STM8S103的板子上,有一个默认自带的AT24C02芯片,I2C读写,程序可以正常工作。 但是当飞线接另一个芯片时,却不能正常通讯,总是死在等待slaveAddress的应答上,I2C通信失败。 请教一下,有人遇到类似问题,如何解决的?? 下面是代码: void Delayms(unsigned int ms) { unsigned int x , y; for(x = ms; x > 0; x--) /* ͨ¹ýÒ»¶¨ÖÜÆÚÑ»·½øÐÐÑÓʱ*/ for(y = 3000 ; y > 0 ; y--); } void IIC_Init() { PB_DDR_bit.DDR4 = 1; PB_DDR_bit.DDR5 = 1; PB_ODR_bit.ODR4 = 1; PB_ODR_bit.ODR5 = 1; PB_CR2_bit.C24 = 1; PB_CR2_bit.C25 = 1; I2C_CR2_bit.SWRST = 1; //I2C1->CR1 |= 1 << 15; asm("nop"); asm("nop"); asm("nop"); asm("nop"); I2C_CR2_bit.SWRST = 0; //I2C1->CR2 &= ~I2C_CR2_FREQ; // I2C_FREQR_bit.FREQ = 16; //Freq = 36M I2C_CCRH_bit.F_S = 1; I2C_CCRH_bit.DUTY = 0; I2C_CCRL = 40; //200KHZ I2CFreq = PCLK1 / CCR / DUTY[λ] = 16MHZ / 40 / 2 = 200KHZ I2C_TRISER_bit.TRISE = 16 + 1; // I2C1->CR1 &= ~I2C_CR1_SMBUS; I2C_CR1_bit.ENGC = 1; I2C_CR1_bit.PE = 1; } void IIC_Write(unsigned char subaddr , unsigned char Byte_addr , unsigned char *buffer , unsigned short num) { unsigned char i2csr1; //while(I2C1->SR2 & I2C_SR2_BUSY); I2C_CR2_bit.START = 1; while(I2C_SR1_bit.SB == 0); i2csr1 = I2C_SR1; //SR1.AF I2C_DR = (subaddr); while(I2C_SR1_bit.ADDR == 0); i2csr1 = I2C_SR1; i2csr1 = I2C_SR3; I2C_DR = Byte_addr; while(I2C_SR1_bit.BTF == 0); i2csr1 = I2C_SR1; while(num > 0) { I2C_DR = *buffer; while(I2C_SR1_bit.BTF == 0); i2csr1 = I2C_SR1; buffer++; num--; } I2C_CR2_bit.STOP = 1; } void IIC_Read(unsigned char subaddr , unsigned char Byte_addr , unsigned char *buffer , unsigned short num) { unsigned char i2csr1; I2C_CR2_bit.ACK = 1; I2C_CR2_bit.START = 1; while(I2C_SR1_bit.SB == 0); i2csr1 = I2C_SR1; I2C_DR = subaddr; while(I2C_SR1_bit.ADDR == 0); i2csr1 = I2C_SR1; i2csr1 = I2C_SR3; I2C_DR = Byte_addr; while(I2C_SR1_bit.BTF == 0); i2csr1 = I2C_SR1; I2C_CR2_bit.START = 1;//I2C1->CR1 |= I2C_CR1_START; while(I2C_SR1_bit.SB == 0); i2csr1 = I2C_SR1;//SR1.AF?? I2C_DR = (char)(subaddr | 0x01); while(I2C_SR1_bit.ADDR == 0); i2csr1 = I2C_SR1; i2csr1 = I2C_SR3; while(num) { if(num == 1) { I2C_CR2_bit.ACK = 0; I2C_CR2_bit.STOP = 1; } while(I2C_SR1_bit.RXNE == 0); i2csr1 = I2C_SR1; *buffer = I2C_DR; buffer++; num--; } } |
STM8S003无法检测到引脚电平
STM8 @svlreg 问题
STM8AF62XX+L99PM62GXP LIN通讯的电路原理图有吗?官网提供了一套软件,没找到对应的原理图,请大家指教一下
求一个STM8S207例程
STMS005K6T6 如何采集内部参考电压。
stm8s003 adc中断和通道切换的问题
adc施密特触发器stm8
stm8l051f3 TSSOP20 封装,待机模式下,2天后,电流突然增加到140UA
STM8S用STVP烧录怎么加密?
不是两个24C02芯片,一个24C02是板子自带的,一个是飞线连接的另一个芯片,IIC地址是不一样的。
