请问有懂ST SL算法库的吗?
gcq689 提问时间:2021-7-22 09:19 / 未解决
ST H750支持SL(角度评估),属于声学应用领域,哪位比较懂?烦请指点一下,如下参数,什么意思:libSoundSourceLoc_Handler_Instance.channel_number = 4;  libSoundSourceLoc_Handler_Instance.M12_distance = DIAGONAL;
  libSoundSourceLoc_Handler_Instance.M34_distance = DIAGONAL;
  libSoundSourceLoc_Handler_Instance.sampling_frequency = AUDIO_IN_SAMPLING_FREQUENCY;
  libSoundSourceLoc_Handler_Instance.algorithm = UserAudioStatus.SLocStatus.Algorithm;
  libSoundSourceLoc_Handler_Instance.ptr_M1_channels = 4;
  libSoundSourceLoc_Handler_Instance.ptr_M2_channels = 4;
  libSoundSourceLoc_Handler_Instance.ptr_M3_channels = 4;
  libSoundSourceLoc_Handler_Instance.ptr_M4_channels = 4;
  libSoundSourceLoc_Handler_Instance.samples_to_process = 512;
  AcousticSL_getMemorySize( &libSoundSourceLoc_Handler_Instance);
赞 收藏 评论1 发布时间:2021-7-22 09:19
st_yujie2510 回答时间:2021-7-26 13:54:41
您从哪里拿到SL库的?一般在提供库文件的同时,会同步提供一个库文件的说明文档,类似下图中:
