编译器:IAR 芯片:stm8l151c8t6 64K的FLASH 目的:使用Block擦除和写入数据 严格按照以下步骤操作: æä»¶æè¿°æ¥éª¤ ![]() ![]() ![]() ![]() ![]() 结果编译时出现错误:Error[Lc036]: no block or place matches the pattern "ro code section FLASH_CODE in stm8l15x_flash.o" ![]() 根据错误在place in NearData 中添加了 ro section FLASH_CODE, ![]() 编译时有警告: Warning[Lp005]: placement includes a mix of sections with content (example "ro code section FLASH_CODE in stm8l15x_flash.o") and sections without content (example "rw data section .near.data in Flash.o") Warning[Lp006]: placement includes a mix of writable sections (example "rw data section .near.data in Flash.o") and non-writable sections (example "ro code section FLASH_CODE in stm8l15x_flash.o") ![]() 测试程序时,程序卡死,RAM汇编指令: ![]() 怎么测试都通过不了Block擦除与读写。 请教各位大神,我是哪里操作不对吗?我哪里设置不对呢? 谢谢了,各位大神!!! |
stm8l051f3 TSSOP20 封装,待机模式下,2天后,电流突然增加到140UA
stm8l050j3
STM8L的LCD调试时不亮
STM8L050J3使用SWIM下载方式,无法下载,总是报错
STM8L52、在主频1M下I2C 100K 时序异常,在主频16M就没问题。这是什么原因
stm8l152 低功耗7uA,降不下来
STM8 flash 库函数 startaddress = startaddress + ((uint32_t)BlockNum * FLASH_BLOCK_S
stm 8 flash 在RAM运行代码的问题,是不是库函数有问题 Library call (?sll32_l0_l0_a) from within a
批量中有少数几片STM8L101F3的uid多次读出不一致
STM8L051低功耗模式下ADC无法关闭
