本文讲述基于STM32G070进行ADC多通道采集,并分别介绍非DMA方式和DMA方式。# }" o/ q1 H' W. h4 \
1. 非DMA方式采集+ N; Y& `, w/ G# C& N
ADC初始化代码如下(使用STM32CubeMx自动生成),配置了3个通道:
% |! e# }% f9 | C! r) T) [/ F) `8 X5 @3 v8 ^( F6 \; ~+ Q
4 B% \* @" J6 V+ \
- static void MX_ADC1_Init(void)
; ?, e- _! h" j( X" _: `$ D - {
7 b) F" C* ^+ [8 `7 `
8 T- M+ z' i" x5 \1 b- /* USER CODE BEGIN ADC1_Init 0 */. ^( s' H3 q2 U* V
6 V! m& \# N- f6 h0 v- /* USER CODE END ADC1_Init 0 */
( b4 j7 A p) F2 F$ {5 d- p) a7 @ - ! J& _2 C5 ~# h I( v# r
- ADC_ChannelConfTypeDef sConfig = {0};. f8 Q8 H2 H/ D$ m: v
- ( m& n# J- h& Y! P
- /* USER CODE BEGIN ADC1_Init 1 */7 E& v# v9 b( H, F z5 f5 b/ m
- . x: w. W8 J* d0 C' U& Y& q
- /* USER CODE END ADC1_Init 1 */0 `- a0 U5 m* t
- /** Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion)
, g( ]' d, a# ]( l% o - */
- Z0 ^, }4 B- D; I b& a' G - hadc1.Instance = ADC1;% {1 M& f( W6 [
- hadc1.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV2;
% V5 @6 ^1 P' `5 z; P - hadc1.Init.Resolution = ADC_RESOLUTION_12B;
' p* P9 P8 I1 F. s - hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;3 |5 G) K3 {4 U
- hadc1.Init.ScanConvMode = ADC_SCAN_ENABLE;
, H! }, f/ l7 D# \; ~ - hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV;8 z4 s/ ?" r c0 O$ I/ C
- hadc1.Init.LowPowerAutoWait = DISABLE;, N# {' z. w& I& r0 R
- hadc1.Init.LowPowerAutoPowerOff = DISABLE;8 j' l, V+ |" n
- hadc1.Init.ContinuousConvMode = DISABLE;1 M+ }' [; H! A, z' m2 J; l. C+ F' {
- hadc1.Init.NbrOfConversion = 3;: ~) \* ^. A2 l, D1 X
- hadc1.Init.DiscontinuousConvMode = ENABLE;
1 p1 k! {. a$ I: Z0 o2 ^' F1 w - hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;; F3 G T3 Q' h
- hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
- m3 Q. i+ b! V; h - hadc1.Init.DMAContinuousRequests = DISABLE;
4 J, e0 A6 p4 l6 A, j1 k! r4 ] - hadc1.Init.Overrun = ADC_OVR_DATA_PRESERVED;
3 n/ R' i" c8 N3 C/ B% G - hadc1.Init.SamplingTimeCommon1 = ADC_SAMPLETIME_1CYCLE_5;2 ?- x; E' c! U
- hadc1.Init.SamplingTimeCommon2 = ADC_SAMPLETIME_1CYCLE_5;
. |" D9 b, ^4 O; G5 ~9 ]& d - hadc1.Init.OversamplingMode = DISABLE;
2 D! O& d- |4 v( p: F: } - hadc1.Init.TriggerFrequencyMode = ADC_TRIGGER_FREQ_HIGH;1 s* s: N) E' z6 d
- if (HAL_ADC_Init(&hadc1) != HAL_OK)( t3 b- ?6 a- r2 N% ~$ L
- {' }. T; ^! H# ]$ v# F3 _: z+ A
- Error_Handler();
) [- @5 j2 z1 F6 A H - }
& I. c6 ?5 f% G' U - /** Configure Regular Channel
