各位大大,我最近在做STM32L151时出现了一个问题,就是RTC唤醒(wake up)中断不会中断啊,不知道为什么。下面是我的部分程序: void RTC_Configuration(void) { /* Enable PWR and BKP clock */ RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR, ENABLE); /* Allow access to BKP Domain */ PWR_RTCAccessCmd(ENABLE); /* Enable the LSE OSC */ RCC_LSEConfig(RCC_LSE_ON); /* Wait till LSE is ready */ while(RCC_GetFlagStatus(RCC_FLAG_LSERDY) == RESET) { } /* Select the RTC Clock Source */ RCC_RTCCLKConfig(RCC_RTCCLKSource_LSE); /* Enable the RTC Clock */ RCC_RTCCLKCmd(ENABLE); /* Wait for RTC APB registers synchronisation */ RTC_WaitForSynchro(); RTC_InitStructure.RTC_AsynchPrediv = 0x06; RTC_InitStructure.RTC_SynchPrediv = 0x66; RTC_InitStructure.RTC_HourFormat = RTC_HourFormat_24; RTC_Init(&RTC_InitStructure); /* Configure the RTC WakeUp Clock source: CK_SPRE (1Hz) */ RTC_WakeUpClockConfig(RTC_WakeUpClock_CK_SPRE_16bits); RTC_SetWakeUpCounter(0x0); /* Enable the RTC Wakeup Interrupt */ RTC_ITConfig(RTC_IT_WUT, ENABLE); /* Enable Wakeup Counter */ RTC_WakeUpCmd(ENABLE); } void NVIC_Configuration(void) { NVIC_InitTypeDef NVIC_InitStructure; // Set the Vector Table base location at 0x08000000 */ NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0); // 1 bits for Preemption Priority and 3 bits for Sub Priority */ NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0); NVIC_InitStructure.NVIC_IRQChannel = RTC_WKUP_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); } 时钟用的是LSE,就是外部低速晶振(32.768K)的 一直不能产生中断,各位大大,帮我看看是怎么回事吧,小弟在此谢过了... |
STM32L151 stop模式 rtc 闹钟唤醒不稳定
STM32L151RDT6 SDIO读写SD卡 FIFO下溢错误,不知是什么原因
STM32L152 RTC唤醒STOP mode问题
STM32L151为何FLASH擦除后全是是0x00?
STM32L152开发板原理图及说明文档
STM32L1系列,如何释放PA15为普通GPIO端口
STM32L151读取W25Q16的ID错误,请帮忙看看是什么原因
STM32L151 STOP模式唤醒程序跑哪儿了
请问有人可以STM32L152驱动LCD段码屏例程吗?
求分享STM32L152例程!!!!!!!
第一,所有的RTC中断都必须由EXTI产生,手册上面有这样一句话:
All RTC interrupts are connected to the EXTI controller.
第二,既然是EXTI在产生,所以他不同于一般的中断。一般的中断是只要标志位为1,就一直触发中断,直到标志位被清零,这是电平触发(例如TIM_IT_Update就属于此类)。EXTI只能检测上升沿和下降沿,不能直接通过电平触发。因此,如果开机的时候一来RTC_FLAG_WUTF就已经置位,那么EXTI_Line22将永远是高电平,不会有上升沿,因此永远也不会触发中断。解决方案是在开中断前手动清除标志位:
第四,RTC_ITConfig(RTC_IT_WUT, ENABLE)和EXTI_Init(&exti)要同时打开。并且RTC_IT_WUT有记忆性,系统复位后不会关闭该中断。手动执行RTC_ITConfig(RTC_IT_WUT, DISABLE)后中断不再有效。
你可以在正常运行模式下使能唤醒,就会进入中断
回复:求助!!STM32L151中的RTC唤醒(wake up)中断问题
你在stm32l1xxit.h文件中有加中断程序吗?http://www.amobbs.com/thread-5004198-1-1.html这里貌似有这个中断。。不过我刚开始学,也不清楚这些。
RE:求助!!STM32L151中的RTC唤醒(wake up)中断问题
例如:
/* EXTI configuration *******************************************************/
EXTI_ClearITPendingBit(EXTI_Line20);
EXTI_InitStructure.EXTI_Line = EXTI_Line20;
EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;
EXTI_InitStructure.EXTI_LineCmd = ENABLE;
EXTI_Init(&EXTI_InitStructure);
官网上下载的STM32L固件库中就有RTC中断的例子,你可以参考。
什么问题,发帖说明情况。
测试代码:
system_stm32f2xx.c中要把SystemInit函数中的SetSysClock();函数调用注释掉,启动时选16MHz的HSI作为系统时钟。
我用的单片机是STM32L476,也是进不去中断,今天刚把这个问题解决掉。因为驱动库中给的RTC Wakeup的EXTI中断没有打开。进行如下操作:将HAL_RTCEx_SetWakeUpTimer_IT(&RtcHandle, 0, RTC_WAKEUPCLOCK_CK_SPRE_16BITS)函数中的__HAL_RTC_WAKEUPTIMER_EXTI_ENABLE_EVENT()替换为__HAL_RTC_WAKEUPTIMER_EXTI_ENABLE_IT()
分析的很透彻,也讲的很清楚,感谢分享
