我使用STM32L4R9ZGT6,移植了UCOSIII 和 STEMWIN,参考了正点原子的STM429开发板,实验2,文本显示,UCOSIII STEMWIN都移植了,显示缓冲用的是内部RAM ,没有使用DMA2D,直接LTDC驱动了,程序如下 void TFT_LCD_Init(void) { LTDC_HandleTypeDef hltdc; LTDC_LayerCfgTypeDef pLayerCfg = {0}; LTDC_LayerCfgTypeDef pLayerCfg1 = {0}; /* USER CODE BEGIN LTDC_Init 0 */ Ltdc_GPIO_Init(); // __HAL_RCC_DMA2D_CLK_ENABLE(); // 源地址-> 目的地址图像格式混合格式 __HAL_RCC_LTDC_CLK_ENABLE(); // 产生LCD需要的各种时钟 /* USER CODE END LTDC_Init 0 */ /* USER CODE BEGIN LTDC_Init 1 */ // USER CODE END LTDC_Init 1 hltdc.Instance = LTDC; // Polarity configuration // Initialize the horizontal synchronization polarity as active low hltdc.Init.HSPolarity = LTDC_HSPOLARITY_AL; // Initialize the vertical synchronization polarity as active low hltdc.Init.VSPolarity = LTDC_VSPOLARITY_AL; // Initialize the data enable polarity as active low hltdc.Init.DEPolarity = LTDC_DEPOLARITY_AL; // Initialize the pixel clock polarity as input pixel clock hltdc.Init.PCPolarity = LTDC_PCPOLARITY_IPC; // The RK043FN48H LCD 480x272 is selected // Timing Configuration hltdc.Init.HorizontalSync = (TM043NDH02_HSYNC - 1); hltdc.Init.VerticalSync = (TM043NDH02_VSYNC - 1); hltdc.Init.AccumulatedHBP = (TM043NDH02_HSYNC + TM043NDH02_HBP - 1); hltdc.Init.AccumulatedVBP = (TM043NDH02_VSYNC + TM043NDH02_VBP - 1); hltdc.Init.AccumulatedActiveW = (TM043NDH02_WIDTH + TM043NDH02_HSYNC + TM043NDH02_HBP - 1); hltdc.Init.AccumulatedActiveH = (TM043NDH02_HEIGHT + TM043NDH02_VSYNC + TM043NDH02_VBP - 1); hltdc.Init.TotalWidth = (TM043NDH02_WIDTH + TM043NDH02_HSYNC + TM043NDH02_HBP + TM043NDH02_HFP - 1); hltdc.Init.TotalHeigh = (TM043NDH02_HEIGHT + TM043NDH02_VSYNC + TM043NDH02_VBP + TM043NDH02_VFP - 1); // Configure R,G,B component values for LCD background color : all black background hltdc.Init.Backcolor.Blue = 0; hltdc.Init.Backcolor.Green = 0; hltdc.Init.Backcolor.Red = 0; // Configure the LTDC if (HAL_LTDC_Init(&hltdc) != HAL_OK) { Error_Handler(); } // Layer1 Configuration ------------------------------------------------------ // Windowing configuration // In this case all the active display area is used to display a picture then : // Horizontal start = horizontal synchronization + Horizontal back porch = 43 // Vertical start = vertical synchronization + vertical back porch = 12 // Horizontal stop = Horizontal start + window width -1 = 43 + 480 -1 // Vertical stop = Vertical start + window height -1 = 12 + 272 -1 pLayerCfg.WindowX0 = 0; pLayerCfg.WindowX1 = 0; pLayerCfg.WindowY0 = 0; pLayerCfg.WindowY1 = 0; pLayerCfg.PixelFormat = LTDC_PIXEL_FORMAT_RGB565; pLayerCfg.Alpha = 0; pLayerCfg.Alpha0 = 0; pLayerCfg.BlendingFactor1 = LTDC_BLENDING_FACTOR1_CA; pLayerCfg.BlendingFactor2 = LTDC_BLENDING_FACTOR2_CA; pLayerCfg.FBStartAdress = 0; pLayerCfg.ImageWidth = 0; pLayerCfg.ImageHeight = 0; pLayerCfg.Backcolor.Blue = 0; pLayerCfg.Backcolor.Green = 0; pLayerCfg.Backcolor.Red = 0; if (HAL_LTDC_ConfigLayer(&hltdc, &pLayerCfg, LTDC_LAYER_1) != HAL_OK) { Error_Handler(); } pLayerCfg1.WindowX0 = 0; pLayerCfg1.WindowX1 = 480; pLayerCfg1.WindowY0 = 0; pLayerCfg1.WindowY1 = 272; pLayerCfg1.PixelFormat = LTDC_PIXEL_FORMAT_L8; // Alpha constant (255 == totally opaque) pLayerCfg1.Alpha = 255; // Default Color configuration (configure A,R,G,B component values) : no background color pLayerCfg1.Alpha0 = 255; pLayerCfg1.BlendingFactor1 = LTDC_BLENDING_FACTOR1_CA; pLayerCfg1.BlendingFactor2 = LTDC_BLENDING_FACTOR2_CA; pLayerCfg1.FBStartAdress = (uint32_t)&RGBL8_480x272; pLayerCfg1.ImageWidth = 480; pLayerCfg.ImageHeight = 272; pLayerCfg1.Backcolor.Blue = 0; pLayerCfg1.Backcolor.Green = 0; pLayerCfg1.Backcolor.Red = 0; if (HAL_LTDC_ConfigLayer(&hltdc, &pLayerCfg1, LTDC_LAYER_2) != HAL_OK) { Error_Handler(); } //##-2- CLUT Configuration ################################################ HAL_LTDC_ConfigCLUT(&hltdc, (uint32_t *)L8_480x272_CLUT, 256, LTDC_LAYER_2); if (HAL_LTDC_SetPitch(&hltdc, 0, 0) != HAL_OK) { Error_Handler(); } if (HAL_LTDC_SetPitch(&hltdc, 0, 1) != HAL_OK) { Error_Handler(); } // USER CODE BEGIN LTDC_Init 2 // USER CODE END LTDC_Init 2 //##-3- Enable CLUT For Layer 1 ############################################ HAL_LTDC_EnableCLUT(&hltdc, LTDC_LAYER_2); // Assert backlight LCD_BL_CTRL pin HAL_GPIO_WritePin(GPIOB, LCD_On_Off, GPIO_PIN_SET);// } 这个是直接初始化LTDC的层2 在显示缓冲区RGBL8_480x272里修改数据,能变化画面 然后移植 STEMWIN, 没有用层, 程序如下 //设置EMWIN内存大小 #define GUI_NUMBYTES (20*1024) #define GUI_BLOCKSIZE 0x80 //块大小 //GUI_X_Config //初始化的时候调用,用来设置emwin所使用的内存 void GUI_X_Config(void) { U32 *aMemory = mymalloc(SRAMIN,GUI_NUMBYTES); //从内部RAM中分配GUI_NUMBYTES字节的内存 GUI_ALLOC_AssignMemory((U32 *)aMemory, GUI_NUMBYTES); //为存储管理系统分配一个存储块 GUI_ALLOC_SetAvBlockSize(GUI_BLOCKSIZE); //设置存储快的平均尺寸,该区越大,可用的存储快数量越少 GUI_SetDefaultFont(&GUI_Font16B_1); //设置默认字体 } void LCD_X_Config(void) { //设置第一层 GUI_DEVICE_CreateAndLink(GUIDRV_LIN_8,GUICC_M332,0,0); GUI_SelectLayer(0); // 设置层0 LCD_SetSizeEx(0,XSIZE_PHYS,YSIZE_PHYS); LCD_SetVSizeEx(0,XSIZE_PHYS,YSIZE_PHYS); LCD_SetVRAMAddrEx(0, RGBL8_480x272); } 应用程序如下 GUI_Init(); //STemWin初始化 WM_MULTIBUF_Enable(1); // 开启stemwin 多缓冲,RGB屏可能会用到 WM_SetCreateFlags(WM_CF_MEMDEV); //Use memory devices on all windows to avoid flicker WM_SetCallback(WM_HBKWIN, &_cbBkWindow); //Set callback for background window GUI_SetBkColor(GUI_RED); GUI_Clear(); GUI_SetBkColor(GUI_BLACK); GUI_Clear(); GUI_SetColor(GUI_WHITE); GUI_DispStringAt("Hello!", 0, 0); GUI_Delay(10); 显示缓冲区使用的8位L8 , GUI_SetBkColor(GUI_RED); GUI_Clear(); 显示缓冲区填充的是0xe0 红色 GUI_SetBkColor(GUI_BLACK); GUI_Clear(); 显示缓冲区填充的是0x00 黑色 GUI_SetColor(GUI_WHITE); GUI_DispStringAt("Hello!", 0, 0); 显示不出来字符,显示缓冲区没有变化,都是0x00 怎么回事情? |
使用CubeMX能配置STM32L4XX芯片的低功耗模式吗?
STM32L4P5 有OCTOSPI配置成QSPI驱动LCD屏的相关示例吗(IC:GC9B71)
STM32L476 使用系统bootloader中的IIC下载,读取数据时,时钟线为什么会一直为低?
简单聊聊STM32的SPI外设
Bluenrg-ms是否支持hid 复合设备?
stm32l4p5zg 串口1低温-40度tx无法正常输出高
哪一个型号的stm32支持DMA直接从SPI将数据搬运到FMC
STM32L431RCT6 关机模式使用Wakeup唤醒
STM32L431RCT6 怎么将PB3(JTDO-TRACESWO)引脚配置成GPIO输出使用
STM32L451ADC读数有问题
OS_ERR err;
return ((int)OSTimeGet(&err)); //»ñȡϵͳʱ¼ä,´Ë´¦Ê±¼äµ¥ÔªÎª1ms
//GUIÑÓʱº¯Êý
void GUI_X_Delay(int period) {
OS_ERR err;
CPU_INT32U ticks;
ticks = (period * 1000) / OSCfg_TickRate_Hz;
OSTimeDly(ticks,OS_OPT_TIME_DLY,&err);//UCOSIIIÑÓʱ²ÉÓÃÖÜÆÚģʽ
为什么?