+ h2 Y( Z4 B* ]( g T- Y/ P - */% y( ]: m8 i9 C6 h
- sConfig.Channel = ADC_CHANNEL_4;# x# A6 N+ {2 G0 P1 ^: K
- sConfig.Rank = ADC_REGULAR_RANK_1;
e c6 T O5 d5 T- o$ Q$ L - sConfig.SamplingTime = ADC_SAMPLINGTIME_COMMON_1;
+ B4 E# S0 X% K7 J - if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)9 K, A& i2 T- ?2 ]( r
- {. ^0 ~0 O( j2 C/ e' {
- Error_Handler();
7 {# |3 s6 m; e: {* u. ^0 @9 q6 S - }
+ I+ J. m g- o! d7 n c; {* W7 d$ o - /** Configure Regular Channel
# f( F8 @4 ^4 N1 t, i1 I$ L - */1 Y# |) m, U/ b! w: y0 d
- sConfig.Channel = ADC_CHANNEL_5;
% ^4 e ] o5 L9 o - sConfig.Rank = ADC_REGULAR_RANK_2;: y2 M1 L& p* e" d, M$ u
- if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)7 q7 f3 n$ y- a
- {. N! _3 F$ b* @5 C: u; E8 d' b
- Error_Handler();0 i. i2 R/ p0 x! f) i9 R( j; ~6 @$ ? e8 \
5 a6 O+ V" Y7 J+ i: d - /** Configure Regular Channel' U3 D* o5 x! A0 U/ _9 C& K7 ~+ b
" P5 E6 _! I# i! U - sConfig.Channel = ADC_CHANNEL_9;2 v; P5 F+ L& s, m- i# w# N
- sConfig.Rank = ADC_REGULAR_RANK_3;# ^" r. F# v, i! w5 J0 C' x
# Y6 y6 H0 B4 \* m }3 o - {4 m5 ?8 {3 u/ v, L8 X( N! H
- Error_Handler();
! l& i2 F# M3 ? - }5 _# E* R* k- b
- /* USER CODE BEGIN ADC1_Init 2 */4 {5 C; Y+ f9 T6 S2 ^
- 7 S% b/ G" C) z
- /* USER CODE END ADC1_Init 2 */8 N" S! i# e0 J+ Z
- + `% y* [& d# S7 |' n/ n8 K+ V
) m+ O* v, a1 w; s
复制代码 获取ADC数据
1 j2 ?* O" ^4 G* }% i- // 校准
* l3 a9 f* _! @$ } - HAL_ADCEx_Calibration_Start(&hadc1);
+ E A8 j3 A+ E2 X4 G8 n7 \1 e2 b5 X
7 P5 g: U3 ~$ {- for (idx = 0; idx < 3; idx++)3 l$ f/ U* C" ^& ]; r/ h0 |2 b1 G
F6 [& E' e& r; u& F8 } - HAL_ADC_Start(&hadc1);) D1 T1 O" J9 n5 g1 A" R
- HAL_ADC_PollForConversion(&hadc1, 50);7 N1 }$ l4 R; r# d: @4 y+ D2 q& \
( z8 X/ h: A- l# _! T% q5 `- /* Check if the continous conversion is finished */! b3 w4 o$ V: P$ r) M" p1 i ]
- if(HAL_IS_BIT_SET(HAL_ADC_GetState(&hadc1), HAL_ADC_STATE_REG_EOC))' H* _; x: k# Q" q% h- i. }* J
" H5 u- Q: x l' X3 T; |4 I - /* Get the converted value */
' \2 m0 D+ \" C& X - AD_Value[idx] = HAL_ADC_GetValue(&hadc1);
9 V7 N& F8 _+ ~7 u0 T - }
: \2 x6 P; ~6 N% ~+ d' l5 ^4 R - }" \- c6 C8 i# S6 f2 y2 y" J
# Q$ \% R" n0 p$ Z4 V* h' S$ E- HAL_ADC_Stop(&hadc1);
% y' z3 w% e1 e2 L
复制代码 1.1 关于ADC扫描定序(scan sequencer)
% s" j9 c+ T* V5 J- GADC scan sequencer can be used in two different modes. 配置ADC多通道采集时,对于各个通道的采集顺序有两种方式:- G4 |9 j* N) L, S) K9 u
3 x! r+ V8 d3 n+ K: K6 E4 Y6 Z+ F2 |
; |8 n0 ]* u4 A+ z) F, \, r- ?
