannel(&ADC1_Handler, &ADC1_ChanConf);
    ADC1_ChanConf.Channel = ADC_CHANNEL_2;
    ADC1_ChanConf.Rank = ADC_REGULAR_RANK_2;
    HAL_ADC_Init(&ADC1_Handler);
                HAL_ADC_Start(&ADC1_Handler);
DMA配置
void MYDMA_Config(DMA_Channel_TypeDef *DMA_Channel, u32 seq)//
          __HAL_RCC_DMA1_CLK_ENABLE();
    ADC1DMA_Handler.Instance = DMA1_Channel1;
    ADC1DMA_Handler.Init.Request = seq;
    ADC1DMA_Handler.Init.Direction = DMA_PERIPH_TO_MEMORY;
    ADC1DMA_Handler.Init.PeriphInc = DMA_PINC_DISABLE;
    ADC1DMA_Handler.Init.MemInc = DMA_MINC_ENABLE;
    ADC1DMA_Handler.Init.PeriphDataAlignment = DMA_PDATAALIGN_WORD;
    ADC1DMA_Handler.Init.MemDataAlignment = DMA_MDATAALIGN_WORD;
    ADC1DMA_Handler.Init.Mode = DMA_CIRCULAR;
    ADC1DMA_Handler.Init.Priority = DMA_PRIORITY_HIGH;
   HAL_DMA_Init(&ADC1DMA_Handler);
  HAL_DMA_DeInit(&ADC1DMA_Handler);
  __HAL_LINKDMA(&ADC1_Handler, DMA_Handle, ADC1DMA_Handler);
main中调用
HAL_ADC_Start_DMA(&ADC1_Handler, (uint32_t*)&AD_DMA, 2);
但AD_DMA中的数为0,不知道哪里出问题了,求大神帮忙看下
赞 收藏 评论6 发布时间:2020-4-28 14:41
6个回答
七哥 回答时间:2020-4-29 10:28:34
程序就这点点?ADC对应的IO不需要配置吗,IO时钟不需要开吗?找个样例程序改吧,不要想当然。
STMCU + 2
wenyangzeng 回答时间:2020-4-29 14:03:35
这句貌似把初始化完成的DMA又关闭了。
STMCU + 2
gaomoumou 回答时间:2020-4-29 14:17:47
当然需要配置,那些配置没什么问题,就没必要贴出来了
gaomoumou 回答时间:2020-4-29 14:22:38
这句貌似把初始化完成的DMA又关闭了。
谢谢,是这个问题,已解决
老牛洋车 回答时间:2020-4-30 07:20:29
怎么不用CubeMX来配置,会更省事、可靠。
参与人数 1蝴蝶豆 +3 收起 理由
STMCU + 3
gaomoumou 回答时间:2020-4-30 09:16:13
嗯,已经开始用CubeMX了,确实省事很多,谢谢
