STM32F030K6T6无法进入中断,在线等大神
shabiyufeiwang 提问时间:2020-7-13 21:55 /
void Usart_Init(void)
        //GPIO¶Ë¿ÚÉèÖÃ
    GPIO_InitTypeDef   GPIO_InitStructure;
  USART_InitTypeDef  USART_InitStructure;
  NVIC_InitTypeDef   NVIC_InitStructure;
   //DMA_InitTypeDef DMA_InitStructure;
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1|RCC_AHBPeriph_GPIOA, ENABLE); //ʹÄÜUSART1£¬GPIOAʱÖÓ
   USART_DeInit(USART1);
  GPIO_PinAFConfig(GPIOA,GPIO_PinSource9,GPIO_AF_1);
  GPIO_PinAFConfig(GPIOA,GPIO_PinSource10,GPIO_AF_1);
  //USART1_TX   PA.9
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9|GPIO_Pin_10; //PA.9
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; //¸´ÓÃÍÆÍìÊä³ö
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
    GPIO_Init(GPIOA, &GPIO_InitStructure); //³õʼ»¯PA9
   //USART ³õʼ»¯ÉèÖÃ
  USART_InitStructure.USART_BaudRate = 9600;//Ò»°ãÉèÖÃΪ9600;
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;//×Ö³¤Îª8λÊý¾Ý¸ñʽ
  USART_InitStructure.USART_StopBits = USART_StopBits_1;//Ò»¸öֹͣλ
  USART_InitStructure.USART_Parity = USART_Parity_No;//ÎÞÆæÅ¼Ð£Ñéλ
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//ÎÞÓ²¼þÊý¾ÝÁ÷¿ØÖÆ
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //ÊÕ·¢Ä£Ê½
   USART_Init(USART1, &USART_InitStructure); //³õʼ»¯´®¿Ú
   USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//¿ªÆôÖжÏ
   USART_ITConfig(USART1, USART_IT_IDLE, ENABLE);//
    //USART_DMACmd(USART1,USART_DMAReq_Rx,ENABLE);   //DMA enable
   USART_Cmd(USART1, ENABLE);                   //
   //Usart1 NVIC ÅäÖÃ
    NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPriority = 1;  //×ÓÓÅÏȼ¶3
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;   //IRQͨµÀʹÄÜ
  NVIC_Init(&NVIC_InitStructure); //¸ù¾ÝÖ¸¶¨µÄ²ÎÊý³õʼ»¯VIC¼Ä´æÆ÷
void USART1_IRQHandler(void)                 //´®¿Ú1ÖжϷþÎñ³ÌÐò
uint8_t Res;
GPIO_ResetBits(GPIOA,GPIO_Pin_8);
if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)  //½ÓÊÕÖжÏ(½ÓÊÕµ½µÄÊý¾Ý±ØÐëÊÇ0x0d 0x0a½áβ)
   Res =USART_ReceiveData(USART1);//(USART1->DR); //¶ÁÈ¡½ÓÊÕµ½µÄÊý¾Ý
   USART1_RX_BUF[len_usart1]=Res;
   len_usart1++;
   //LedShinning();
//GPIO_ResetBits(GPIOA,GPIO_Pin_8);
//Receive_Done = 1;
if(USART_GetITStatus(USART1, USART_IT_IDLE) != RESET)  //½ÓÊÕÖжÏ(½ÓÊÕµ½µÄÊý¾Ý±ØÐëÊÇ0x0d 0x0a½áβ)
   USART_ClearITPendingBit(USART1,USART_IT_IDLE);
   Receive_Done = 1;
   //LedShinning();
收藏 评论9 发布时间:2020-7-13 21:55
9个回答
mylovemcu 回答时间:2020-7-14 19:42:04
没有打开引脚复用功能的时钟
使用串口的时候引脚属于复用功能  需要打开复用功能时钟  就是AFIO的时钟
并且注意一下A口线的时钟  是AHB的时钟线  怎么用APB2的函数配置  我没看这个编程手册  不知道A口线是哪个时钟总线的  留意一下
shabiyufeiwang 回答时间:2020-7-14 21:37:32
mylovemcu 发表于 2020-7-14 19:42
没有打开引脚复用功能的时钟
并 ...
现在STM32忘上位机发送没有问题
ikxlf 回答时间:2020-7-15 09:15:54
不是我泼凉水 看到你发个帖子都这么的随意 不用心, 我也没有看的欲望了 , 至少排版的整齐点,把乱码要不删除要不就该人人类能看懂的符号这样不好吗?
fighter12315 回答时间:2020-7-15 09:57:05
你TX和RX都初始化为输出模式?还都上拉?试试把RX初始化为浮空输入
hjl2832 回答时间:2020-7-15 15:14:08
干嘛不用HAL呢,用CUBEMX配置,省得自己搞还出错。
小小超 回答时间:2020-7-15 17:24:33
初始化顺序调换一下。。。先把引脚初始化 ,再设置复用功能。。。
lebment 回答时间:2020-7-15 19:34:17
HAL库调试,LL库最后优化代码速度。
aiherong 回答时间:2020-7-16 03:49:34
孩子们都用库函数,看着爱莫能助!
乱码是因为没选用简体中文(在edit ->config 设置)
用PA9、PA10使用串口1不必复用,将PA9设为推挽输出,PA10设为上拉输入,分二次进行初始化,不可以放在一起一步完成,另外,将涉及复用的部分全注释掉,试试看,应该没问题!
shabiyufeiwang 回答时间:2020-7-19 23:35:47
斯文人 发表于 2020-7-15 09:15
不是我泼凉水 看到你发个帖子都这么的随意 不用心, 我也没有看的欲望了 , 至少排版的整齐点,把乱码要不 ...
   //USART1_TX   PA.9
    uint8_t Res;
        len_usart1++;