Sequencer fully configurable (The order in which the channels are scanned is independent from the channel number)! P8 L# F5 I% |/ s: g: _, Q) b( m
采用这种方式时,ADC的通道扫描顺序将和channel number不再相关,如1中代码,就采用了这种方式2 s: z3 N3 R1 {! D7 v; c* [
- //扫描方式:ADC_SCAN_ENABLE9 |) Q1 q( E2 F; b: ^9 Q: _1 Q- O
- hadc1.Init.ScanConvMode = ADC_SCAN_ENABLE;& [2 c3 ?% _4 b. [0 }9 N0 y0 F. b' a
: ~4 [4 k; C0 @' I: \& l - sConfig.Channel = ADC_CHANNEL_5;* e+ ]* a' j6 ~1 V W/ j; ?; y
3 w4 ?2 @" G+ t8 M. ] - if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)- g) R' Y, L$ `5 X) I4 T
- {' i; @; e: N! _0 j* P/ C
- Error_Handler();8 c4 Z+ A3 K& _6 d; F9 B! S* x ~* q6 @
- }$ B& {7 V% W9 n' }& \ N! g
- $ e" t: W+ i4 V' }/ b
- sConfig.Channel = ADC_CHANNEL_6;# P5 Z% a# K h
- sConfig.Rank = ADC_REGULAR_RANK_1;6 S0 |! z" z% g! ?
- if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)$ ]3 }4 m* I h6 M8 F0 c4 | {
- {$ l& e) s( `$ v
- Error_Handler();
+ N9 G& r5 e7 w% z5 v- ? - }; i9 l4 A. k5 y6 J* p) f2 B
复制代码 如果按照如上代码配置,在采集时,将先采集channel 6,再采集channel 5。但是使用该方式时,需要注意Only channel 0 to channel 14 can be selected in this sequence。即channel 15/16/17/18无法使用该方式,如果需要使用channel 15-18,则可以使用下面第二种扫描方式。
; {2 {& y/ G! o6 ~7 `, F
% p6 |$ s( j) \
! {3 t6 G4 U( c7 _$ {/ ASequencer not fully configurable (The order in which the channels are scanned is defined by the channel number)
" i0 x* Y5 g* w: ?# l1 ~: e( r8 {这种方式比较好理解,就是按照channel number的大小,按顺序进行扫描,配置代码如下:
; V6 d9 s/ z" Y. [4 ~8 b1 N; v- W0 m- // 扫描方式:ADC_SCAN_SEQ_FIXED
2 Y' N4 O) ^* ^( Z- g X* I - hadc1.Init.ScanConvMode = ADC_SCAN_SEQ_FIXED;
+ G9 u+ ^$ M- |
]2 l# S' e: j6 }" Q8 w" k- sConfig.Channel = ADC_CHANNEL_16;
' z7 ]1 l" K( ~9 M4 a" g8 ^+ P - sConfig.Rank = ADC_RANK_CHANNEL_NUMBER;8 @, ^9 R7 j6 ]
( i; m! K4 g ^% o# p - {
' d: }% ]; e! a7 e' b7 y1 k/ F - Error_Handler();. c! }% W: o! x! s. c9 t
- } a2 G: G! l( _" H8 S! Y% {7 M
复制代码 2. DMA方式采集- y; Y" K s6 u) y3 S N. I
直接上代码:
9 X% O) Z* S) p; l6 z: ?- static void MX_ADC1_Init(void)! m2 W' g/ g. s2 R
0 @! a- a+ S! W3 ] - , g' w- j' m$ _. M# e; N* l
9 P" x- h; \# Y1 L. j2 R - # }- s- H& r i+ Z
- /* USER CODE END ADC1_Init 0 */& g0 @0 t4 F/ P% w0 z8 x( \" f
- ( }/ u) D6 y l' B! s7 w
- ADC_ChannelConfTypeDef sConfig = {0};9 G) W/ P$ b8 g( q; V) M
- + z7 p9 G! c# U! d" f6 E1 p R
" F! |6 V$ V' U2 r, O8 C - ) n' \" @- Q+ t( W2 w. u$ i
- /* USER CODE END ADC1_Init 1 */- P/ v+ V. O' Y* k% u
# X* [3 F( d3 i - */# ^; C- L: k& b3 |
- hadc1.Instance = ADC1;: f/ w6 c! o, y( v
