STM32L151读取W25Q16的ID错误,请帮忙看看是什么原因
chenbourne 提问时间:2020-5-6 09:26 /
使用STM32L151的SPI2读取W25Q16的ID错误,返回总是0xFFFF,请帮忙看看代码是什么原因。代码参考的是正点原子的。
  1. void SPI2_Init(void)
  2. {
  3.   SPI_InitTypeDef  SPI_InitStructure;
  4.   GPIO_InitTypeDef GPIO_InitStructure;
  5.     ////SPI Set PB13,14,15 as Output push-pull - SCK, MISO and MOSI
  6.         RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2,ENABLE);
  7.     /* 使能SPI引脚相关的时钟 */
  8.    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB,ENABLE);
  9.
  10.     /*指令IO的复用功能*/
  11.      GPIO_PinAFConfig(GPIOB, GPIO_PinSource13,GPIO_AF_SPI2);
  12.   GPIO_PinAFConfig(GPIOB, GPIO_PinSource14,GPIO_AF_SPI2);
  13.   GPIO_PinAFConfig(GPIOB, GPIO_PinSource15,GPIO_AF_SPI2);
  14.     /*  SCK、MOSI、MISO */
  15.   GPIO_InitStructure.GPIO_Pin =   GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
  16.   GPIO_InitStructure.GPIO_Mode =  GPIO_Mode_AF;  //复用
  17.   GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //推挽
  18.   GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
  19.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_40MHz;
  20.   GPIO_Init(GPIOB,&GPIO_InitStructure);
  21.         /* SPI2 configuration */
  22.         SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  23.         SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
  24.         SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
  25.         SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
  26.         SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
  27.         SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
  28.         SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_2;
  29.         SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
  30.         SPI_InitStructure.SPI_CRCPolynomial = 7;
  31.         SPI_Init(SPI2, &SPI_InitStructure);
  32.         /* Enable SPI2  */
  33.         SPI_Cmd(SPI2, ENABLE);
  34.
  35.         SPI2_ReadWriteByte(0xff);
  36. }
  1. //SPIx 读写一个字节
  2. //TxData:要写入的字节
  3. //返回值:读取到的字节
  4. uint8_t SPI2_ReadWriteByte(uint8_t TxData)
  5. {
  6. uint8_t retry=0;
  7. while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_TXE) == RESET) //检查指定的SPI标志位设置与否:发送缓存空标志位
  8.   {
  9.   retry++;
  10.   if(retry>200)return 0;
  11.   }
  12. SPI_I2S_SendData(SPI2, TxData); //通过外设SPIx发送一个数据
  13. retry=0;
  14. while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_RXNE) == RESET) //检查指定的SPI标志位设置与否:接受缓存非空标志位
  15.   {
  16.   retry++;
  17.   if(retry>200)return 0;
  18.   }
  19. return SPI_I2S_ReceiveData(SPI2); //返回通过SPIx最近接收的数据
  20. }
  1. //读取芯片ID
  2. //返回值如下:
  3. //0XEF13,表示芯片型号为W25Q80
  4. //0XEF14,表示芯片型号为W25Q16
  5. //0XEF15,表示芯片型号为W25Q32
  6. //0XEF16,表示芯片型号为W25Q64
  7. //0XEF17,表示芯片型号为W25Q128
  8. uint16_t W25QXX_ReadID(void)
  9. {
  10. uint16_t Temp = 0;
  11. GPIO_ResetBits(GPIOB,GPIO_Pin_12);
  12. SPI2_ReadWriteByte(0x90);//发送读取ID命令
  13. SPI2_ReadWriteByte(0x00);
  14. SPI2_ReadWriteByte(0x00);
  15. SPI2_ReadWriteByte(0x00);
  16. Temp|=SPI2_ReadWriteByte(0x00)<<8;
  17. Temp|=SPI2_ReadWriteByte(0x00);
  18. GPIO_SetBits(GPIOB,GPIO_Pin_12);
  19. return Temp;
  20. }
收藏 评论8 发布时间:2020-5-6 09:26
8个回答
mylovemcu 回答时间:2020-5-6 10:22:58
PB12引脚是不是没有配置  默认的话是输入模式  不配置CS引脚不能拉低
还有测试一下其他读写功能好使不
参与人数 1蝴蝶豆 +3 收起 理由
STMCU + 3
chenbourne 回答时间:2020-5-6 12:29:43
还有测试一下其他读写功能好使不 ...
PB12配置了的,读写功能也不正常,读出来的数据与写进去的数据不一样
mylovemcu 回答时间:2020-5-6 13:14:25
PB15换成输入模式  不用复用模式
SPI波特率降低  你现在配置的是2分频  设置到128分频试一下
废鱼 回答时间:2020-5-6 15:03:54
用示波器先看有没有数据通讯,排除硬件链接和引脚功能配置错误以后,再进行确定发送的时序,数据内容是否真确。楼主应该掌握排查问题的方法,这样解决问题会快很多。
参与人数 1蝴蝶豆 +3 收起 理由
STMCU + 3
chenbourne 回答时间:2020-5-6 20:28:10
mylovemcu 发表于 2020-5-6 13:14
PB15换成输入模式  不用复用模式
SPI波特率降低  你现在配置的是2分频  设置到128分频试一下 ...
好的 我试一试 谢谢了
chenbourne 回答时间:2020-5-6 20:41:10
安 发表于 2020-5-6 15:03
用示波器先看有没有数据通讯,排除硬件链接和引脚功能配置错误以后,再进行确定发送的时序,数据内容是否真 ...
好的 谢谢了
李康1202 回答时间:2020-5-7 09:16:44
spi的速度降一下试一试
lebment 回答时间:2020-5-9 15:34:03
调试法则:1.检查硬件。
                2.检查软件。
                3.重复1,2步骤直到发现问题。
最基本的东西是正确的,后面的步骤才会有效。