- hadc1.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV1;
( T/ I$ b) ~. D# q6 y/ ^. J0 L - hadc1.Init.Resolution = ADC_RESOLUTION_12B;
! u, m1 j8 e/ v2 l* z - hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
3 X( W1 a4 Y& J6 |1 x - hadc1.Init.ScanConvMode = ADC_SCAN_SEQ_FIXED;1 i2 v; X/ w* h' m1 \+ @
/ p/ t" w( v! h$ N! E# @8 F - hadc1.Init.LowPowerAutoWait = DISABLE;
* Q; j7 |7 z* Y& X! g6 H - hadc1.Init.LowPowerAutoPowerOff = DISABLE;
1 ^/ }8 _; i) p; H - hadc1.Init.ContinuousConvMode = ENABLE;# J+ A. r% m% T7 Y
- hadc1.Init.DiscontinuousConvMode = DISABLE;
: T6 s# f( _) A/ W2 d& V - hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
( P! `4 w* g' C- ]# s/ d( w; R& K- r - hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;7 X! q) l' E9 Q- l- m" s+ M0 n+ o
- hadc1.Init.DMAContinuousRequests = ENABLE;
i; ~2 N+ o/ ^2 S# z4 n9 x8 G( t( M - hadc1.Init.Overrun = ADC_OVR_DATA_OVERWRITTEN;3 l: c2 Q; ~1 J1 g7 x8 v
- hadc1.Init.SamplingTimeCommon1 = ADC_SAMPLETIME_12CYCLES_5;- K; t9 h9 Z" c
- hadc1.Init.OversamplingMode = DISABLE;0 t- S# ~. K5 y! P. R
- hadc1.Init.TriggerFrequencyMode = ADC_TRIGGER_FREQ_HIGH;" \" y& I# P' B B' X' A3 V
- if (HAL_ADC_Init(&hadc1) != HAL_OK)% ]0 W. n5 z3 L2 J5 u) c
' f: K9 N8 r% ^6 W' F8 ]: a - Error_Handler();" C2 V* k! A4 v
/ J* K( e; `' d3 b - /** Configure Regular Channel
" l" W9 J5 c, u( X - */8 ]7 y; ?& } l9 \% w
" d3 E8 V0 R( G9 @0 B - sConfig.Rank = ADC_RANK_CHANNEL_NUMBER;" `/ h& e% H0 L" \
- if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK): v5 Y; [# ] c9 c8 W7 `$ ^' x4 K
- {. r/ ~! d2 D: I, G2 n2 U
- Error_Handler();: M' e: @8 V: s' a6 ?1 m H
- }$ `# K& ?# V( F2 u4 ]
- /** Configure Regular Channel- F$ L( p4 h3 P3 J3 e' Z
I! ]7 [$ q& p* s2 L - sConfig.Channel = ADC_CHANNEL_5;
- A @% v. w# B* J" t - sConfig.Rank = ADC_RANK_CHANNEL_NUMBER;
7 ~$ b6 w& i$ t9 r; V/ L( i9 x - if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)+ R1 u O, l! R w. z C: I
- {# p6 x0 n; @ f; |6 |+ m, C0 `0 R
- Error_Handler();
# `7 A& |# a3 {/ p* _) E. u/ ? - }
' k H! p2 h; h( o - /** Configure Regular Channel; y5 n. a8 N/ W5 S% L" a
5 X+ @ x/ {* a4 ~' m; C: p! L - sConfig.Channel = ADC_CHANNEL_9;
; i* a0 \: M! z8 H - sConfig.Rank = ADC_RANK_CHANNEL_NUMBER;
a8 k3 V& l& C3 Q$ c - if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
8 w& P. h1 w+ l) O) k3 Y. { - {. o* l& M2 }9 F, R
- Error_Handler();
. w; y9 L2 c7 J: t/ W: @4 P - } W& Q& i& q. s. Z3 H
- /** Configure Regular Channel+ C5 b G: @. S0 D# R( S) @ ?
- */& {! Q! b# W' e( F) q* f
- sConfig.Channel = ADC_CHANNEL_10;7 ?* }5 H% @% L; F$ I& G
% L, O, d6 j: {( S2 W" y - if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
$ @) y9 O5 A! m: Y' r - {9 ]& Y: ]# |- C0 z6 O7 O- _" F
- Error_Handler();; v) w4 ?0 @' L7 a9 }* j- M4 i
- }+ s& |) S& Y r: S' X# I
- /** Configure Regular Channel; F0 {: k" c" _7 W Z" S( j4 ^7 v
- */8 @8 a4 q0 x+ b V4 G" n$ j, L
- sConfig.Channel = ADC_CHANNEL_16;" z, q: r5 i' e! _+ w ^3 M- E
! K0 I6 a5 |+ R# a - if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)+ t- X2 q4 k9 K4 A( y# l s
- {0 o( d: e9 z: @4 a: V) O3 D3 Q( ?) Y- ]
- Error_Handler();
, \" X: V! |( q4 y+ K, k' z6 g# E - }; A( \5 N6 s @, r# ~ J% }
- /* USER CODE BEGIN ADC1_Init 2 */$ l1 L+ ~0 m6 _/ J4 S- F9 g
- 6 g7 F) n Q: I4 ]% f" {0 a4 w& P
7 e6 i4 K% t7 a3 y& g5 G - : F7 n9 o8 x* Y
& F, N3 y9 g( J) U0 _2 ~% e# n - Z. l. P9 B( ?" b( J
- static void MX_DMA_Init(void)/ L8 u# n' L, ?' H4 }2 h7 a' T1 q* _
& A: I7 x. y2 Q6 F" _) I/ l+ {8 b - 0 \2 R8 G9 b5 N! e7 y
- /* DMA controller clock enable */% T0 T, Q- f. r$ ~4 m2 g) _
- __HAL_RCC_DMA1_CLK_ENABLE();
5 Y c8 _$ z0 J8 |* Y) P6 ~( d - 3 c% j1 F8 g. W% Y, v0 r
- /* DMA interrupt init */& N! w' B% w$ j7 F3 P7 Q( k
- /* DMA1_Channel1_IRQn interrupt configuration */8 G0 ^% ?1 y& J
- HAL_NVIC_SetPriority(DMA1_Channel1_IRQn, 0, 0);3 K+ E9 a9 v' S$ Z& I0 l: g
- HAL_NVIC_EnableIRQ(DMA1_Channel1_IRQn);/ X3 Y8 H. ^6 H# L: F
- ' J9 @3 i7 V6 F' |# O F# T3 N. [
- }9 @- c( ?6 @8 L' a' W/ G! W
- 7 R2 A4 M. ^" I4 D; f
- void HAL_ADC_MspInit(ADC_HandleTypeDef* hadc)
1 S0 \! L$ _+ c: o7 L Y1 L7 O" p - {- ]1 Z) v) A/ j8 h7 G2 A
- GPIO_InitTypeDef GPIO_InitStruct = {0};
6 {4 b2 \5 O; e7 ` - if(hadc->Instance==ADC1); u( p! X. [( z3 {
5 B t* B# c* n0 ^* H/ g0 B V" z - /* USER CODE BEGIN ADC1_MspInit 0 */4 V2 o- r8 b- R0 c6 d
+ I; _2 D2 L- j4 J1 z' d$ k- /* USER CODE END ADC1_MspInit 0 */) V8 }, f( Q$ R2 ]: g
- /* Peripheral clock enable */" @ |( c1 r( ^ `: e
- __HAL_RCC_ADC_CLK_ENABLE();
: X4 ~& g4 T7 L3 k
; _4 _0 N P! P1 R" s! q- __HAL_RCC_GPIOA_CLK_ENABLE();
, m8 z) `& h/ Y1 }/ z, F - __HAL_RCC_GPIOB_CLK_ENABLE();
0 _* r) }5 \, K# q# U" c& d+ l - /**ADC1 GPIO Configuration
0 o4 F' U: B# @7 C8 q" {& L/ o - PA4 ------> ADC1_IN4
6 M$ N$ @- ^; }4 u' r - PA5 ------> ADC1_IN5! j' R9 L$ i" d
- PB1 ------> ADC1_IN98 |. N: Y A* l
- PB2 ------> ADC1_IN10
h+ u9 h- y6 N" V - PB12 ------> ADC1_IN16
. |. u0 x$ b2 B2 k% m - */
9 q* |- c8 P0 `# G3 F r& d3 n: r - GPIO_InitStruct.Pin = GPIO_PIN_4|GPIO_PIN_5;$ B: [5 J0 P) b
- GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;: V# u5 {' h/ L& l
- GPIO_InitStruct.Pull = GPIO_NOPULL;
0 I8 i2 B- F( t- p - HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
5 G& [( `" L" Q# s1 j7 p- N9 m! x9 O+ F - 2 P* W p5 E+ E- U: L
- GPIO_InitStruct.Pin = GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_12;
4 N( e" _: w) j' p& _ - GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
& u: I. [2 i( w - GPIO_InitStruct.Pull = GPIO_NOPULL;
+ d% \/ _+ F. F% o" c a3 q8 ?9 u - HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);. l' H0 M- m& G1 M4 i5 l
3 x& |7 h4 a; l- /* ADC1 DMA Init */
2 I9 h, B5 k3 a8 {" S - /* ADC1 Init */! S/ {3 w. s+ r6 e$ h y
- hdma_adc1.Instance = DMA1_Channel1;
# k, R* G: O0 l2 A' F% |1 o! w. E - hdma_adc1.Init.Request = DMA_REQUEST_ADC1;& ?5 r4 ?5 L7 d" E
- hdma_adc1.Init.Direction = DMA_PERIPH_TO_MEMORY;
4 s8 m. X+ }7 w; j% S/ z: V; Z - hdma_adc1.Init.PeriphInc = DMA_PINC_DISABLE;
0 U( o4 z& F1 Q. ], P9 S" r - hdma_adc1.Init.MemInc = DMA_MINC_ENABLE;3 Q) s+ ?2 s$ ]/ Q5 f
- hdma_adc1.Init.PeriphDataAlignment = DMA_PDATAALIGN_WORD;3 T/ ~+ ?9 g6 V: y3 ~& ?6 ^
- hdma_adc1.Init.MemDataAlignment = DMA_MDATAALIGN_WORD;! {) }# k! z* A! K
- hdma_adc1.Init.Mode = DMA_CIRCULAR;- q' N; X) U# O: |/ X- ?
- hdma_adc1.Init.Priority = DMA_PRIORITY_LOW;
* }" [5 [$ d5 B8 J! M+ L - if (HAL_DMA_Init(&hdma_adc1) != HAL_OK)
8 M- h- C" P$ N6 | - {
8 @$ H' \# H; L `; s - Error_Handler();
& A, l, \" Y- B( P - }. }$ e+ {0 j) J' u) \5 C' D
- $ k. }! K# C7 K2 V
- __HAL_LINKDMA(hadc,DMA_Handle,hdma_adc1);
5 d5 b2 q: ~2 s f7 I
$ ^" z( r4 z; ^1 c- /* USER CODE BEGIN ADC1_MspInit 1 */
0 _( H9 K, q: d2 L& j# u - & q$ S/ k/ l+ W, x
- /* USER CODE END ADC1_MspInit 1 *// T. ~2 S6 Q( b! `* P) i7 p
. s5 o. @+ z- _ - 8 t2 v/ m/ l3 k; L7 d) }
- }( l4 {; i A6 ?6 W: W# N
复制代码 初始化完成后,即可使用:: R) }& {9 h& f# f& o B4 V
- //开始ADC转换4 s5 ?# `' h& N
- HAL_ADCEx_Calibration_Start(&hadc1);/ B3 y- {7 O% _, M
- HAL_ADC_Start_DMA(&hadc1, (uint32_t *)&AD_Value_Buffer, AD_DMA_BUFF_LENGTH);
复制代码 注:AD_Value_Buffer为事先定义好的数组,长度为AD_DMA_BUFF_LENGTH. @' N6 {, N# Z* |' Z: d5 B- k
接下来,无需CPU参与,DMA将会把ADC采集到数据搬运至AD_Value_Buffer的地址中,当长度达到AD_DMA_BUFF_LENGTH时,将从头开始,此时会覆盖数据。
2 H" w7 \6 g# @; `" }5 ?; i( b$ _1 Z& I7 p5 Q: p1 R# m
) V9 B# l# V" o$ E7 N- E- _
5 u" ]9 L7 ~4 e: a3 p y& E9 z
+ v+ R) E$ m/ G+ H" Q2 {% v& K5 ~ q7 E5 ]0 A6 G, }" f5 O
8 v' z+ y* `" w& y
7 l. R9 \; v: B( u$ o
